05-07-2017, 10:08 PM
#101
2017 23' Flying Cloud
Parker
GMFL, what year is yours. There were two wires over there that would work for an inverter on mine. But mine is a 2017.
I would removed the sea level and poke around, might be one there. Also, look at the rats nest area and see if you can see any unattached RJ45 cables, if so then you have some presides. If yours is a newer model I can send some photos..
Troutboy
05-07-2017, 10:11 PM
#102
Parker
Originally Posted by dbdreams
Troutboy,
I did a quick and dirty burn test, took about 3 minutes to get to the flame stage two inches above a propane flame, at about 250f in an outdoor oven the adhesive started getting soft (took it up in 25 degree increments from 150 to 300) so I feet safe at 175, if it gets much hotter in there than that I have a real problem! I am going to look for a better material to put on the upper surface, closest to the heat source. When I called Frost King they would only say it was intended to be used on heater ducts, up to about 150f, I may call them again. I am planning on a small exhast fan blowing out the upper part of the top door before summer.
DBDreams,
Good to know, sounds safe. Thanks for sharing.
We just took ours out for the maiden voyage this last weekend. Temps in the day, high 70s, fridge stayed cool, way cool. I was worried the entire fridge was going to be a freezer. I had to keep moving that white control bar down.
Also, no heat build up, no odors/fumes, and everyone slept well as the noise was hardly noticeable. We left the fans on 24/7 the entire trip.
Rich
Troutboy
05-08-2017, 08:37 AM
#103
2016 23' Flying Cloud
New bern
, North Carolina
23d tank capacities
Our 23d has the new tank level sensor and for one i like to know how much fluid each tank really holds and just how much is in it as a planing tool.
Here are my figures for the tanks.
Black 6 gal-0% Fresh 5 - 0% Grey 2- 13%
8 -19% 10- 19% 4- 38%
10 -38% 15- 38% 6- 44%
12 -75% 20- 56% 8- 80%
14 -94% 25- 75% 10- 69%
16 -100% 30- 100% 12- 75%
18 - full 35- 100% 14- 81%
39- full 16- 88%
18- 94%
20- 100%
Note* tank
4
more gal to fill
05-08-2017, 09:26 AM
#104
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Inverter install. Look what I found!
Well I took Troutboy's advice and did a little digging and my inverter install just got a whole lot easier. Look what I found.
05-08-2017, 09:32 AM
#105
Overkill Specialist
Dadeville
, Alabama
Mine is a 2014. Here is The wire on the schematics so it was a pre-run inside the wiring harness my trailer just did not come with the inverter option.
05-08-2017, 10:36 AM
#106
I'm In
, Kentucky
Originally Posted by Boog
Hey Rich and WaLee, it looks like you have 1 of 20 made in that original model. Here's a post from another thread:
Thanks, Boog, very interesting. Personally, I hate the L-couch but the wife likes it. I guess I'd rather have it than the booth. I've heard it's very uncomfortable for watching TV or even just sitting for a long time. If she'd let me I'd take out the L-Couch an put in a recliner with a storage box next to it.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
05-08-2017, 03:23 PM
#107
Nevada City
We like the layout a lot. My wife has taken over the "
05-08-2017, 03:25 PM
#108
Nevada City
"L" portion. So i picked up a folding ottoman- like a camp chair to out my feet up on. We use TV tables to eat inside on. Otherwise we eat outside on the camp table. We also have a Rollup aluminum table to use where there is no camp table.
05-08-2017, 04:25 PM
#109
Hurst
Oh, excellent! I've got to dig into mine and see if the wiring harness is there as it is in yours. Is the first photo of the plug under the table at the front of the trailer?
05-08-2017, 07:25 PM
#110
Overkill Specialist
Dadeville
, Alabama
Rob, First pic is plug in galley and second is under street side lounge up close to where the 12 volt comes in. There is also an Ethernet cable in there that is marked solar control.
05-08-2017, 07:30 PM
#111
Overkill Specialist
Dadeville
, Alabama
http://www.airforums.com/forums/atta...7&d=1494202138
Dbdream posted this pic showing the stock inverter switch above the galley plug right where the wire is located. I am going the hook everything up and test before I cut a hole in my galley wall for the inverter switch
I'll keep you posted
05-08-2017, 07:35 PM
#112
Overkill Specialist
Dadeville
, Alabama
Rob!!!!
Holy Cow...........
