Old 10-14-2019, 02:12 PM   #3581
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Looks like the same. Mine kept pulling loose and retighting didn’t help. They just kept working loose. Well I put some toothpick pieces and wood glue and they stayed tight during our last camping trip last weekend to Hocking Hills, Ohio. Today I’m winterizing today as well.
FloydCoVa is offline   Reply With Quote
Old 10-14-2019, 07:12 PM   #3582
Rich W's Avatar
I'm In , Kentucky
Don't forget to close the outside shower taps before you waste 1/3 of your pink stuff. That's the 3rd time I've done that.
In my picture you can see there's a screw loose. I've owned this AS since early 2014 and we never had a screw come out. They seem to hold pretty well. On the other had, our slide out pantry slides out like it's warped, moving from the right side to the left. I've taken it out twice and replaced / tightened screws. That lasts about 6 months, then it moves again. It's the tracks, they keep slipping. I may use glue this next time.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 10-15-2019, 06:43 AM   #3583
FloydCoVa's Avatar
Rich, last year while winterizing I left the front low point drain open and pumped most of a gallon on the driveway!
This is what I did to my pantry, not my idea, added a second slide to the second shelf. So far so good. Rob(RFP) came up with this and his write up is spot on. I’m not very handy with this kind of stuff but I got it done. Check it out.
http://www.airforums.com/forums/f38/...3d-158887.html
Old 10-15-2019, 08:13 AM   #3584
Rich W's Avatar
I'm In , Kentucky
Oh good, it's not just me then. After I discovered I had dumped that antifreeze I closed the spigot, shook my head and realized I hadn't winterized the shower spigot. We don't use the shower much but I always run tap water through it to get rid of the antifreeze. I barely had enough to finish the job. At least now I don't have to store any over the summer.
Rob is definitely a talented individual and comes up with all kinds of improvements. He has some good ideas on stabilizing the pantry slide. I'll save the link and add it to my list of things to do. When I retired I wondered if I'd find enough projects to keep me busy. Then I bought an AS and I've not rested since then.
(Rob's pantry looks to be about twice the width of ours. I think ours is about 6-8" wide, difficult to get into to tighten screws.)
-Rich
Rich & Yvonne
Old 10-16-2019, 06:16 AM   #3585
2018 23' Flying Cloud
St. Petersburg , Florida
Convection Microwave too much power
We have the 2018 with a Couture Convection Microwave that's rated at 1500 watts. For the first year plus, according to our EMS, it pulled about 12 amps when microwaving.
Recently it's pulling 18-19 amps on microwave. That seems impossible.
Any thoughts of how to check this out? I'm concerned it may be dangerous.
DavidaPeter is offline   Reply With Quote
Old 10-16-2019, 07:15 AM   #3586
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
You would need to verify the AMP draw with another meter independent of the rest of the trailer. Your EMS monitors the total AMP draw traveling through the trailer like the charger/converter.
Also AMPS are dependent on VOLTS. (watt=amp X volt)
So with that.
1500watts=18AMPs X ?VOLTS
Using this formula 1500W/18A=83 VOLTS.
So whats your volts to the trailer UNDER LOAD?
If it’s 120 volts. It Means W=18A x 120V. Your microwave is using 2160 watts
Based on the factory numbers your microwave should...1500=A x 120V. Draw. 12.5 AMPS
Best bet is to test the with a independent meter.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 10-16-2019, 07:37 AM   #3587
Rich W's Avatar
I'm In , Kentucky
Originally Posted by richw46 View Post
In the RV section of Lowes I found a replacement. I can use the good parts off of the old drain to keep some of the "chrome" look. The old drain is mostly plastic anyhow, should look good. The bottom part was too long for my AS, the original is a good fit.
https://www.lowes.com/pd/Road-Home-C...Kit/1000458987
The Lowes drain is junk. We never even used the sink and the "chrome" at the bottom of the basin has separated from the drain. I used plumber's putty which may have been the reason, but there was no caution against it. I'm ordering a chrome plated steel one from eTrailer.com.
https://www.etrailer.com/p-PF282010.html
-Rich
Rich & Yvonne
Old 10-16-2019, 08:29 AM   #3588
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yep. I swapped both of mine (bath sink and shower). Found nice heavy chrome plated brass ones.
