Old 05-03-2017, 04:42 PM   #57
2007 22' International CCD
My 23FB has a GFI outside outlet on the roadside rear corner that loves to get wet and pop the GFI...cheap cover does not seal well.
rmkrum is online now   Reply With Quote
Old 05-03-2017, 04:47 PM   #58
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Originally Posted by dbdreams View Post
Rob,
( snip ) I know something must have gotten wet but I cant find it.
David
David,
I guess that you have already checked the outside 120-volt receptacle for dampness... I'll go out and walk around ours and see if there is anything else [more or less] obvious to check.
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 05-03-2017, 04:54 PM   #59
RFP
RFP's Avatar
Hurst , Texas
OK, David, I think that you probably have more "equipment" than we do, but the only outside 120-volt potential exposure is (1) curb-side receptacle, (2) AC power cord connection, and (3) inside refrigerator compartment. That's about the best I can do from here.
Rob
And some stuff
Old 05-03-2017, 05:32 PM   #60
CAB & DAB
dbdreams's Avatar
2019 19' Flying Cloud
Fayetteville , Texas
Thanks Rob,
The one in the fridg compartment seemed completly dry, the 120 outlets had some mosture, I have had a small heater blowing on them for about an hour, will try a reset after dinner and post what happens, I may just change it out in the morning, the Denver dealer is booked till late June but has been very helpfull on the phone.
Thanks all!
dbdreams is offline   Reply With Quote
Old 05-04-2017, 05:54 AM   #61
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
We have the gap in our front curbside cover. It allows leaves to settle in, as the lower seal seems to hold everything in. I just clean it inside the cover, a couple of times a year. I'm following along even though I have the FB. There's a fair amount in common. (14" tires..)
Hope you find a fix for the gap-itis, and post it here.
Thx
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 05-04-2017, 06:54 AM   #62
2016 23' Flying Cloud
New bern , North Carolina
Front Window Gap
Ours has the same gap. I tried using 1/2 inch foam pipe insulation. The problem is that the gap is not consistant. It is annoying and we are looking for an answer also
Mariah is offline   Reply With Quote
Old 05-04-2017, 06:58 AM   #63
Front Window Shade
We have a 2016 23d and found that the front curtains were a pain to close at night. We ended up installing a shade on the center part of the front wrap around window. It makes it easier to close up at night.
Old 05-04-2017, 08:08 AM   #64
CAB & DAB
dbdreams's Avatar
Gfi
The problem with my GFI turned out to be the outside 120V plug, ran a small heater blowing into it for a few hours and it dryed out. Anyone replaced the factory cover with one that is a bit more waterproof?
One little mod I did was to add some insulation to the wall in the fridge compartment on the aft side, the closet now stays a bit cooler, was getting a lot of heat transfer. Quick and easy and MAY help the A/C in our warm Texas summers!
Old 05-04-2017, 08:48 AM   #65
RFP
RFP's Avatar
Hurst , Texas
Glad you solved the GFI problem.
Can you give us the source of the insulation you used? That's certainly a worthwhile project... the closet was does get toasty.
And some stuff
Old 05-04-2017, 09:21 AM   #66
2017 23' Flying Cloud
Bartlett , Tennessee
I wonder of these outlet covers would help.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 05-04-2017, 09:23 AM   #67
"Hey, I know you!"
Boog's Avatar
2012 23' Flying Cloud
Irmo , South Carolina
Where I'd like to stuff some insulation is at the top, but I may need to pull the fridge to get to it.
Boog is offline   Reply With Quote
Old 05-04-2017, 12:09 PM   #68
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Micro air installed. Easy and works great
Old 05-04-2017, 02:08 PM   #69
CAB & DAB
dbdreams's Avatar
The insulation I used was a frostking product from Home Depot for A/C and heater ducts, it is self adhesive and has seemed to stay put very well for about three months, including some very warm days in south Texas, right now in Colorado so it has seen temps from hi 90s to 17 with no signs of coming loose. I have also put a strip above and am watching it closely as I could not find a true max temp rating for it.
As for the outlet cover I will look at a few sealed covers in a few days when I go to Denver to do some shopping, if it rains before then I will tape it up to keep water out.
Old 05-04-2017, 04:59 PM   #70
Troutboy's Avatar
Parker , Colorado
The main reason I did the fan upgrade i posted above was to eliminate that heat transfer. Now I can't even tell, barely any heat buildup.
The insulation idea is a good one, and I would watch to make sure it can handle the heat.
I had a product I want sure about so I tested it myself. I needed it to withstand 160 degree max. I used my heat gun set at 500. It melted. Turned it down incrementally and used heat o 300 and it withheld. So I knew it was good at 160.
The wrong rates insulation could cause a great danger. I would call the manufacturer and try to track that down or test the limits yourself.
Troutboy
Troutboy is offline   Reply With Quote
23d
« The 23FB forum | Top | - »
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
