Old 08-10-2019, 08:44 AM   #3459
FishByFly's Avatar
2019 22' Sport
Fort Worth , Arkansas
Originally Posted by richw46 View Post
That one looks pretty good.
I'm not sure Airstream understood my question to them. I was asking about the vanity sink and their reply referred to a basket. I'm no plumber but that sounded like the basket for the stopper in the shower. Maybe basket is the official plumbing term.
They said I could contact an Airstream dealership about a replacement or to use a household replacement, as long as the same thread pattern, size and it makes a good seal with the sink. It would probably be better if I just keep searching my parts manual for it. I will post if I find it.
An Airstream Dealership should be able to order a good replacement for that basket. Otherwise, I would imagine that a household replacement would work as long as it has the same thread pattern and size, and you can get a good seal on the sink. -Mike
For my sink replacements, I’ve looked for a bit bigger and higher quality. I used a deep round stainless bar sink on my last trailer. Large enough to soak and washout clothes. Ordered that online. I’ve been successful finding drain line components following the airstream plumbing at big box stores. The two go together just fine.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 08-11-2019, 05:22 PM   #3460
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
So, following our usual get-outta-town protocol on our way from Hurst to Colorado, we drove the 190 miles to Food left, Texas. On arrival, the temperature outside was 107 with a strong southerly wind. Inside the Airstream it was a much more pleasant 106 !
We're waiting for it to cool down in here a bit...
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 08-11-2019, 05:46 PM   #3461
RFP
RFP's Avatar
Hurst , Texas
Oh, it'll probably cool down quicker if I close the two vents... that's so embarrassing, don't tell Linda
And some stuff
Old 08-14-2019, 08:12 PM   #3462
richw46's Avatar
Lexington , Kentucky
Thanks, Fishbyfly. We just got back from our long journey to the left coast and return by northern states. I have lots of things to work on. I'll check locally for the drain and stopper. If no luck there, I'll check the TX dealership recommended by RFP
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-15-2019, 07:16 PM   #3463
richw46's Avatar
Originally Posted by GMFL View Post
I would be interested in the part number if you find it.
In the RV section of Lowes I found a replacement. I can use the good parts off of the old drain to keep some of the "chrome" look. The old drain is mostly plastic anyhow, should look good. The bottom part was too long for my AS, the original is a good fit.
https://www.lowes.com/pd/Road-Home-C...Kit/1000458987
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-19-2019, 08:22 PM   #3464
RFP
RFP's Avatar
Hurst , Texas
If I could do only one 'mod' ...
Greetings from South-central Colorado!
I just realized today, that if I could have done only one mod, it would have to be my redesigned vanity countertop/sink/faucet.
Making a new countertop with a radiused front edge allowed me to move the sink a couple of inches out away from the rear mirrored cabinet. Then a new Moen faucet puts the water right into the sink instead of barely down the back of the sink.
And some stuff
Old 08-19-2019, 08:42 PM   #3465
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Glad you yours made it safely. I love that MOD. It may be in my future.
I just added an LED light strip under the medicine cabinet Saturday morning. I tied it to the bathroom vanity switch for power so it works when that switch is on.
My wife loves it.
Dept of “OverKill”
@Airstream_Nuts_And_Bolts
Old 08-20-2019, 06:40 AM   #3466
RFP
RFP's Avatar
Hurst , Texas
My wife loves it.
Ooooo... I really like that idea, Ronnie. How did you route the wiring? Gotta have photos, of course!
And some stuff
Old 08-20-2019, 08:34 AM   #3467
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here’s a couple of pics. Super easy. I ran the wire between the closet wall and inside skin. “Mine” had about an 18th inch gap so I just “sleeved” the wire in a thick plastic tube to protect it from rubbing and then fished the wire over to the switch. You can work through the hole in the wall to the switch. Only problem I had was working wire around the tank vent that is housed in the wall.
I just used a piece of left over LED Tape for another project.
Only thing I’m no happy with is..... I used a dab of silicone caulk to prevent the wire from shifting around during travel and it was not as neat as I would have liked it...., but you can’t see it unless you are laying on the floor.
ID:	349979   Click image for larger version
Dept of “OverKill”
Old 08-20-2019, 12:11 PM   #3468
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Your attention to detail puts me to shame!
pcskier is offline   Reply With Quote
Old 08-20-2019, 03:06 PM   #3469
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
It’s a curse
Dept of “OverKill”
Old 08-20-2019, 05:12 PM   #3470
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Rob,
You still happy with you seat foam selection?
Dept of “OverKill”
Old 08-20-2019, 05:40 PM   #3471
RFP
RFP's Avatar
Hurst , Texas
Rob,
Super happy... and it sleeps as good as it sits!
And some stuff
Old 08-20-2019, 05:44 PM   #3472
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I’m going to order a full sheet tomorrow and replace all my bottom seat cushions.
Dept of “OverKill”
23d
« The 23FB forum | Top | - »
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
