Old 05-15-2017, 03:38 PM   #57
Long Island , New York
Originally Posted by Bobbo View Post
I don't have the trailer yet, and it seems like I remember the stabilizer jacks had square shanks.
That may be the case on some AS, not sure. I would call your dealer for specs and see if the new trailer will come with a nice mechanic's hand crank like we have for the stabilizer jacks. Pretty sure ours are 3/4" hex head also.
Thanks Troutboy for the clarification.
Old 05-15-2017, 06:47 PM   #58
2017 23' Flying Cloud
Bartlett , Tennessee
It definitely comes with a hand crank, but I want a socket for my 18v impact wrench.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 05-15-2017, 07:01 PM   #59
Troutboy's Avatar
Parker , Colorado
The 23FB forum
I bought this one and use it with my 18v. Works great.
https://www.amazon.com/gp/aw/d/B001V...co+jack+socket
Troutboy
Troutboy is offline   Reply With Quote
Old 05-15-2017, 09:11 PM   #60
2019 25' Flying Cloud
2018 23' Flying Cloud
NC , SC, GA, FL
Any issues with the Air Conditioner in the summer months? Does the 23FB stay cool enough with only one unit?
Xplore is offline   Reply With Quote
Old 05-16-2017, 05:53 AM   #61
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Ours is fine in the hot and humid Missouri summers. Will cool it to any temp. I'm not sure if we've ever been in direct sun though. We always are in shade, but plenty of summer hot..
I just took the 3/4" socket from my set, have the torque set on the cordless drill to release about when it starts to twist out of my grip, and power up and down. We've found the 23FB to be very stable. Easily leveled on uneven pads.
I do raise the entrance (curb) side just a hair past level, as it makes the kitchen sinks drain easier, and keeps my head just a bit higher than my feet when in bed.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 05-16-2017, 08:22 AM   #62
VTSmitty's Avatar
2013 23' FB Flying Cloud
Jericho , Vermont
We've had our 23FB since the spring of 2014, and absolutely love it. It's the perfect size and layout for us (a couple with a dog and cat), and is comfortable for the 3-4 months we're in it each year for our annual trip around the country. It tows easily, is big enough so we're not cramped, and yet it's small enough to tuck into some pretty tight spots. The 23 was described to us as "the biggest of the small" (largest Airstream with 8 foot width) and "the smallest of the big" (smallest dual axle Airstream), and we like that combination. Our favorite features are the queen bed and the full bathroom; least favorite is the ground clearance, but we've done what we can about that. We looked into the Dexter lift kit, but were concerned about about potential misalignment issues and opted to upgrade to 15" wheels/tires and change out the axles for 32 degree torsion arm models instead. That gave us a couple of extra inches, which seems to be enough. The mods we've made so far are:
  1. Installed 200 watt flexible Go Power solar charging system, including panels & controller
  2. Replaced axles with 3000 lb torsion axles, 10" brakes with 32 degree torsion arms (5 lug)
  3. Replaced original 14" wheels with Sendel T03 15x6 Aluminum Bullet Trailer Wheel 5 Lug, 2150 lb Max Load, TW-106EZSS-60C (trailer-wheels.com)
  4. Replaced original Goodyear Marathon 14" tires with Michelin LTX M/S 2 Radial Tires - 235/75R15 108T
  5. Removed original toilet, installed Nature's Head composting toilet
  6. Added Shurflo 182-200 Pre-Pressurized Accumulator Tank to water system
  7. Modified plumbing to selectively drain kitchen and bathroom sink into the black water tank
  8. Modified the under sink cabinet shelf backs for current & future service access
  9. Replaced dinette cushion foam with Mid Foam Firm (seats) and Mid Foam Medium (backs), with Dacron batting
  10. Replaced original window shades with OceanAir shades
  11. Installed Shurflo 94-591-01 water pump silencing kit
  12. Added SensorPush temperature monitors and WiFi gateway for refrigerator and pet temp monitoring
We tow with a Tundra with ProPride, and while I haven't gotten around to weighing the whole rig yet we travel pretty light so I'm not concerned. I'm planning on getting it on the CAT scales this summer, especially since we're considering adding a Honda eu2000i generator. We do a lot of boondocking, but there are times when the sun just won't shine...
