Old 06-23-2019, 05:40 PM   #3333
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
FloydCoVa is offline   Reply With Quote
Old 06-24-2019, 09:36 AM   #3334
2018 23' International
Diamond Bar , California
Battery options.
My 2018 23CB will be two years old this fall. We have the original Interstate batteries, 200 watts of solar on the roof and I’m concerned the batteries are near the end of their useful life.
We do a lot of Boondocking.
Yesterday we were at the beach. We parked about 1130am and had 100 percent showing in the power monitor and 13.2 on the voltage. Plenty of sun, no shade.
So I was quite concerned at dinner time when voltage was down to 10.0, and battery capacity showed 0 percent. Discovered somebody left the radio on, and my grandson turned a light on that was apparently draining the battery for several hours. Just one light...the decorative incandescent light next to the divan.
Service writer at the local AS dealer told me some time ago that I shouldn’t expect battery life of more than a couple years with the as-delivered Interstate batteries.
What would you do at this point? Replace batteries with what?
Dealer wanted to sell me a power upgrade for something like $4k.
Am sure the experts here have better, more cost-effective answers.
Leaving shortly for a couple of big trips, mostly with full hookups.
Thanks in advance.
DB
DRBusse is offline   Reply With Quote
Old 06-24-2019, 11:37 AM   #3335
richw46's Avatar
Lexington , Kentucky
We changed out all of our incandescent bulbs for LEDs; better light, lower battery draw. I would switch from Interstate batteries too. I'd go with Deka, Trojan or Lifelines.
You should be able to swap out the old incandescent bulbs yourself. Replacement LEDs have the same base, just LEDs instead of filaments. Got mine on Amazon.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-24-2019, 12:46 PM   #3336
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Thanks in advance.
DB
At 10 volts your old interstates are toast.
Changing out to twin 6 volt golf cart batteries is the way I went. 225 amp hours almost doubles your current capacity and provides you with a battery that was designed for long term use. (made to charge and discharge).
Your solar will do a descent job maintaining them and cost will be on your side as 6 volt golf cart batteries run about $120.00 each (you will need two).
Here’s a couple of my blog post on my upgrade.
You will not need the Barry box extender ring because your trailer already has a bigger battery box.
http://www.airforums.com/forums/blog...-upgrade-2923/
http://www.airforums.com/forums/blog...-install-2924/
Dept of “OverKill”
Old 06-24-2019, 01:16 PM   #3337
We have all LEDs and those decorative lamps on either side of the dinette are, I think, incandescent.
David R. Busse
DRBusse@roadrunner.com
2018 Airstream International 23CB
2018 GMC Sierra 1500 4x4
Old 06-25-2019, 06:52 AM   #3338
richw46's Avatar
Yours is a much newer model than mine. Ours still has the high intensity lamps above the L-couch and bed; battery hogs. Is that what you mean by your decorative lamps? If so, you'll probably have to swap out the lamps for something else.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 06-25-2019, 02:42 PM   #3339
CAB & DAB
dbdreams's Avatar
2019 19' Flying Cloud
Fayetteville , Texas
Oh well
likely my fault but went to turn on the refrigerator yesterday and would not function on gas. It had worked fine about two weeks ago but would not even try to light, no ignition sequence just the check light after about ten seconds.
Did all the troubleshooting I could and seems the lower circuit board died. The trailer is about 7 months old so time for a failure or two right? In all fairness I installed an exhaust fan for the compartment tying the positive side to the existing fan and ground to the fan ground downstream of the thermostat so I could turn the new fan off and on with the inside fan switch. I may have arched something at some point, though I don't think so frying the board. I guess I will look back on other fan installs to see how others have wired theirs.
Good news is for the price of the fuel to haul her to a dealer I can replace the board! Hope that cures it, have a trip in the plans for early July
Good day all!
dbdreams is offline   Reply With Quote
Old 06-25-2019, 03:32 PM   #3340
2019 23' Flying Cloud
South Lyon , Michigan
Spare Tire Bracket Recall
Just got a letter from Airstream stating that certain 2017-2020 Airstreams (Mine is a 2019 23 CB) are being recalled for a defective weld in the spare tire bracket that could cause it to break off the Airstream. I'm going to try and call and see how bad this really is since I'm leaving soon for a 3 week 3000 mile trip out west. There's no way I'll get into the dealer before the trip. I may just remove the spare and put it in the bed of the truck and hope that the weld isn't really bad.
Rdavenp3 is offline   Reply With Quote
Old 06-25-2019, 03:58 PM   #3341
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
If I were you I would inspect the holder and if it looked ok I would roll with it and just keep an eye on it. Or you could do as you said and just put the spare in the bed of your truck. You could also with just two bolts remove the stair rack altogether.
But over all enjoy your trip.
Here’s a blog post that may help explain.
http://www.airforums.com/forums/blog...rier-mod-2921/
http://www.airforums.com/forums/blog...er-mod-2-2922/
Dept of “OverKill”
Old 06-25-2019, 05:37 PM   #3342
2018 23' Flying Cloud
St. Petersburg , Florida
Power Jack
Recently ours starting making some squeaking sounds as it gets high. (It always at the full height or bottom made the brrrrr clicking sound). This is new. Any thoughts?
DavidaPeter is offline   Reply With Quote
Old 06-25-2019, 07:42 PM   #3343
RFP
RFP's Avatar
Hurst , Texas
I wish that ours was so well behaved. It squeals, groans, and grinds - going up and down - when it's pretty well extended. I hope our camping neighbors don't think I'm abusing a family pet (!)
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 06-26-2019, 04:46 AM   #3344
"Hey, I know you!"
Boog's Avatar
2012 23' Flying Cloud
Irmo , South Carolina
Here's a link to a thread with pictures and video about tongue jack maintenance: http://www.airforums.com/forums/f457...cs-187676.html
https://thisoldcamper.com/
Boog is offline   Reply With Quote
Old 06-26-2019, 04:58 AM   #3345
"Hey, I know you!"
Boog's Avatar
trip out west
And just for the heck of it, here are some pictures of our trip out west in May.
Desert View Campground - Grand Canyon AZ
Monument Valley AZ/UT
Dead Horse overlook Utah
Heading into Arches National Park:
Goose Island campground, Moab UT, (just outside of Arches)
And a shot of the Grand Tetons from Gros Ventre campground outside of Jackson, WY:
Old 06-26-2019, 05:12 AM   #3346
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
Boog, thanks for sharing. The West is calling.
Clint
Wolfwhistle is online now   Reply With Quote
23d
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
eagletoo
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
