07-27-2019, 10:01 AM
#1301
2019 23' International
Portland
, Oregon
Left it on the charger overnight. The battery was full the WFCO was at 13.6
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
07-27-2019, 10:57 AM
#1302
Portland
, Oregon
Is there anything critical under the floor in the compartment where the inverter is? Do I have to worry about the screws that hold the shunt down penetrating the floor?
07-27-2019, 11:21 AM
#1303
Portland
, Oregon
07-27-2019, 11:29 AM
#1304
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Originally Posted by leedav
Thinking I might just put the victron here on the pedestal. We're outside anyway when the generator is running and it has Bluetooth. Also, what is this thing in the speaker enclosure?
That would be a good spot. I used the prewire to the galley because I wanted easy visual on the meter, but once it was installed and I saw how sweet the bluetooth app is...the meter really doesn't need to be easily visible. The box with the wires is a mystery. Is that on the wall under the dinette seat next to the sub? Looks like one wire has a white tag on it, can you read what it says?
Temp sensor is $20. Dammit I've been reading this stuff until my eyes are falling out and I missed that.
Temp sensor doesn't matter unless you add solar with the Victron Charge Controller that will use the temp to regulate the charge...I *THINK*. Not a massively huge deal even then, as far as I'm concerned.
Even the PD4655 might not go into 13.2 float for 48 hours or so, and then as soon as a load is applied to the batts, goes back into 13.6 mode. Don't stress too much about it, the main advantage is getting the true bulk mode with manual override, and the true 13.2 float mode when plugged in for long periods of time, especially storage (for those that store their's plugged in).
No, especially not those short screws, they won't even penetrate the plywood all the way.
07-27-2019, 11:38 AM
#1305
The Aluminum Tent 3
Park City
, Utah
Nice. You're in! Great spot for it.
07-27-2019, 11:50 AM
#1306
The Aluminum Tent 3
Park City
, Utah
Something to keep in mind when watching 'float' vs 'absorption' vs 'bulk,' and what the battery voltage reads at any given moment, etc...is that this is not like a mechanical connection with absolutes. It's actually a very fluid and flexible process. The monitor should measure amps 'out' at any given moment quite accurately, as well as what the battery voltage is at any given moment...but keep in mind that even that can be impacted by how long since it's been 'offline' from the charger, etc. My tow vehicle, I discovered during this process, provides current through the umbilical even if the car is turned off...which would totally mislead the readings from my Victron Monitor as far as amps being used, and voltage in the trailer battery. Other vehicles only provide power through the cord if the car is running, or ignition is 'on', and I've heard some only if the car is in "D". So depending on all that you might need to unplug from umbilical if stopped for the night and want to monitor batteries. Just remember to plug back in before leaving!
If you're camping without shore power, yes, the voltage will be pretty accurate as well. But things like 'time to discharge' on the Victron are nothing more than guesses, at a specific moment in time, so don't get caught up in that. Also, the PD4655 is always in a 'dance' with the batteries, trying to figure out how charged they are, what draws there are, and what voltage and current it needs to provide them with, at any moment in time. All that bounces around constantly so don't worry about instantaneous readings or charger outputs at any given moment. Just let it do its thing, and let the new monitor help you keep an eye on all of it.
07-27-2019, 12:18 PM
#1307
Portland
, Oregon
So I just installed the jumpers that allow me to check the levels in my battery, because for some reason airstream gives you a little short ones that don't let you open the caps. Both batteries have a bad cell at the end, which is probably contributing to my issues. Good news is the pd4655 just arrived
07-27-2019, 01:30 PM
#1308
Portland
, Oregon
Dog is out. Kat is in
07-27-2019, 01:41 PM
#1309
The Aluminum Tent 3
Park City
, Utah
Ahhhhh I know you loved seeing that 14.1V. Did it default to that or did you bump it in to boost.
Re: bad cells in batteries: Make sure water is full, Give them a good 2-day charge, remove power, let rest a couple hours, then test with hydrometer. If each still has a bad cell, pull them out and head to the store for two new ones...they are toast and will not hold a charge. Better yet...switch to two 6V batteries and bump your available amp hours from around 160 to 225 :-) On a 2019 they should fit in your box without needing an extension. (Verify this of course. Trojan T105s are 11.07 inches tall. Would require you to put replace 12V house side lugs with ring lugs at batteries.
07-27-2019, 01:45 PM
#1310
Portland
, Oregon
Originally Posted by pcskier
Ahhhhh I know you loved seeing that 14.1V. Did it default to that or did you bump it in to boost./
> a chorus of angels sang
> not sure b/c I hit the button then realized I wasn't plugged in.
