Old 01-23-2018, 11:49 AM   #491
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Frank, where the bars tough to get out even when you raised the jack to the highest setting?
I have found by putting a 6inch block under the jack, I can extend the jack to itís highest setting (while the ball/hitch is still attached) which has allowed me to get the bars off very easily regardless of level or angle of the TV.
Troutboy
Troutboy is offline   Reply With Quote
Old 01-23-2018, 11:56 AM   #492
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Originally Posted by Fbastian View Post
< snip >, it was very difficult to pry one of the sway bars on/off its bracket < snip >
Frank, Are you using the tongue jack to raise the rear of the tow vehicle along with the trailer (still hooked up) to take most of the weight off of the bars before releasing them?
I don't want to seem impertinent, but is wasn't clear to me from your narrative if you were using this common 'trick.'
EDIT: Oops, I just saw Troutboy's comment...
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 01-23-2018, 02:43 PM   #493
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Just picked up the coach. Felt nice to have her back. Looks like we need to resync the camera. Hope that is not a regular deal. Battery held up well with the isolation switch.
It's time to take a new look at storage. All my punts need to be converted to coordinated plays that support the cook. Packaging may well be key. Have to find a place for the new waffle iron and hand mixer too.
Winter is not over, but it's time to start on Spring. Hope to meet you all down the road. Pat
Old 01-23-2018, 03:53 PM   #494
2018 23' Flying Cloud
Jackson , Oh
Originally Posted by Xplore View Post
I tow it with my wife's Mercedes GLE 350. I have an F-150 3.5 on order and will use that once it comes in. No issues with the GLE we just need a truck bed for grills, bikes, etc.
Here is the hitch I am using and have been very happy with it.
https://www.etrailer.com/Weight-Dist...ies/49586.html
Thanks, Xplore
earthdog is offline   Reply With Quote
Old 01-24-2018, 06:54 AM   #495
Fbastian's Avatar
2017 23' International
Danville , Pennsylvania
At first I did try raising the hitch as high as I could but I was concerned that since it has a 3000 pound rating, lifting the backend of the truck too much might break the Jack. Also I would eyeball the bars as I raised the jack and it seemed that the bars raised at the same rate. I guess Iíll try that again - if that works it would be simpler.
Fbastian is offline   Reply With Quote
Old 01-24-2018, 07:37 AM   #496
RFP
RFP's Avatar
Hurst , Texas
At first I did try raising the hitch as high as I could but I was concerned that since it has a 3000 pound rating, < snip >
I had the same thought about the robustness of the tongue jack when lifting the truck and Airstream together, but considering the sheer difficulty of wrestling tension-stressed bars off won out that particular mental skirmish.
Being retired for nearly two decades, I certainly count my pennies differently than I once did, and I don't want to seem be too cavalier about money, but I decided that if the OEM tongue jack isn't up to this particular task, I'll replace it with one that is.
And some stuff
Old 01-25-2018, 06:33 PM   #497
Savoy , Texas
What tire pressure?
We pick up our 23FB tomorrow and are curious what tire pressure you are using in your Goodyear Endurance on your 23FB?
SpinWhite is offline   Reply With Quote
Old 01-25-2018, 07:33 PM   #498
Bartlett , Tennessee
80 psi
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 01-31-2018, 10:40 PM   #499
PKI
PKI's Avatar
FYI - a new 23FB looking for info to improve a coach they very much like and want to keep. See link to thread they started. Pat
http://www.airforums.com/forums/f514...-177197-2.html
Old 02-03-2018, 12:40 PM   #500
2019 25' Flying Cloud
NC , SC, GA, FL
Originally Posted by earthdog View Post
May I ask what your tow vehicle is and what weight distribution hitch you use? If your TV is a pickup, are you able to lower the tailgate without it hitting the jack? Thanks!
Update:
I setup the hitch for my new F-150 today and the tailgate does not clear the jack on my 2018 23FB. I didn't think it would but wanted to report back. Very close, needs another inch or so.
3.5 F-150 + 23FB = A great combo. Love this setup.
Xplore is offline   Reply With Quote
Old 02-03-2018, 01:06 PM   #501
Troutboy's Avatar
Parker , Colorado
Update:
Do you think it will clear if you turn the jack head 90 degrees?
Troutboy
Old 02-03-2018, 02:37 PM   #502
NC , SC, GA, FL
Possibly, it starts to make contact about here
Old 02-03-2018, 05:46 PM   #503
Troutboy's Avatar
Parker , Colorado
Thanks. I havenít hitched up yet with the new f150.
Troutboy
Old 02-03-2018, 09:31 PM   #504
2007 22' International CCD
Installing a new ProPride hitch system will most likely be the most ďoverkill engineering ď way to fix that little issue. Thatís how I solved my interference with the jack motor on ours...
But yeah, see if turning the jack motor 90 degrees will do it. Much less cost...
rmkrum is online now   Reply With Quote
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 03:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 02:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
