Old 07-30-2019, 12:53 PM   #3431
2007 22' International CCD
So basically clean it a bit, mask off a bunch of the area to stop overspray, then just spray it.
What brand of paint and color was it?
I’m having the same fade issues on mine as well. The sun out here in the CA desert is tougher than hell on paint.
Old 07-30-2019, 12:56 PM   #3432
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
That’s what I did...
Rust-Oleum. Red Apple
Dept of “OverKill”
Old 07-30-2019, 01:01 PM   #3433
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Originally Posted by GMFL View Post
It’s in the wall behind the thermostat. I’ll do some more digging. I hate the fact there is a fuse that is hidden inside the wall.
I was just wondering if the solar wires go from next to the Fantastic Fan, over to the wall, and down from there? Can't see any other 10a ones on the basic schematic in the manual.
Whatever it's for, it could drive someone insane if it blew and nobody knew it was back there.
pcskier is offline   Reply With Quote
Old 07-30-2019, 01:05 PM   #3434
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
BINGO! Driving me insane and it’s not blown. Hidden Fuses are not nice.
Dept of “OverKill”
Old 07-30-2019, 07:34 PM   #3435
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here is the blog post on the Waterheater switch LED MOD.
Clear as MUD
http://www.airforums.com/forums/blog...or-led-s-3054/
Dept of “OverKill”
Old 07-30-2019, 09:48 PM   #3436
Makes perfect sense** to this Overkill Engineering expert.
Basically is purchase and install a 12 volt LED (color of your choice) and wire it to the output of the switch. Other end of LED goes to a ground. Polarity matters, of course.
**yeah, assuming you have a degree in electronics and are a Ham Radio operator as well....
Old 07-30-2019, 09:51 PM   #3437
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yep that’s about it. Not hard, but it was tedious dealing with that little LED for sure. Fat Fingers and small parts.
Dept of “OverKill”
Old 07-30-2019, 10:27 PM   #3438
The 23D thread
Add in tired old eyes and you have my reality. If I can’t get something into the right part of the progressive lenses in my glasses it can get really weird when I try to get a big magnifying light into the place I’m having trouble crawling into....
Old 07-31-2019, 07:14 AM   #3439
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Fuse in the wall!
While I was installing the LED light for my water heater switches I found a 10amp fuse in the wall. Any idea what it is for. I did not spend the time investigating.
Well because I can’t put a good mystery down, first thing this morning I went to digging and solved my little “Fuse in the wall” question I found yesterday.
Turns out it’s for the rear ceiling light dimmer switch. I also checked the front dimmer and there is a fuse in the wall there also.
MAKE A MENTAL NOTE!
MAKE A MENTAL NOTE!
MAKE A MENTAL NOTE!
Sorry I heard that if you say something three times you have a better chance of remembering. So I thought for good measure I would type it
Note: If you pull this fuse the lights will not come on! So that means if this FUSE is BLOWN GUESS WHAT? The lights will not work.
Please be aware that there is a fuse in the wall behind the dimmer switch and....... If yo lights be not working....
Check this super secret hidden fuse.
In Airstreams defense I do not see any other way they could have laid this out. Fuse had to be close to the switch. Maybe they could have used one of those auto reset busses instead of a standard “blow and throw fuse”, but to be honest I’m not sure how reliable those really are.
As always check out the photos.
Thanks for watching.....
ID:	348110   Click image for larger version
Dept of “OverKill”
Old 07-31-2019, 07:35 AM   #3440
eagletoo's Avatar
2020 23' Globetrotter
Long Island , New York
Ronnie, your perseverance and deductive reasoning is commendable.
Thank you for sharing your gifts.
Bruce
2020 23’ Globetrotter FBT Natural Elm/London Grey
2018 Jeep Overland 5.7L Hemi
Wally Bryan Airstream Club #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 07-31-2019, 08:15 AM   #3441
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Got it... fuse for dimming lights! Once again thanks.
FloydCoVa is offline   Reply With Quote
Old 07-31-2019, 10:34 AM   #3442
pcskier's Avatar
Park City , Utah
[QUOTE=GMFL;2271251]
[/QUOTE
Let's hear from the electrical engineers. Why would you need a 10 amp fuse for 4 LED lights that surely draw less than half that on full power? Plus there is already a fuse on in the 12v section of the power center for the lighting. The dimmer is somehow a factor I guess, requiring this 'double fusing?'
Old 08-01-2019, 07:45 AM   #3443
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Took down a soaked my front curtains in 20 mule borax yesterday. Result was amazing. Curtains came clean as new. They really look GREAT! I had no idea they had gotten that soiled.
Anyway, now that they are spotless I would like to keep them that way. I was thinking about treating them with Scotch-Guard..... before I rehang them.
Any one have any advice?
Dept of “OverKill”
Old 08-01-2019, 07:55 AM   #3444
RFP
RFP's Avatar
Hurst , Texas
[QUOTE=pcskier;2271358]
[/QUOTE
I would bet that the 'hidden fuse' is part of the switch/dimmer/plate assembly that Airstream buys from their supplier. There is no electrical need for it to be there, the circuit is already protected by the fuse in the main panel. Actually, the 'fuse in the panel' is in the preferred place as it provides fused protection for all the wiring between the panel and each fused device. The 'hidden fuse' would only protect the LEDs on the switch/dimmer. A large (20A ~ 30A) fuse could be put into the 'hidden fuse' location without one bit of loss in protection, the panel fuse provides fully-fused protection.
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is online now   Reply With Quote
23d
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
RFP
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