> The Interstate guy in our neighborhood said bring the whole rig on Monday, so plenty of time for them to equalize. Water was low too. Didn't like the circular finger pointing between AS and Interstate but it's all good now
> yes, 6v when these die on MY nickel..
07-27-2019, 01:49 PM
#1311
The Aluminum Tent 3
Park City
, Utah
Oh yeah if Interstate is hooking you up with freshies, go with that obviously for now. Check water in new batteries often, especially now you have a charger that will be pumping out 14.x volts at times.
Good job, now just the shunt and you're in business.
07-27-2019, 04:05 PM
#1312
Portland
, Oregon
Ok. Kind of an ordeal (mostly fear of a bonfire), appreciate the coaching.
Tomorrow I'll pick up the tools and put the mattress back.
Thanks again.
07-27-2019, 05:06 PM
#1313
The Aluminum Tent 3
Park City
, Utah
Thanks again. Attachment 347763Attachment 347764
Wow you're done! nice job. Get your new batteries and go camping!
07-27-2019, 07:21 PM
#1314
Wolfwhistle
Margaritaville
, Banana Republic
I’ve been following along. I really don’t get it that there are 2 negative - black cables - that run to the negative terminal of the battery bank. I only had 1. If it’s for another function usage won’t be calculated, of course. Just sayin’
Clint
07-27-2019, 07:42 PM
#1315
Portland
, Oregon
It goes to the inverter. Dunno why.
Clint
07-27-2019, 07:59 PM
#1316
The Aluminum Tent 3
Park City
, Utah
Clint
On his trailer, Airstream used separate cables from the batteries, one set to the 12V house (6ga) and one set to the inverter (4ga). If trailer was not equipped with factory inverter, there would have only been the one set, 12V house.
So instead of just interrupting one set of cables from the batteries with the shunt, he had two sets to interrupt...the inverter and house cables. Needed to include both cables from the batteries to the shunt, in order to have enough wire capacity to carry both house loads and inverter load. Then continue the original two wires from load side, one to the inverter, the other to house. So inverter draw and house draw will flow through the shunt.
On my install, I removed the 6ga and 4ga pairs when I did my 6V battery conversion, and went with 2ga wire from battery to the trailer; then 4ga from load side of shunt to inverter, and 6ga from load side of shunt to house 12v. The 2ga was installed so that I had enough capacity to carry both the house and inverter loads on one strand of cable. Doing it Leedav's way is easier and perfectly fine, but I decided to go a bit cleaner with less wires from the batts. Especially since I installed a switch that gives me four options: battery off, house only, inverter only, or both house and inverter. The second switch is to isolate solar panels from the solar charger.
07-28-2019, 07:15 AM
#1317
1975 29' Ambassador
2019 23' Flying Cloud
Beach Park
Attachment 347776
Attachment 347777
OK Please bare with me as I went from a 1975 29' to this new 2019 23FB and I've been following this thread but I'm not sure I understand what the shunt is for or does. Do or should I put one in on my coach? Thanks John
07-28-2019, 07:21 AM
#1318
Portland
, Oregon
The 23FB forum
The shunt is a resistor. It allows the monitor, which is basically a voltmeter, to measure the current flowing in and out of the battery. It's small resistance doesn't affect the power usage. Since voltage=current times resistance, the meter can determine by reading the voltage across the shunt how much current is being drawn, and by keeping track of that over time, how much power remains in the batteries. A battery meter therefore will only work with a shunt.
07-28-2019, 08:42 AM
#1319
Portland
, Oregon
Now thinking about closet shelves. From the battery meter exercise I now know that the closet walls are 33/64 thick, including the paper on each side.
07-28-2019, 10:04 AM
#1320
The Aluminum Tent 3
Park City
, Utah
John, congrats on the upgrade. She shunt is if you wanted to install a more robust dedicated battery monitor such as the Victron that Leedav used. It accurately will display battery voltage like the OEM systems monitor on the panel does, but also allows for an accurate reading (because of the shunt) of amps being used and some other metrics, which is helpful for battery management when boondocking or non-hookup campsites. (No shore power hookup). All negative loads go through the shunt to accomplish this.
Definitely not required, but a 'nice to have'.
Many of us have added in conjunction with a solar installation. I did, because it's helpful to see the 'net amps' flowing to or from the battery based on various power draws and solar production input. If the meter shows a net of 0 amps...the sun is keeping your batteries at par. If negative...you're using less than you're producing, and if positive...your producing more than you're using. Just sort of a window to know what is happening overall, with an eye to conserving battery power while not hooked up to shore power.
