Old 01-20-2018, 12:58 PM   #463
2018 23' Flying Cloud
Jackson , Oh
[QUOTE=RFP;2057664]Earthdog! Soul brother!
We were (actually still are) 'Rob and Linda' over on the Casita Forum... I wonder if we crossed paths there.
Rob and Linda - Yes, I certainly do remember your posts on the Casita Forum. Always enjoyed seeing what your latest mod was.
earthdog is offline   Reply With Quote
Old 01-20-2018, 01:22 PM   #464
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Originally Posted by earthdog View Post
Rocinante - Thanks for your reply.
Attached is a pic from a 23FB on the dealer lot. Ignore the Minute Maid can - that was an experiment. This is a 4000# jack. Not sure if rotating it would do the trick. Looks like the tailgate will hit the jack head and jack stem.
Yeah, that's the newer style of jack, of course, on a newer trailer. Doesn't look like that one can be rotated to get more room. Not suggesting you buy a new jack for your new trailer, though this is the type of jack on older trailers, which could be rotated: https://www.barkermfg.com/hi-power-3500.html
Rocinante is our 2014 International Signature 27FB
Old 01-20-2018, 03:54 PM   #465
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Look at the type of topper that replaces the tailgate and gives you a vertical door for access. Do not use extended shank as ball closer to the rear TV axle provides better stability.
Research the available hitches. Investigate the Eaz-Lift, Blue Ox Sway Pro, Reese dual cam, and Propride hitch.
Note that the 23FB has a lower unloaded tongue weight than other coaches, but if you do not manage the front bed storage, weight increases quickly. Only store bulky light weight items under the bed.
Congrats on the new shiny. Going to get you a bunch of smiles. Pat
Old 01-20-2018, 04:18 PM   #466
2017 23' Flying Cloud
Bartlett , Tennessee
Question 1: We used an Andersen weight distribution hitch on the Casita. Our Airstream dealer provides the Equal-i-zer. What WDH are you using on your 23BFB?
Question 2: The tailgate on our 2014 F150 will hit the trailer jack when the Airstream is hitched to the F150, so tailgate will not open fully. Had this issue with the Casita, too, so installed the Jack-E-Up so the jack could be removed when the Casita was hitched to the F150 and tailgate would open fully. What do you do to enable your pickup tailgate to open fully when hitched to your Airstream?
Thanks for your help.
Question 1: Be sure you are getting the Equal-I-Zer. When I was buying my 23FB, the dealer told me they were installing an equalizer (note lower case and lack of hyphens), and I asked to see the box. It was a Fastway E2 hitch. That is a lighter duty less capable hitch. I told him I wanted a Reese Strait-Line hitch with their Dual Cam. It cost extra, but I am happy with it.
Question 2: My tailgate misses the jack by about 1/4", but it misses. That may (or may not) be a problem.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 01-20-2018, 06:00 PM   #467
Jackson , Oh
Thanks for the tip. This is an option I'll keep in mind. Appreciate your reply.
Old 01-20-2018, 06:07 PM   #468
Jackson , Oh
We have a commercial-style ARE cap set up to carry our two Jack Russell Terriers in crates. Would hate to have to replace the cap - maybe they have a door option that might work.
The extended shank was suggested, but I understand that may introduce some sway. Thanks for the tips on the WDH options.
Load distribution is a factor. Like the lower hitch weight of the 23FB, but would be easy to add to that weight.
We are looking forward to March. Need to get some things squared away before then...
Old 01-20-2018, 06:15 PM   #469
Jackson , Oh
Dealer specified Equal-I-Zer brand, but good point.
I see you have basically the same tow vehicle. Might be the Reese hitch gives you the extra room for the tailgate. I may have to wait and see if the Equal-I-Zer will allow lowering.
Thanks to all of you for your responses.
I'm still open for ideas.
Old 01-20-2018, 06:19 PM   #470
2018 25' International
East Northport , New York
With a ProPride hitch, the tailgate on my Tundra opens with no problem.Attachment 302724
James
Biker is offline   Reply With Quote
Old 01-20-2018, 06:24 PM   #471
2007 22' International CCD
Yup. Have one. It’s overkill for the tailgate, but solves other sway issues permanently
Old 01-21-2018, 07:21 AM   #472
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Earth dog, welcome to the forum!
I run the Equalizer with my Tundra, and unfortunately I hit the jack with my tailgate. I don't use a bedcover or topper though, so it hasn't been a problem. I haul motorcycles too often for topper use. I was going to recommend the other, more expensive hitches (Hensley) but that would be a pretty costly solution.
You'll love the 23FB.
Question.. They are putting 15" tires on the 23s now. I imagine they are the Goodyear Endurance tires. Do you know if they are D or E rated? I'm in the process of going from 14s to 15s..
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 01-21-2018, 07:38 AM   #473
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Earthdog, While the 23FB and the 23D (now 23CB) are of the same genus, they are definitely different species. That said, there is useful cross-pollination by checking out both this fine thread and the "23D" thread (here: http://www.airforums.com/forums/f142...um-166374.html). Great ideas both places... wander over tho the "other place" from time to time... we'd love to see you there.
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 01-21-2018, 09:22 AM   #474
Troutboy's Avatar
Parker , Colorado
Rob, does the tailgate on your F150 clear the jack on the 23D with the equalizer hitch?
Troutboy
Troutboy is offline   Reply With Quote
Old 01-21-2018, 12:12 PM   #475
2019 27' Globetrotter
Salem , Oregon
I have a 2016 F150 with a Equal-i-zer hitch with my 23fb. Yes it does hit. I think I could turn the jack head as it barely hits and if I am exactly straight I can clear it. I usually don't have to get in the back of the truck unless I am stopped for the night so it has not been a big problem for me.
The pro pride and Hensley hitches would not work for me as they hang down and would create a problem backing into my up hill sloping drive way.
Dave
NoResults is offline   Reply With Quote
Old 01-21-2018, 01:48 PM   #476
OldGreyMare
2009 23' FB Flying Cloud
1962 22' Safari
Honolulu , Hawaii
Hey PKI Love your pictures. What are you towing your 23FB with? Thanks
eastendmary is offline   Reply With Quote
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 04:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 03:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-12-2012 12:29 AM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 12:12 PM