LOVE "The Black Swan"
I had no idea you where such a Playboy!
05-08-2017, 08:37 PM
#113
Hurst
Rob!!!!
Holy Cow...........
Thanks, Ronnie, for your kind compliments. This car is actually a part of our retirement plan... it is number 40 of only 62 ever made. It is one of fifteen verified examples listed on the German Porsche M491 registry. That's 30 year old paint, and the entire car looks like it was built this morning. I have entered it in 8 shows and wound up with six "best in class," and two "best in show." Two of these "shows" were Porsche Club of America events... and that's a whole different level of crazy (I can say that since I've been a part of it for over 40 years). I love this thing.
Thanks again!
Rob
05-08-2017, 10:27 PM
#114
Parker
Ronnie,
Nice work! Also, good idea on the wires, I did the same. Make sure they work before cutting.
Troutboy
05-09-2017, 09:48 AM
#115
New bern
, North Carolina
23d Tank capacities
I am a new poster so bear with me. I posted yesterday about the tank sizes on our 23d. My biggest concern has been the size of the Grey tank. Our 2016 model has the newer tank monitor system. So I could better manage while boondocking it helped me to know what the monitor % meant as far as gallons in each tank. My first post was garbled so i will try again now. your numbers should be similar depending on the factory placing the sensing tape on the tanks in the same places.
Grey Water has a listed capacity of 21 gal. I found that I could easily put 25 gal in this tank before it was really full. The guage readings follow
Grey gallons in tank/% shown on guage
2gal=13% 4gal=38% 6gal=44% 8gal=50% 10gal=69% 12gal=75% 14gal=81% 16gal=88% 18gal=94% 20gal=100% I was able to add 5 more gal before tank was full
Our black tank had the following readings
2gal=0% 4gal=0% 6gal=0% 8gal=19% 10gal=38% 12gal=75% 14gal=94% 16gal=100% 18gal=full
Fresh water had the following readings
5gal=0% 10gal=19% 15gal=38% 20gal=56% 25gal=75% 30gal=100% 35gal=100% 39gal=full
I keep a small card in a drawer so i can determine what i really have in my tanks and find it to helpful. I hope this post is a little more inteligable. Im still learning how to post on the forum
05-09-2017, 09:52 AM
#116
Hurst
Originally Posted by Mariah
<<< snip >>> I'm still learning how to post on the forum
Well, actually you are doing great... and welcome to the group. The participants in this thread are really nice folks; smart and helpful, too. With the level of detail you have presented, it's a sure thing that you will be a valued contributor!
Rob
05-09-2017, 10:05 AM
#117
Hurst
Improving the curtains
So, to further prove that I've got more time than creativity, I set out to "improve the factory curtains" to make them hang better.
From Home depot, I purchased several little "driveway markers" (see photo) which are a 1'4" fiberglass rod with a two-sided reflector on one end. The way the factory curtains are made, a length of the 1'4" rod into the "pocket" on each end of the curtain. This stiffens the edges of the curtains and makes a real improvement in the way they hand. It even gives a bit more of a "handle" to use when opening/closing the curtains. On a couple of the curtains, I had to open up a few stitches to get the rods in, but the stitches were easily replaced. Now the rods can be removed for cleaning and simply reinserted. It's important to remember to round over the ends of the rods to make them smooth... that helps them slide into the curtains and will keep them from "gouging" the fabric when in use.
05-09-2017, 10:06 AM
#118
Parker
Thanks Mariah. Welcome and I agree your post was fine.
Interesting on the grey water being able to add about 5 more as that would be close to 25, versus the stated 21.
What I like about your post is that you tested the limits to see where it would go.
I like that idea and thinking and hadnt thought about it.
I think it's a great idea and I will plan to do a test on my grey and black.
As I am learning and boondock, I am finding that the grey tank is my limiting factor. So best to get smart about it and "calibrate" the tank.
As you mention, highly unlikely that the measuring tape is installed the same on all units.
Troutboy
05-09-2017, 10:51 AM
#119
"Hey, I know you!"
Chapin
, South Carolina
Re: improving the curtains
That's kinda like collar stays for curtains!
05-09-2017, 11:23 AM
#120
"Hey, I know you!"
Chapin
, South Carolina
hardwired surge protector
I just finished this up and posted it in the Electrical section, here's the link: http://www.airforums.com/forums/f37/...ml#post1947376
and a picture of what's lurking behind your converter.
