Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 12-08-2018, 10:08 PM   #2901
Leilanisteve's Avatar
2015 19' International
Boise , Idaho
Originally Posted by FloydCoVa View Post
Just put my 23d away for the winter in my new pole barn. The concrete was poured three weeks ago. I had it built as I didn't or couldn't get the trusses set or pour the concrete. I will finish it next year. I'm thinking putting 1x8x12' boards on three sides then put a shed roof out each side. Any way now our Airstream is protected from the sun and most snow and ice this winter.
Attachment 329291
Envious
Leilanisteve is offline   Reply With Quote
Old 12-09-2018, 12:28 AM   #2902
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Originally Posted by GMFL View Post
Scott,
You getting any snow yet?
Yes I’m at work near Bluefield WV. It started at about 1:00am here. Just talked to my wife and she said our deck is covered already.
FloydCoVa is offline   Reply With Quote
Old 12-09-2018, 07:22 AM   #2903
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Scott, stay warm, and that is a really nice pole barn!
Troutboy
Troutboy is offline   Reply With Quote
Old 12-09-2018, 01:20 PM   #2904
FloydCoVa's Avatar
Here a pick of wife's car in driveway at noon. Still snowing....
Old 12-09-2018, 01:40 PM   #2905
FloydCoVa's Avatar
Leilanisteve and Troutboy, thanks. This pole barn is mainly for the airstream and tv, but I have other equipment to store in it. It's 36x24. Not sure how far I'll take it, maybe fully enclose and turn it into a shop? If I put shed roofs on sides that would give me extra room for utility trailer and tractor to free up the main part for a shop with the airstream inside.
Scott
Old 12-09-2018, 01:48 PM   #2906
FloydCoVa's Avatar
My wife just sent me this pic. Serious snow removal! This is with no wind if it gets up the drifts will be really bad!
Old 12-09-2018, 03:51 PM   #2907
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Wow that a lot of white stuff. Stay warm be safe.
If that happed here there would be no milk, bread, in the stores for a month.
Old 12-09-2018, 08:04 PM   #2908
Troutboy's Avatar
Parker , Colorado
Finished up the install of the Victron Color GX. It’s pretty cool but mostly eye candy. Also allows remote monitoring and control of the system which is cool.
I installed it on the right vanity wall where the furnace/AC control is. We didn’t want it on wall near TV. I thought this would be easy but neglected to check drawings and ran into a vent pipe. So I had to repair the vent pipe I violated and cut another hole lower to avoid the vent pipe. This created the need to have a “hole cover” and I used some leftover 1/8” aluminum plate.
I’m not too steady with the dremmel tool but it got the job done and with the aluminum trim plate it looks okay.
I ran the 4 wires down the gap between the vanity wall and closet wall, then over the wheel well to all of my system components.
Pictures below.
Troutboy
Old 12-09-2018, 08:27 PM   #2909
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
That looks great! Good recovery.
I’m not sure why they brought that vent pipe over at early in the rise. Seems like it could have went up and chased closer to the wall and ceiling.
Does the monitor control everything including your inverter?
Old 12-09-2018, 09:15 PM   #2910
2008 23' International CCD
Pinson , Alabama
Nice!!!
RosiesGuy1 is offline   Reply With Quote
Old 12-09-2018, 10:08 PM   #2911
Pinson , Alabama
Hinges keep breaking !
Originally Posted by RosiesGuy1 View Post
Nice!!!
We've a 2008 23D which we purchased new. I recently changed to Goodyear Endurance Tires, running at the 65lbs max allowed. Since replacing with new tires the hinges on the curved doors under the sink have started breaking during travels. I now have replaced all four of the hinge bases. I've had to remove the sink each time replacing the top hinges due to limited space.
Has anyone else been having this problem? Am I running to much pressure in the tires?
Old 12-10-2018, 05:42 AM   #2912
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
I have the 23FB so I couldn’t have the same problem. But if I were to WAG it, I would say too hard tires is the issue. My AS would have had C rated, a 50 psi max tires from JC. Now D rated 14” Endrance shoes. Even at 50 psi they are well under capacity but wanting to possible gain some fuel economy I went up to 60 psi. I am experiencing a left to right push pull and have tried possible solutuons. So yesterday, traveling back from a WBCCI local gathering, I dropped pressure to 55 and it tows better. Next time I’ll drop it to 50 and see what that does. If I were you I would drop the pressure to as low as 50 and see if things stop breaking. Clint
Fair_Enough is offline   Reply With Quote
Old 12-10-2018, 06:26 AM   #2913
RFP
RFP's Avatar
Hurst , Texas
We've a 2008 23D which we purchased new. I recently changed to Goodyear Endurance Tires, running at the 65lbs max allowed. Since replacing with new tires the hinges on the curved doors under the sink have started breaking during travels. < snip >
Can you describe how (where) the hinges are breaking, or better yet, show us a photo of a broken hinge?
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 12-10-2018, 06:58 AM   #2914
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I’m with everybody else. Sounds like tire pressure to high. I’m running 43-45 psi in my Michelin’s and trailers floating on air.
Like Rob said pictures always help.
Old 12-10-2018, 07:02 AM   #2915
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Celebrity News
Robs Famous across all models.
Old 12-10-2018, 07:50 AM   #2916
Troutboy's Avatar
Parker , Colorado
Thanks Ronnie. Not what I wanted but it looks okay.
I’m not sure in the control of the multi yet. It seems that I still control it from the remote inverter panel and the CGX monitors and once on can control.
Troutboy
Old 12-10-2018, 08:04 AM   #2917
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Endurance Tire inflation
Wolfwhistle,
You may want to weigh your trailer and use the following as your guide. Should take out the guess work and you can find the level that best suits your load.
https://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'18 F150 Lariat maxtow --- Liz
tinbender is offline   Reply With Quote
Old 12-10-2018, 03:24 PM   #2918
Joannadannna's Avatar
2018 23' Flying Cloud
Dungville next to Donkeytown , Alabama
Originally Posted by dbdreams View Post
Ronnie,
Sorry for the late response, still cannot post from my phone. The delivery went pretty well, the trailer was mostly ready and paperwork only took a few minutes. We had them work a couple of issues while we watched but of course found a few more after living in her a few days. One that I need to work is the wiring behind the fridge, it is just hung over the expansion tubes between the fan and the switch under the TV, will not last long that way! I then noticed a couple of cut tie wraps and open connectors ~ and no thermostat, looks like the dealer may have robed it for another unit and forgot to replace it!
We do like the new door to the bathroom (mostly) as it gives more room in the bath and by the sink along the bed making the bed easyer to make up and get in and out of.
Will start a few upgrades and mods in the next few weeks as time allows working around Christmas,
Good day to all !
David and Carole
Curious what the bathroom mod ran you. I’ve been thinking of removing the door entirely and replacing with something which affords more room.
~Joanna
You had me down as a damsel?
Darling, I'm the wolf.
Joannadannna is offline   Reply With Quote
Old 12-10-2018, 04:37 PM   #2919
RFP
RFP's Avatar
Hurst , Texas
< snip >
Rich,
I'm sure you still have an 'ample' supply of the laminate. If you will send an appropriate size piece, I'll make you a 'proper' wallplate.
And some stuff
Old 12-10-2018, 04:57 PM   #2920
FloydCoVa's Avatar
Originally Posted by RFP View Post
Rich,
RFP , That's just awesom! That's why this forum,this thread is the best.
Scott
23d
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
