Old 04-11-2019, 05:43 AM   #1041
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Jdubya, we also swi5chd from 19 to 23FB. I think the 23 pulls better. Maybe it’s the dual axle, not sure, but it feels very stable back there. We don’t have a lot under the bed. All the spare boots and shoes. All the linens towels etc in the tubs. We do have a lot of clothes in the over the bed cabinets and both wardrobes. Plus all my fishing stuff. We also have the front storage compartment packed full. Tool box, hoses and miscellaneous stuff.
You’re going to love the 23FB. Welcome to the group.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 04-11-2019, 10:53 AM   #1042
2019 23' International
Seattle , Washington
Thank you PKI so much great information!!!!!!!
Bradley G is offline   Reply With Quote
Old 04-11-2019, 04:47 PM   #1043
2018 23' Flying Cloud
Savoy , Texas
We went from a 22FB to our 23FB. Using the bathroom scale weight measure loaded for travel our hitch weight is around 625 lbs. Ten gallons of fresh water and 5 gallons of water in black tank. It pulls smoother than the 22FB.
SpinWhite is offline   Reply With Quote
Old 04-12-2019, 02:48 AM   #1044
2017 23' International
Liberty Hill , Texas
Tires
What are the thoughts on the factory supplied tires? We plan two long times this summer and a neighbor said that the tires supplied by the factory are junk and I should immediately upgrade. I get ours today and no idea of the quality of the tires.
Franktr is offline   Reply With Quote
Old 04-12-2019, 05:09 AM   #1045
GettinAway's Avatar
Depends on which ones you have. If they are Goodyear Marathons, you will probably want to swap them out. Depends a bit on age. If they are the newer Goodyear Endurance tires, Iíve read almost 100% positive comments on them. When I switched from 14Ē wheels to 15Ē, I went with the GY Endurance tires, and so far so good. I watch tire pressures closely, no matter what tire is there. Tire failure on an AS can be very costly. If the tread separates and beats on the aluminum, or dump valves.. Knocking on wood.
2011 FC 23FB
Old 04-12-2019, 08:54 PM   #1046
First Night
Our first night love it so far. Bathroom and shower are great.. Two questions for now the fridge does it have an internal light? Also can we adjust the Temp does not seem cold enough.
Old 04-12-2019, 08:56 PM   #1047
Okay I have Goodyear Endurance tires 15 inch so I should be okay.
Old 04-12-2019, 09:00 PM   #1048
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
No, the big fridges do but not the ones installed in the 23’s
Yes,it can be adjusted by siding the thermistor (I believe) down on the cooling fin. BUT...With that said,it will never be as cold as a residential refrigerator, Welcome to RV refrigeration.
Old 04-13-2019, 06:29 AM   #1049
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We converted our stock refrigerator to a Verifrigo DP150i freon based coolent with a Dan Foss 12Vdc compressor and it does have an internal light and accurate temperature control with both a freezer compartment with it’s own door and the main refrigerator compartment.
Old 04-13-2019, 10:02 AM   #1050
GettinAway's Avatar
I would certainly say so. Many threads on the GY Endurance. Almost all very positive. Now, when you need to decide what pressure to run them at, thatís opening up a whole different can of worms.
2011 FC 23FB
Old 04-14-2019, 06:05 AM   #1051
Long Island , New York
Most thermistors have to be moved up to get colder I think. [Mnemonic -- it is colder UP north]
Good quality fridge/freezer thermometers are essential to track this IMO.
Also, try to avoid putting warm items in the fridge. Buy things cold, or pre-chill them in a cooler . . . makes a huge difference in performance. You can get close to residential performance IMO. In hot weather, adding some ice once in a while helps the cows limp back to the barn, doncha know?
Peter
OTRA15 is online now   Reply With Quote
Old 04-14-2019, 07:25 AM   #1052
Thinking of running 75 PSI> Could not find a definitive number bit the tires say 80 PSI I think that is a max pressure.
Old 04-14-2019, 07:30 AM   #1053
Another question Towel Rack bathroom/Mattress
We have a 2017 23FB and want to add another towel rack on the door in the bathroom. However where can I buy one the same as what is there? I would like them to match.
We elected to swap the mattress from our old trailer to this one but it is too large. So going to buy a replacement. How is the Airstream OEM Mattress? Does anyone have the air adjustable mattress and are they worth the added cost.
