04-23-2019, 09:34 AM
#1081
Walnut Creek
Found this video, which is supposed to be a generic guide. Looks like it is poke and prod investigation time. Thanks to the original poster. Pat
04-23-2019, 01:30 PM
#1082
2015 23' FB Flying Cloud
Omaha
, Nebraska
12 volt comes from battery under trailer into electrical area under head of bed. There it goes to an always on bus with circuit breakers (for propane detector, trailer brakes, and a few other always on items) then to use-store solenoid. From there dips under floor by water heater to street side and the converter.
04-23-2019, 01:39 PM
#1083
Omaha
, Nebraska
04-23-2019, 01:44 PM
#1084
Omaha
, Nebraska
04-23-2019, 01:45 PM
#1085
Omaha
, Nebraska
Not sure why pictures loading twice. Sorry.
04-23-2019, 01:47 PM
#1086
2007 22' International CCD
Corona
The 23FB forum
Sometimes when you post it looks like the picture is in there twice. It’s a bug in the software, I think. Your post looks fine from here.
04-23-2019, 01:54 PM
#1087
Omaha
, Nebraska
Thanks. Most frustrating was replacing the broken plastic water tank drain. Accessing the little hose clamp to remove and replace is almost impossible.
04-23-2019, 02:12 PM
#1088
2014 23' International
Hurst
Originally Posted by dolson
Thanks. Most frustrating was replacing the broken plastic water tank drain. Accessing the little hose clamp to remove and replace is almost impossible. Attachment 338951
Ooooo, I want to do this. How did you access the almost-impossible-to-get-to clamp... through the bottom access panel?
04-23-2019, 02:19 PM
#1089
Omaha
, Nebraska
Tried bottom access panel first, even enlarged it a little but was difficult. Finally found it easier to access from above through the closet floor next to water pump with a long screwdriver. Cut away some of the vinyl to reveal a larger access hole.
04-23-2019, 02:25 PM
#1090
Hurst
Thanks for the good info. I'm sorry that it won't help me... drat! The 23D's fresh water tank isn't really accessible from up top. Oh well, it was worth asking... thanks again. By the way, ALL your projects are awesome!
04-23-2019, 02:35 PM
#1091
Omaha
, Nebraska
There is the pesky little clamp seen from above through th street side closet floor.
04-23-2019, 02:45 PM
#1092
Omaha
, Nebraska
If you carefully jack up the trailer with jack stands you could do it from the bottom. My problem was the ground clearance was not sufficient to work from below. That would have been my next try if I didn’t get it from above.
04-23-2019, 02:54 PM
#1093
Hurst
There is the pesky little clamp seen from above through th street side closet floor. Attachment 338952
Actually, this is very helpful. Thanks a million for taking the time to share your knowledge and experience!
Rob
04-24-2019, 08:47 AM
#1094
SR
2014 23' FB International
DFW
Dolson, those are all nice projects. Looks like your pup is already enjoying the extra space under the table.
Do you think the table top could be positioned in the center of the space if the Lagun base were mounted in the corner to the right of center position?
04-24-2019, 09:01 AM
#1095
Omaha
, Nebraska
The horizontal arm is 15” long (13” center on center post) so not quite long enough unless moved somewhat toward the center plus the adjustment lever is on the right of the vertical post so it would have to be mounted on the left side.
04-24-2019, 09:41 AM
#1096
SR
DFW
This is very helpful information. Thank you for sharing!
05-28-2019, 08:22 AM
#1097
2019 25' Flying Cloud
Westmoreland
, New Hampshire
Elfa Closet Help
I thought I remember seeing on this forum someone giving the exact order for their Elfa shelving for their large closet but I can't find it. I have a few questions. Do we need to worry about the weight of the shelving unit itself? Do we order the cabinet depth or the regular depth? What it the max width of shelving to order and not get in the way of the door? Does anyone remember seeing that post? Thanks for any help!
05-29-2019, 08:29 PM
#1098
1958 22' Flying Cloud
1971 31' Excella 500
2012 23' FB International
1996 30' Land Yacht
https://www.google.com
, https://www.google.com
23FB shower door bottom seal
I have a 23FB and need to replace the bottom “slide in” seal for the shower door. I was hoping someone might be able to help me out with finding this... Or possibly the shower door manufacturer?
Also, is there a simple way to adjust the door for plumb? Any input would be greatly appreciated.
Thanks!
06-04-2019, 05:51 AM
#1099
2017 23' Flying Cloud
Cleveland
, Ohio
Thanks for water heater support
Just want to say that thanks to the good information I’ve found here I successfully swapped out our 23FB water heater igniter board and mixing valve. Both procedures were pretty much plug and play. The Dinosaur board seems to have exorcised our hot water demons. All good!
06-04-2019, 08:14 AM
#1100
Walnut Creek
Morning 23FBs
Closet storage - the wire drawer installation that I have seen discussed was for the 27s. Don't remember an order list, but a Blue Box word search might reveal the thread you want. We talked to one 23 owner who had replaced the closet with shelving. That install was only solid board installation for separation and control. The Ultimate Airstream group also markets their storage alternatives.
Never replaced the seal on the shower door, so have same interest. Suggest a post in a general group like the Flying Cloud threads. The door has got to be used on other models and the seal is likely a standard extrusion.
Good to hear your WH problems are vanquished. Yes, the info here is greatly appreciated. Sharing makes the group stronger and smooths the route to just about everywhere.
Travel safe. Pat
