Old 07-10-2019, 04:57 PM   #3375
Meriwether's Avatar
2017 23' International
Oregon City , Oregon
Help! Fresh Water Drain Valve Leaking
Originally Posted by talewis13 View Post
Attachment 345915 Why are there two valves on my fresh water tank and what are the used for? I know the white on on the side is for draining but I am a little confused about the one directly below. Thanks in advance!
We’ve been traveling and just pulled into the KOA at Mt. Rushmore yesterday.
While checking in I noticed water streaming from around the white plastic drain valve on our fresh water tank.
Initially I thought a rock kicked up and broke the valve. After further inspection it appears the valve is not broken and is still functional. I checked the screws that secure the valve to the side of the tank and they are tight.
As near as I can tell, without pulling the tire off, the water is leaking from around the base of the valve.
When we checked in yesterday the tank was 100% full, this morning it’s empty.
We’re on city water at the campsite, but if I can’t fix the leak it will be a major inconvenience for the rest of our trip.
Does anyone know what is or if there is a gasket etc. under the valve base?
Also if I remove the two screws in the valve base, will the base be released from the tank?
Any help or suggestions are greatly appreciated!
Keith
2017 23D International Serenity
2014 1500 Silverado 5.3L
Meriwether is offline   Reply With Quote
Old 07-10-2019, 05:01 PM   #3376
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Originally Posted by Meriwether View Post
< snip >
Ronnie, it's for you !
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 07-10-2019, 05:36 PM   #3377
Meriwether's Avatar
Ronnie,
Here’s what I’m thinking might be a possible solution, and perhaps you would know if this will work;
If I remove the white valve assembly and can find a piece of thin sheet metal large enough to cover the opening, drill two holes in it to make a cover. They have patch kits for rubber rafts at the KOA store that might work as a gasket.
Could something like this seal the tank, or is there an inner plastic tank that I’m dealing with?
Keith
Old 07-10-2019, 05:55 PM   #3378
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Call me 334-332-0003
Old 07-10-2019, 05:55 PM   #3379
2007 22' International CCD
There is an inner plastic tank. The metal is just protecting the plastic tank against road debris damage
rmkrum is online now   Reply With Quote
Old 07-10-2019, 06:23 PM   #3380
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Ronnie,
Keith I sent you a PM. Call me
Dept of “OverKill”
Old 07-10-2019, 08:48 PM   #3381
2018 23' International
Diamond Bar , California
FYI—experts at Bay Area Airstream had the door deadbolt repaired and in good working order less than an hour after I pulled into their service lane! Good people, and they didn’t charge me.
David R. Busse
DRBusse@roadrunner.com
2018 Airstream International 23CB
2018 GMC Sierra 1500 4x4
DRBusse is offline   Reply With Quote
Old 07-10-2019, 09:06 PM   #3382
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I spoke with Keith. I think he will be able to repair his broken water valve on the road.
Dept of “OverKill”
Old 07-11-2019, 05:26 AM   #3383
eagletoo's Avatar
2019 23' International
Long Island , New York
Ronnie, all this advice while standing on a beach?? You are ‘da man - kinda like a guardian angel out there for us!
Enjoy the rest of your mini-vacation.
Bruce
2019 23FB International Serenity
2018 Jeep Overland 5.7L Hemi
Wally Bryan Airstream Club #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 07-11-2019, 06:48 AM   #3384
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Well Bruce,
It could be done from worse places for sure.
Fortunately I’d been there before, so I could help.
Kevin should be able to access the freshwater tank valve from an access plate in the tank cover. Then he will be able to disconnect the white drain valve and place a plug in the flexible hose attached to the tank.
This will at least salvage their trip and he can seek a permanent solution once they have returned home.
Dept of “OverKill”
Old 07-11-2019, 11:41 AM   #3385
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Yeah I'm keeping him on speed dial!
pcskier is offline   Reply With Quote
Old 07-11-2019, 01:41 PM   #3386
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Merit Badge
Meriwether (Keith) just informed me after a few hours of gathering supplies and work that he has repaired he’s water tank and is ready to continue their trip.
He has definitely earned a
“On the road Repair” Merit Badge!
Great Job! Travel safe!
Old 07-11-2019, 04:15 PM   #3387
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Ok I got one for you guys to help/advise me on. We just got back from our third trip this summer today. We went to Twin Falls State Park,West Virginia had a great time even with the high heat and high humidity! Everything worked great! But the first evening I noticed the trim along the left side of bathroom counter top toward the rear there was a 1/4 inch gap. Also along the lower medicine cabinet and the wall the gap was maybe 3/4 inch gap. So I went on commode side and was able to push the wall back in place, Which revealed a loose rivet up high on the curved part of the wall. Then I looked under the counter top,toward the back, and found a L-bracket with the screw pulled out. The drive to the park was a rough two lane road for about 35 miles or so with tons of sharp curves! It’s this something to worry about or replace the screw and keep an eye on it.
FloydCoVa is offline   Reply With Quote
Old 07-11-2019, 04:44 PM   #3388
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Replace the rivet and replace the screw with a # 10 3/4 “ and you should be good the go. Next step up would be to add a Rivnut in the wall and 10-32 machine screw.
You may also want to check the med cabinet as those have a tendency to leap from the wall while traveling.
Dept of “OverKill”
23d
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