Old 04-14-2019, 07:44 AM   #1054
2017 23' Flying Cloud
Bartlett , Tennessee
We added an over the door option similar to this:
We like our Airstream mattress. Be careful replacing it. One corner of the mattress is severely shortened to accommodate the curve of the trailer wall.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 04-14-2019, 09:42 AM   #1055
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
The towel rck should be available from AS service. Believe someone else asked the same question. http://www.airforums.com/forums/f295...ts-133783.html
The bed frame requires the addition of a section of 1/4" plywood and a foot fiddle to allow the use of a full size queen mattress. The square corner of the std mattress leaves space at the head, but that area is easily filled with foam, pillows or a headboard as one user elegantly installed.
We found that a heavier mattress required the upgrade of the platform lift struts and sourced them from a commercial parts house. The brackets need a backing plate and through bolts for sufficient mounting structure to deal with the added load. An extra block of wood has worked well so far.
So, yes, a full size mattress will fit. Much nicer for the taller among us. The short fall with which we struggle is the foam mattress construction. It deforms through the night and the indents which match your body shape are valleys which must be escaped to roll over. We believe we would have been better served with firm conventional construction mattress.
There have been folks who tried the air adjustable mattress and reported great comfort. Someday we may try one. Pat
Old 04-15-2019, 04:40 AM   #1056
GettinAway's Avatar
We just bought a memory foam topper and find it along with the factory mattress to be just fine.
I’m running my GY Endurance tire pressures at 70 also. I know that’s way more than needed, but we are not seeing any popped rivets, or open doors etc..
2011 FC 23FB
Old 04-15-2019, 09:45 AM   #1057
switz's Avatar
2014 31' Classic
Images: 8
Here is the load table for the Good Year Endurance tires. The highest inflation may shake the trailer to death.
File Type: pdf GoodYear Endurance Tire Load Table.pdf (301.0 KB, 28 views)
Old 04-15-2019, 09:49 AM   #1058
2016 19' Flying Cloud
Miami Springs , Florida
We have a 19t single axle (23 is on order), and we upgraded the tires to Endurance after reading all the horror stories about the Marathons right when the Endurance came out. Since we were looking for the maximum safety we went to recommendation on the sidewall: "For Max Load Inflate to 80 PSI". Ride quality improved significantly, and we know about popped rivets and others only from the forum, but on the 23 I would consider running lower PSI as the weight supported by every tire is way less.
Meanwhile the 19's GVWR of 4500 puts 2250 on each of its two tires, the 23's GVWR of 6000 will put only 1500 over each of is four tires. The double axle 23 outs very little stress over the tires when compared to other AS models (bigger and smaller), therefore probably we have (its the first time I refer to myself as a 23 owner ;-)) larger room to play than others when it comes to pressures....
Gallego is offline   Reply With Quote
Old 04-15-2019, 09:53 AM   #1059
Ravenna , Ohio
If you read the actual wording on tires the "max infl" is directly related to the stated "Max Load".
Load capacity on ALL tires is directly related to the tire inflation pressure. It is the air pressure that supports the load else why have Load Inflation tables?
I have never seen a "Sidewall construction/load capacity" table.
If you keep your tires properly inflated for the actual load you will ONLY have sidewall failure if you have an Impact (shock load) or a cut/puncture (loss of air).
"Proper inflation" means more air pressure than identified in the table for the actual scale measured load (while running lower speed than tire design.
Load formula on P & LT tires is based on an assumed 85 mph operational speed. Load Formula for ST tires is based on an assumed 65 mph max speed. If ST didn't have a lower speed limit they what magic is used in ST tires to allow them to support more load than LT tires? Note that P tires are to be De-rated" when in P/U or trailer application to a load capacity that is similar to the capacity of an LT tire of the same physical dimension.
Retired tire engineer (40 years). Write a blog on RV Tire Safety. Give seminars for FMCA In Perry GA & Minot ND.
Tireman9 is offline   Reply With Quote
Old 04-15-2019, 10:06 AM   #1060
2014 23' FB Flying Cloud
Yamhill , Oregon
And here is the load table for Michelin LTX 235/75 R 15 Defender tires. I run mine between 35-37 for our 23FB. They run cool and gives an excellent towing experience.
I am looking for a load vs pressure chart for Defender 235/75R15 LTX tires.
Inflation=Load
26=1545
29=1686
32=1825
35=1960
38=2094
41=2183
Rob Edgerton is offline   Reply With Quote
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 03:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 02:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
