10-10-2018, 11:47 AM
#2481
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Rich,
Here’s my thoughts on that.
“If” Airstream was smart enough and had the fore thought to calculate CFM needs of the gray tank area and “If” Airstream were to implement that calculation into their design, I do not think they would use the vinyl floor with a rough cut razor knife stab as a regulating baffle. I could be wrong though.......
The duct is 2” and the hole cut in the floor is 2”.......
Also when I changed out my freshwater tank the 2”duct for that tank was wide open (see photo)
There is no return air vent from the gray tank area so once the pan is “pressured”. Only the air leaking out of the pan will create the CFM exchange rate.( Which will not be a lot) The back pressure created by this should prevent a drop in flow to other vents.
By opening up the vent hole I am allowing the best chance for heated air to enter around the tank.
This is just another botched job by you know who......
10-10-2018, 07:04 PM
#2482
Overkill Specialist
Dadeville
, Alabama
Photo of under the bathroom sink.
Here’s a pic of the bathroom sink guts. Vanity removed.
10-10-2018, 10:14 PM
#2483
2017 23' Flying Cloud
Parker
Thanks for sharing this Ronnie. How did you notice the leak?
Troutboy
10-11-2018, 01:12 AM
#2484
2013 25' FB Flying Cloud
Longmont
While you are in there it is not a bad idea to snug the four Phillips screws on the back of the city water inlet. If they are loose you can get a leak when the water pressure gets high.
10-11-2018, 04:56 AM
#2485
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
I wonder if AS scientifically placed a given number of openings in strategic places to get just the right amount of air around that freshwater tank. I’m sure they computer modeled it with an air/fluid dynamics program.
Not sure when I’ll get to all my duct work, but I now know it can be better.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
10-11-2018, 05:42 AM
#2486
Overkill Specialist
Dadeville
, Alabama
Last trip out I had a small drip from the back of the street side wheel well. Looked under vanity and was able to feel the insulation wat wet around the city water hook up. I tighten it on site but after returning home I decided to open the can of worms and remove the vanity for closer insection and so I could get a fan in there to make sure all was dry.
10-11-2018, 05:43 AM
#2487
Overkill Specialist
Dadeville
, Alabama
Thanks for the heads up. I did that also. I was able to get an 1/8 turn on them without risk of over torquing.
10-11-2018, 07:14 AM
#2488
2001 16' Bambi
2013 23' International
Piedmont Region
, North Carolina
First problem ever with my trailer was leak on city water inlet. Tightened it and all was good. Hard part was seeing anything, so I decided to make a see-thru access panel that would allow me to easily check on all that plumbing when I wanted to. Removed the wooden back piece of the vanity top shelf and put a piece of 1/8" plexiglass in it's place. Clear view of all without taking anything out.
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'18 F150 Lariat maxtow --- Liz
10-11-2018, 07:15 AM
#2489
2001 16' Bambi
Piedmont Region
, North Carolina
No idea why photo posted twice......
10-11-2018, 08:10 AM
#2490
2015 23' Flying Cloud
Copper Hill
, Virginia
I picked these up yesterday...
10-11-2018, 08:19 AM
#2491
Overkill Specialist
Dadeville
, Alabama
Originally Posted by FloydCoVa
Scott,
That’s AWESOME!!!! And FUN!!!
10-11-2018, 08:43 AM
#2492
Parker
Originally Posted by tinbender
First problem ever with my trailer was leak on city water inlet. Tightened it and all was good. Hard part was seeing anything, so I decided to make a see-thru access panel that would allow me to easily check on all that plumbing when I wanted to. Removed the wooden back piece of the vanity top shelf and put a piece of 1/8" plexiglass in it's place. Clear view of all without taking anything out. Attachment 324953
Great idea!
