Old 07-28-2019, 03:21 PM   #3417
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Originally Posted by GMFL View Post
Timken bearing sets (both #4 and #17) and ten seals (#441151) for the 10" brakes system used on the 23D and sold on Amazon
Thanks Ronnie the Set4 and Set17 bearings come up together as that 'purchase together' feature on Amazon, but also these seals: https://www.amazon.com/Timken-473336...A8E0YCK2Q70XVC
pcskier is offline   Reply With Quote
Old 07-28-2019, 05:17 PM   #3418
WaLee's Avatar
Nevada City , California
New Problem seeking a solution. The corner bathroom door has the lever hardware. How about a solution for a door handle that doesn’t grab you coming out of the bathroom. One idea is to buy a deadbolt set and use the interior portion for the lock. Any suggestions
WaLee is offline   Reply With Quote
Old 07-28-2019, 06:33 PM   #3419
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Looks correct.
Dept of “OverKill”
Old 07-29-2019, 09:39 AM   #3420
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here is the seal number (Lou) Switz had. #442251
Dept of “OverKill”
Old 07-29-2019, 10:02 AM   #3421
RFP
RFP's Avatar
Hurst , Texas
Can you post a photo of what you have?
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 07-29-2019, 02:24 PM   #3422
pcskier's Avatar
Park City , Utah
Thanks Ronnie. I'm probably being WAAAAAYYYY too anal about this. The 473336 and 442251 seals are virtually the same...note the minor difference in shaft size (1/1000 of an inch!). And one is a style '440' and one is style '470', whatever that means. I guess either would work but I'm still curious why there are two that are virtually the same?
We appreciate you taking your time to contact us for this matter. As we have checked, the differences between Timken® 473336 - Premium Seal and Timken® 442251 - Premium Seal is the Shaft size and the style. The Timken® 473336 - Premium Seal has Shaft Size: 1.719" and Style: 470 while Timken® 442251 - Premium Seal has Shaft Size: 1.718" and Style: 440.
Old 07-30-2019, 11:11 AM   #3423
richw46's Avatar
Lexington , Kentucky
Getting caught by the belt loop? Happens to me all the time.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 07-30-2019, 11:28 AM   #3424
richw46's Avatar
We are currently on our longest journey ever in Dora after being off the road for a couple of years. We left Lexington, KY last Thursday and are currently in southwest Idaho, heading to near Portland, OR. That's 2,425 miles one way. Got new tires for the AS and the 4Runner before leaving. Nothing major so far (stink bugs in the water heater air vent causing soot on the side). Fingers crossed, we arrive late tomorrow in Wilsonville, OR, ready to start the visit.
We're contemplating a different route on the return trip, just for something different. It's maybe 100-200 miles different if we take one of the two northern routes.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 07-30-2019, 12:23 PM   #3425
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Finally
Finally got around to adding my switch position indicator LED’s to my water heater switches. I’ll do a bigger write up in a blog post but here’s a few photos of the dirty work.
ID:	348020   Click image for larger version
ID:	348022   Click image for larger version
ID:	348026   Click image for larger version
ID:	348028   Click image for larger version
ID:	348031   Click image for larger version
Dept of “OverKill”
Old 07-30-2019, 12:29 PM   #3426
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Fuse in the wall
While I was installing the LED light for my water heater switches I found a 10amp fuse in the wall. Any idea what it is for. I did not spend the time investigating.
ID:	348035   Click image for larger version
Dept of “OverKill”
Old 07-30-2019, 12:39 PM   #3427
eagletoo's Avatar
2020 23' Globetrotter
Long Island , New York
Killer LEDs. Great upgrade. Should be stock. Time to update my mod list - again
Bruce
2020 23’ Globetrotter FBT Natural Elm/London Grey
2018 Jeep Overland 5.7L Hemi
Wally Bryan Airstream Club #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 07-30-2019, 12:45 PM   #3428
pcskier's Avatar
Park City , Utah
The 2014 Manual shows a 10A fuse between optional solar panels and the charge controller, but on yellow wire. Since the prewires start out next to the Fantastic Fan sort of above that area, maybe that's where they put that fuse? I don't recall seeing a fuse in the rat's nest, just the terminated prewires.
Remove fuse and see if you lose solar since you are using the prewire?
Only other 10a I can see in the diagram is between charge controller and a 20a breaker on positive bus, but that wouldn't be all the way in back up in that wall since the charge controller would be under the dinette.
Curious to know if you figure it out...that would be an interesting thing to know in the event of some mystery power outage here or there (if it's not for the solar but for something else.)
Old 07-30-2019, 12:49 PM   #3429
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
One more! The 23FB guys were making a run at it.
Here’s one more I did this morning. My International name badge was starting to show a little fading. The blue was fine but the red was looking more pink than red. A little rattle can red and good as new...
See photos below.
ID:	348038   Click image for larger version
ID:	348040   Click image for larger version
ID:	348042   Click image for larger version
ID:	348044   Click image for larger version
Dept of “OverKill”
Old 07-30-2019, 12:52 PM   #3430
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
The 2014 Manual shows a 10A fuse between optional solar panels and the charge controller, but on yellow wire. Since the prewires start out in that vent near there, maybe that's where they put that fuse? I don't recall seeing a fuse in the rat's nest, just the terminated prewires.
Only other 10a I can see in the diagram is between charge controller and pos bus but that wouldn't be all the way in back up in that wall.
It’s in the wall behind the thermostat. I’ll do some more digging. I hate the fact there is a fuse that is hidden inside the wall.
Dept of “OverKill”
23d
« The 23FB forum | Top | - »
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
