Old 09-07-2019, 09:30 AM   #1499
2019 23' International
Portland , Oregon
It comes on maybe once every few hours. I'll have them check it when I go in for service next month. Failing that I'll need to learn about accumulators.
2019 International Signature 23FB "Cecil"
2005 Yukon XL
Former coach: 2015 Bambi 16 "Beanie"
leedav is offline   Reply With Quote
Old 09-07-2019, 10:02 AM   #1500
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
If you install an accumulator, include an adjustable pressure regulator on the shore supply side. Pat
Old 09-08-2019, 06:14 PM   #1501
1975 29' Ambassador
2019 23' Flying Cloud
Beach Park , Illinois
Rear camera
Rear camera links up and has sound but no picture. Any ideas? It worked in the drive a month ago but it looks like a cloud
51hunter is offline   Reply With Quote
Old 09-08-2019, 07:37 PM   #1502
2017 23' Flying Cloud
Bartlett , Tennessee
Could it be a spider built a web over the camera lens?
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 09-09-2019, 07:15 AM   #1503
1975 29' Ambassador
Yeah I checked that and noticed moisture on the inside of the lens. Maybe it got full of water and I'm sure that wouldn't help
Old 09-09-2019, 03:08 PM   #1504
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
Way back in the posts, I remember seeing a partial hole cut thru the vinyl flooring... where the furnace vent(s) ducts screw to the floor with hole cut "haphazardly" cut... not the full size of the hole thru the plywood.
Mine are like that and the holes would flow maybe 1/3 the air based on the hole cut with razor knife and I am sure this is intentional. I left them that way, because I would just as soon not have heat wasted warming a less than freezing underbelly. My 23 has a furnace that is really not up to the task.
Clint
2018 Ford F150
2013 International Signature 23FB
A married man should forget his mistakes. There's no use in two people remembering the same thing!
Wolfwhistle is offline   Reply With Quote
Old 09-09-2019, 04:31 PM   #1505
Wolfwhistle
HILLIARD , Florida
I had the fridge fans out today and thought I would post a pic of the housing I built for DC/DC converter and digital thermostat and wiring. Only awkward thing is that its Celsius only. I have it set to close at 31c and with the hysteresis set to 5, it turns off at 26c on the dot. That probably should be set to 3. I leave the inside switch on all the time.
It can also provide contact closure when temperature drops to a certain point.
Clint
ID:	351794   Click image for larger version
2018 Ford F150
Old 09-09-2019, 05:19 PM   #1506
1975 29' Ambassador
Well after checking out the forum about cameras it seems water is the big problem. Duh
Old 09-09-2019, 06:49 PM   #1507
1975 29' Ambassador
Clint
Thanks for the pics and layout. I'm going to do mine next spring. Have the parts already. John
Old 09-10-2019, 05:31 AM   #1508
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Why the DC/DC converter? Is this so you can run the fridge off battery while driving, vs propane? Or, is this more accurate temp control? Knock on wood, our fridge has been working great for years.
I agree also on opening the heat vents up to the water tanks. I’m not really planning on camping in sub freezing temps. I don’t mind a little frost, but we will move before we are in hard freezing temps. The furnace seems to do ok for us when we need it. Doesn’t push very much heat into the bath or bedroom, but that’s been ok. The upside is, it’s not draining the batteries as quickly..
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 09-10-2019, 07:22 AM   #1509
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The solution to the factory installed solitary fan in the top vent on our 2015 23D that was a complete waste of time is shown below. The fans come on whenever the Dan Foss freon based compressor in the Vitrifrigo DP150i is running on either 120Vac or 12Vdc.
The photo with one fan is the factory installation when we had the stock Dometic refrigerator. The modification to the three exhaust fans with fully blocked off top vent area forces all the air to come in the bottom vent and bring cooling air flow past the refrigerator. The new fridge with separate freezer is shown after installation.
Name:	23D Fridge Cooling fan new inside view-1.jpg
ID:	351833   Click image for larger version
Name:	23D Fridge Cooling fan new outside view-1.jpg
Name:	23D Fridge Cooling fan original-1.jpg
ID:	351835   Click image for larger version
Name:	23D Vitrifrigo installation.jpg
Old 09-11-2019, 06:48 AM   #1510
Wolfwhistle
HILLIARD , Florida
The temperature control module I picked has a max voltage of 12.5, since I charge at 14.4 to 14.6 (way too high for it) so after reading about failures with it I decided to add this converter to deliver 9v no matter the input voltage. There are other ways to limit to 12v, such as, a zener diode. This was just easier IMO.
I took others advice and fully closed of the top vent exhaust side, so air has to flow thru the fan openings, whether running or not.
Clint
2018 Ford F150
Old 09-11-2019, 06:50 AM   #1511
Wolfwhistle
HILLIARD , Florida
Switz, I would love to get that fridge.
C
2018 Ford F150
Old 09-11-2019, 11:11 AM   #1512
2018 23' Flying Cloud
Missoula , Montana
Bedroom windows closing on lowest setting
After retiring in June then spending seven weeks on the road and just now settling in as the house-husband I've finally had the time to work through about the first forty pages of the 23FB thread. Very helpful.
With that said - if someone has raised this question in the following 68 pages, my apologies. I'll get there eventually.
On our road trip I noticed that the curbside and street side windows in the bedroom of our 2018 23FB, when set on the lowest of the three "open" settings, will close all the way. Very inconvenient when your camping in Montana and want just a little air through the room overnight without having to run the fan. I can find no adjustment and, of course, the other two settings work just fine because they have a little more wiggle room.
Before I go back to the dealer in Salt Lake City (whom I highly recommend) to get a couple of other things fixed before my two year warranty runs out in the spring I thought I'd see if there's an easy fix.
Thanks in advance for any help.
Craig
Missoula
cajohnson is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 03:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 02:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