Troutboy
10-11-2018, 11:44 AM
#2493
Overkill Specialist
Dadeville
, Alabama
Thanks for the great idea I just happened to have a piece Lexan in the shop and before I put the vanity back in I swapped the cabinet backer like you showed to allow visual inspection of the plumbing. You guys gotta tell people when you have a great way to improve a design or make something easier to use. Don’t be shy. The 23D thread is rapidly becoming an encyclopedia of great ideas.
Here’s a few pics of what I did. Also you can note the gray tank heating duct with the vanity back in place.
10-11-2018, 04:36 PM
#2494
Wolfwhistle
Margaritaville
, Banana Republic
Excellent idea. I'm thinking where I could use this in a 23FB. Remember my vanity is in the back of the trailer... I looked down there today with a endoscope. Found a charger and a plastic bag. I am trying to plan how to bring the cable for a wired backup camera up behind the shower, into the vanity then drill to the outside close to the license tag. I would still have to run it on the surface of the belly pan from the tongue. I got cables, umbilical cord and camera today.
I also got a replacement rubber radio antenna tip. Like others report it looks to have simply fallen apart. I ordered one, but AutoZone has these.
WW
Is taking it all with you, really getting away from it all?
10-12-2018, 09:53 AM
#2495
Hurst
Originally Posted by Wolfwhistle
< snip >
WW
Ooooooo... I need one of these, too, and, there's an AutoZone only about a mile away.
10-12-2018, 09:58 AM
#2496
Hurst
Originally Posted by GMFL
< snip >
Airstream had some kinda female to female pex adaptor in-line with the sink water hook up. I’m going to swap out for a crimped pex female connector straight to the pex supply line and do away with Airstreams gizmo. Also noticed Airstream did a not so wonderful job of crimping the male connectors. < snip >
This is bizarre. Mine has no goofy 'adapters' at all. Did you ever come up with a theory as to 'why' those things were there?
Also, I suppose that I've looked closely at every PEX crimp that is visible above the floor... all look very good with uniform spacing and secure crimps. The unit-to-unit variations among these trailers is astounding.
Oh, my gray tank duct had the exact same irregular, small hole through the vinyl floor covering. I'm positive that Airstream is doing this on purpose.
10-12-2018, 10:05 AM
#2497
Hurst
While I'm busying myself running a HDMI cable from the front television to the TV back in The Queen's Chambers, I've got the microwave out. I've taken the opportunity to photograph the "hardened" mounting for the microwave. Those 3/4" plywood triangles are epoxied inside he opening and there are Tee-nuts for secure mounting. Machine screws hold the microwave securely... I'll not be finding this sucker on the floor!
Of course, while I'm waiting for Amazon to drop by with my new HDMI cable, I did some "hardening" of the front television mounting (gee, I love tee-nuts!)
10-12-2018, 10:11 AM
#2498
2018 23' Flying Cloud
Dungville next to Donkeytown
, Alabama
Alright you guys are seriously on some sort of AS’roids. I say this with all due respect and admiration. The ingenuity and labor to do some of these outstanding mods is commendable and yet rather intimidating for those, like myself, who lack the skill set.
This question goes out to all of you overachievers and tinker-meisters - if you had to choose 2 ‘can’t live without’ upgrades on your 23D (cb) what would they be and why?
Perhaps narrowing down to a couple projects and contracting out might be useful info for us that don’t have aluminum thumbs.
~Joanna
You had me down as a damsel?
Darling, I'm the wolf.
10-12-2018, 03:49 PM
#2499
Overkill Specialist
Dadeville
, Alabama
Hmmmmmm just Two????.............
#1. Robs slideout pantry extra counter top MOD
#2. 3” Lift with 15” Michelin tire upgrade and Dill TPMS. ( see what I did, I got three in one)
10-12-2018, 03:52 PM
#2500
Overkill Specialist
Dadeville
, Alabama
<snip> This is bizarre. Mine has no goofy 'adapters' at all. Did you ever come up with a theory as to 'why' those things were there? <snip>
Only thing I can figure is the trailer PEX was Male and the faucet ends were male so they had to come up with an “easy” fix.
