03-07-2018, 07:21 AM
#1002
New Hyde Park
, New York
Noisy CB?
Hi. How noisy is the water heater under the CB?
Thanks.
03-07-2018, 07:52 AM
#1003
2012 23' International
Sevierville
, Tennessee
Silent on electric except for the rare occasion when you hear the thermostat click to begin a heating cycle. You notice it more when running on LP but I don’t run mine that way at night. I use electric at night or I just turn it off and then back on (LP for quick recovery) in the morning.
Ho'onanea (Ho Oh Na Nay Uh) -- to pass the time with peace, ease, and pleasure.
03-07-2018, 08:06 AM
#1004
2014 23' International
Hurst
Thanks.
good question... I don't think we've ever heard ours (!)
03-07-2018, 10:03 AM
#1005
New Hyde Park
, New York
No heat rising up to bother your bed?
03-07-2018, 10:11 AM
#1006
Sevierville
, Tennessee
No heat noticed for me.
03-07-2018, 08:18 PM
#1007
Overkill Specialist
2020 30’ Globetrotter
Dadeville
, Alabama
Something FREE will break you?
Well the saying goes something FREE will break you. I got 2 of these renogy 100 watt panels for free so now I gotta come up with a solar controller and a few $$$ other odds and ends and I’ll have a 200 watt solar install.
https://www.renogy.com/renogy-100-wa...e-solar-panel/
03-09-2018, 09:38 AM
#1008
2007 23' Safari SE
Annandale
, New Jersey
Hoping you can take some pics of your work and a write up Ronnie. This project will be next for me.
My biggest hang up is punching a hole in the roof, just doesn't feel right...
Wishing we had the AS at home this past week. Power went out last Friday and just came back. With solar panels we could have boondocked in our driveway quite comfortably.
03-09-2018, 09:44 AM
#1009
2007 23' Safari SE
Annandale
, New Jersey
The water heater burner is basically outside the trailer with a thin cover and vent over it and should not be running at night unless youre using hot water, and if there is a concern, simply turn it off.
The tank is fully insulated and if any minimal heat were to rise, it would dissipate to the open air areas in the rear storage before you would feel it.
03-09-2018, 10:09 AM
#1010
2017 23' Flying Cloud
Parker
I can say that if you leave it on at night, when the water heater fires up, it is LOUD, and can wake people up.
If we are using hot water, we just turn it off when we go to bed, we do the same with the water pump.
Seems to work well. Then we turn it on in the morning .
Troutboy
03-09-2018, 09:10 PM
#1011
Overkill Specialist
Dadeville
, Alabama
I will plan on documenting the process. Planning on using the 10 ga Airstream pre-wire which is located in the hole the front fantastic fan is located in. Hoping to be able to drill hole in the side of the fan housing and gain access inside trailer there and not drilling roof.
03-10-2018, 06:37 AM
#1012
New Hyde Park
, New York
Thank you all for taking the time to share your thoughts, experiences and suggestions in regards to the 23CB water heater.
Does not sound like a negative factor.
03-10-2018, 07:17 AM
#1013
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We installed the Truma AquaGo comfort model water heater in both of our trailers. The is the mid model of three. The base model does not have a freeze proof feature. The top model is designed for a hot water recirculating system like in a house. It would really burn thru a tank of propane in a hurry.
There is a single three position switch (eco - off - comfort) for operation plus we reused the power switch in the bathroom for the original water heater as an inside on-off switch. The comfort mode keeps the pint of water at a higher temperatures the hot water starts moving as hot water. The eco mode adds a few seconds to water flow before reaching temperature. The mode controls the cycling of the burner with eco mode being a lower cycle rate.
The 23D Truma is under the bed and the Classic Truma is under the bathroom vanity sink (both locations were where the original water heaters were installed).
Below is the installation/operation manual for our units. There have been significant upgrades to the control system since we installed ours over two years ago during the summer of 2015.
We do not find the burner noise problematic so usually just leave the unit powered on. We find we use much less propane for the summer living in the trailer full time in the Airstream only RV park in Lakeside, AZ (for 2017 I was in one or the other trailer from 30 April to the 5th of October).
03-10-2018, 08:16 AM
#1014
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
We installed the same Truma a few weeks ago. So far, so good. We do flip it to “eco” mode at night, though, to reduce noise and, hopefully, propane consumption.
03-10-2018, 10:00 AM
#1015
New Hyde Park
, New York
Truma-combi heater/water heater
I just read about the Truma-combi. Heater/water heater unit that is installed in high-end RVs. Anybody seen or have experience with this piece of equipment?
It sounds amazing!
03-10-2018, 10:09 AM
#1016
Sevierville
, Tennessee
Switz — have you ever measured the refrigerator compartment temperature of your Vitrifrigo in your 23D? I’m on my first weekend trip after installing mine and I’m sadly underwhelmed with the performance.
The unit cools quickly — happy with that part — but an indoor/outdoor remote thermometer placed inside the refrigerator compartment shows a minimum temperature of 41 degrees on the middle ventilated shelf and 43 degrees on the bottom shelf with the clear plastic bins removed. Cool air falls to the bottom but the bottom shelf has a solid glass shelf above it which probably impedes the coolest air from reaching this section. The black control knob is set to the “max” position.
I’m really disappointed in this after spending so much money on the refrigerator and the effort to get it installed. I still have the working Dometic absorption refrigerator. Conundrum.
03-10-2018, 09:14 PM
#1017
Parker
Hoonanea, do you have any fans on the rear vent? I think you still need to move the hot air out of the back of the 7nit to get cooler temps.... depends on outside temp etc. sometimes just opening the vents can help as well...
Troutboy
03-11-2018, 09:40 AM
#1018
Sevierville
, Tennessee
I have three computer fans moving air into the bottom vent door and exhausting through the top vent door.
I set the control knob to almost the lowest point and the interior air temperature barely changed. Went from 40/41 on the max setting to 43/44 on the low setting. Seems there should be more variance than this.
03-11-2018, 10:58 AM
#1019
Green Cove Springs
Is there any chance that your Vitrifrigo is low on refrigerant? Is there a way to check?
03-11-2018, 11:40 AM
#1020
Sevierville
, Tennessee
The refrigerator is brand new so that *shouldn’t* be the problem. I think a good indication of low refrigerant is continuous running of the compressor. At the max temperature setting, the cycle-on time was consistent at 16 minutes and cycle-off time was consistent at 25 minutes. If the refrigerant was low, I think the compressor would just keep running.
Keep the thoughts and ideas coming! Just a few minutes ago I sent a detailed email to the vendor where I purchased the refrigerator. I’ll likely hear back from her tomorrow.