ID:	354347   Click image for larger version
Old 10-16-2019, 08:47 AM   #3589
FloydCoVa's Avatar
While winterizing the trailer and rereading the manual I ran across this. Could RV antifreeze be causing this?
Old 10-16-2019, 12:02 PM   #3590
Rich W's Avatar
I'm In , Kentucky
For me, I left a hand soap dispenser in the sink and it leaked. It sat there all winter before I noticed the soap had corroded the stopper and drain. It was chrome plated steel and I got a replacement at Lowes that was plastic. We never used the sink and when I winterized I noticed the "chrome" drain was moving. It had separated from the rest of the drain. I'm getting a chrome plated steel one from eTrailer, looks like the original.
The original had never corroded from antifreeze, I always wipe up any spills. I'm guessing the plumber's putty I used for the seal dissolved the plastic.
-Rich
Rich & Yvonne
Old 10-20-2019, 07:32 PM   #3591
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Accessing more space
I have the trailer demoed again...... re working my solar install and adding Rivnuts as I go. I also have relocated some wires and cut an access panel in the lounge seat so that maybe in the future I will not have to remove it again.
I also ran two new 12volt circuits, one for a 12 volt plug behind the Front TV and the other to the front spare tire area for running some future planned under glow lighting. Here’s a few pics.
ID:	354640   Click image for larger version
ID:	354642   Click image for larger version
ID:	354644   Click image for larger version
ID:	354646   Click image for larger version
Old 10-21-2019, 03:22 PM   #3592
Meriwether's Avatar
2017 23' International
Oregon City , Oregon
Added Refrigerator Ventilation
Like many here, we were experiencing a great deal of heat build up in the exterior refrigerator compartment. This was transferring to the street side wardrobe. To help isolate the heat I started by adding insulation around the rear of the refrigerator.
Then I followed Rob's lead with the Masscool 140MM Fans, but wanted to mount them in a way so that they would not be in the way if the compartment needed to be accessed. These fans are so quiet you have to be right next to the compartment (outside) to hear them running.
I used some 1/16" thick C-Channel and Angled aluminum to make a frame to mount the fans, and then riveted the frame to some .025" thick aluminum sheet.
The sheet fits right inside the access door, tucked under the pop rivets at the top and secured to the latch with an extra latch nut, at the bottom. I also put some Velcro strips on the door to help hold things in place. When the door is closed the aluminum sheet actually gets sandwiched between the door and the inner moulding.
I installed this setup in the Spring and we've travelled some very rough roads since then and it's working out very well. I also believe our refrigerator is holding temperature better.
Name:	Fan_Frame 2018-11-06.jpg
ID:	354715   Click image for larger version
Name:	Fan_Frame2 2019-06-14.jpg
Name:	Fan_Frame3 2019-06-14.jpg
ID:	354717   Click image for larger version
Name:	Fan_Frame4 2019-06-14.jpg
Keith
2017 23D International Serenity
2014 1500 Silverado 5.3L
Meriwether is offline   Reply With Quote
Old 10-21-2019, 03:29 PM   #3593
RFP
RFP's Avatar
Hurst , Texas
Originally Posted by Meriwether View Post
< snip >
Well, dang, that's just gorgeous. I want to do that!
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 10-22-2019, 07:35 AM   #3594
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
M, can you tell me more about the latch at the bottom, please.