Dan
Dan and Chris (and Lindy and Milo)
2013 Flying Cloud 23FB
2014 Tundra DC 5.7L / ProPride / Tekonsha P3
VTSmitty is offline   Reply With Quote
Old 05-16-2017, 09:52 AM   #63
Troutboy's Avatar
Parker , Colorado
The 23FB forum
Dan (VTsmitty),
Thanks for the post. I was thinking about an accumulator, how does it work for you. Does it make a big difference?
Also, could you provide more details about the plumbing changes you made to allow selective discharge to black tank?
Thx!
Troutboy
Old 05-16-2017, 04:50 PM   #64
VTSmitty's Avatar
Jericho , Vermont
Originally Posted by Troutboy View Post
Dan (VTsmitty),
Thx!
Troutboy,
We added the accumulator in 2015 after we had a problem with a leak at the city water fitting. While the fitting itself had issues, we also found that when using the hot water it pressurizes the water system and makes leaks more likely. The accumulator helps take care of that, and as an added bonus cuts down on the number of times that the water pump kicks in. If you're just using a little bit of water the accumulator will cover the pressure loss, instead of the pump.
As far as the selective discharge, we added valves and piping under the vanity sink (shown) and the kitchen sink so that we could drain into either the black or the grey tank. Since we don't use the black tank anymore (Nature's Head) this option lets us add another 18 gallons to our grey water storage, which helps out when boondocking. We normally drain to the grey tank, but have that extra reserve if needed.
Not sure this beer is right for you, but if you pass through Montana we recommend giving it a try: http://bigskybrew.com/beers/trout-slayer/
Dan
Old 05-16-2017, 05:24 PM   #65
Covington , Washington
Originally Posted by SuperPop View Post
Attachment 284916Attachment 284917we rarely use the dinette for dining, more for chilling out. Most of our eating happens outside on the picnic table.
Hah, we just took our 23FB out on our first runs, and I think your use of the dinette space is great! We may do that before the week is out. ;-)
MetalAria is offline   Reply With Quote
Old 05-16-2017, 05:42 PM   #66
Originally Posted by PKI View Post
Pictures -
Top Left is the beginning of the Million dollar highway - 550 South out of Montrose to Durango - this is just below Ouray where the tight and twisty section starts. Perfect for a 23 rig.
Top Right is HW 50, a much better route than I80 if you are into new routes. If you look way in the distance you can see the wind mills making volts, or maybe not.
Bottom Left is the Ely NV KOA. Sometimes you get surrounded by the SOBs. But we had AS backup in the row behind and another a few spaces to the Right. Everyone had a story. It was a very sociable group. We learned a lot about the Balloon Fiesta that night and the seed was planted.
Bottom Right is Morefield campground in Mesa Verde. The neighbors came to visit on a daily basis. Yes, the people were nice too.
Travel is great. We need to get back out there. Pat
Yay another person towing with an X5!! Our E70 35d has been a great tow rig so far! Diesel torque works great!
Attachment 285706
Old 05-16-2017, 07:15 PM   #67
Troutboy's Avatar
Parker , Colorado
Originally Posted by VTSmitty View Post
Troutboy,
Dan
Thanks Dan!! Good info and I'll try that beer for sure!
Troutboy
Old 05-16-2017, 10:00 PM   #68
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Back to the conversations about the stabilizers... I recently bought a 2010 FB Flying Cloud and the shafts that we attach a drill to for raising and lowering the stabilizers are slightly bent, so make it difficult to use my cordless drill. Is there a way to straighten these out?
Thanks in advance for your thoughts.
Cameron
curnes is offline   Reply With Quote
Old 05-16-2017, 10:23 PM   #69
SuperPop's Avatar
Eagle , Colorado
Enjoy my air streaming friend.
SuperPop is offline   Reply With Quote
Old 05-17-2017, 06:02 AM   #70
NC , SC, GA, FL
Thanks, I'll be in South Carolina for the 4th of July so that will be a good test. My 22FB never had a problem even in the swampy Florida heat.
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 03:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 02:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