I love the craftsmanship and design. My 2-200mm fans block access and I need to make it better, so thanks for the motivation! Mine works great using a thermostat with inside switch, as well as insulating around the fridge also has made a difference. I actually looked (initially) at placing fans on the back of the louvered cover, but didn't think about mounting them onto a plate. What I did notice is that the fans being that close to the louvers, the air volume was reduced somewhat, air flow wasn't clean. Probably not enough to make much of a difference. I noticed you do have some spacing. I was thinking a shallow box.
The other issue I noticed is a better way to prop up that lid when needing access. Like a very light duty hatch lift??
Thanks for sharing,
Clint
Is taking it all with you, really getting away from it all?
Fair_Enough is offline   Reply With Quote
Old 10-23-2019, 01:17 PM   #3595
Meriwether's Avatar
[QUOTE=Wolfwhistle;2300653]M, can you tell me more about the latch at the bottom, please.
Hi Clint,
Originally I wasn't going to attach the fan assembly to the latch, but after some consideration I realized that anchoring to the latch would be a good thing.
From the inside door measurements I made a template for the aluminum plate. Once the template was cutout I removed the door latch, positioned the template inside the door and marked the location of the door latch hole.
From the template I transferred the outline to the aluminum sheet, and made a notch around the door latch. My notch is roughly 1" wide x 2" high.
I used a Dremel tool with a small cutoff wheel to cutout the aluminum sheet, including the opening for the fans.
The aluminum piece that anchors to the latch is 1/16" thick x 1.5" x 2.0".
Making a separate piece from thicker material is easier and offers more rigidity than putting the latch hole right in the aluminum sheet. I actually made the latch hole to match the latch; 3/4" Diameter with 5/8" wide flats.
If you make a mistake, which I often do, no big deal, throw the small piece away and start over.
Having a separate piece also allows you to position the latch opening on the sheet so that the top edge of the sheet tucks under the pop rivets at the top of the door.
Once the two pieces were positioned I clamped them together and drilled and riveted them together.
I added Velcro strips and an extra nut on the door latch to hold the assembly in place.
Hope this helps.
Name:	Fan_Frame8 2018-11-13.jpg
ID:	354824   Click image for larger version
Name:	Fan_Frame9 2018-11-13.jpg
Name:	Fan_Frame7 2018-11-13.jpg
ID:	354826   Click image for larger version
Keith
Old 10-23-2019, 07:21 PM   #3596
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Y’all think Halloween is Scary! That’s nothing compared to this......
don’t look if you have a weak stomach
ID:	354838   Click image for larger version
ID:	354840   Click image for larger version
ID:	354842   Click image for larger version
Old 10-26-2019, 06:49 AM   #3597
Wolfwhistle
Thanks a bunch.
Clint
Old 10-26-2019, 08:17 AM   #3598
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
[QUOTE=Meriwether;2301167]
Hi Clint,
Hope this helps.
Very, NICE WORK, Keith
Old 10-29-2019, 08:20 AM   #3599
CAB & DAB
dbdreams's Avatar
2019 19' Flying Cloud
Brenham , Texas
rock docking
Just got back from a trip to visit youngest son near LA. Talked him into meeting us at Big Bear.
Stopped at Joshua Tree NP for 3 nights of boon, er Rock docking, had a great time there. This was our first real boon docking experience and it went well. The Champion 3400 dual fuel genny ran the AC fine for the short time you can run a generator there, the factory solar kept the batteries toped off better than I thought they would. the only hitch that we have is running a cpap with what we had using the inverter was a heavy drain. Ordered a dc power supply when we got back and will add a 12v dc outlet near the bed. Any others running cpaps have other ideas?
dbdreams is offline   Reply With Quote
Old 10-29-2019, 08:25 AM   #3600
CAB & DAB
dbdreams's Avatar
Brenham , Texas
Couple of other shots from our trip,
Stops at Gilbert Ray near Tucson, Painted Desert, Davis Mountains in west Texas
ID:	355222   Click image for larger version
23d
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Hoonanea
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
