Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 01-11-2020, 10:09 AM   #3741
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Originally Posted by Chris Borth View Post
Not sure I needed to do this but it is convenient. The item is called an over the door Hangar (Item #10075907 at the Container Store). I cut off the over the door part and screwed it onto the BARE WALL.
Sorry but I can't figure out how to rotate the pictures so you'll have to rotate the screen.
Great idea.
pcskier is offline   Reply With Quote
Old 01-12-2020, 09:52 AM   #3742
talewis13's Avatar
2018 23' Flying Cloud
Garner , North Carolina
Originally Posted by RFP View Post
It is a low point drain. It is not connected to the fresh water tank, it merely is routed through the metal box which surrounds/supports the tank. Be sure to open it when doing your annual winterizing.
Update on the two valves under fresh water tank. One is the drain (the white one). The second one,which is metal, seems to be attached the the water pump. As I was setting up the in-law suite. I had left it open inadvertently and pumped 15+ gals of fresh on the ground. Wondering why the system would not pressurize. Went outside to find water running down the drive but when I close the valve system pressurized within seconds. Refilled the fresh and all was set for the visit.
talewis13 is offline   Reply With Quote
Old 01-12-2020, 10:00 AM   #3743
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
Like RFP said it’s a low point drain. To help drain plumbing when winterizing. It’s not ‘attached’ to the water pump per se, as it’s just part of the plumbing system which is all pressurized by the pump or by city water. If you hooked up to city water that valve would drain as well if open. P.s there are 2 more low point drains in the rear storage compartment to drain when winterizing as well.
Old 01-13-2020, 08:21 AM   #3744
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Ok guys so here is my latest and by far one of my most complex upgrades.
The installation of the Victron MultiPlus 12/3000 inverter, Victron Color GX monitor, ALL new 4/0 battery cables, fuses, breakers, more wires, more fuses, lights, flux capacitor, and relocation of my BMV to the location where my old inverter switch was below the tank monitor.
The relocation of the BMV was a challenge due to the need to run a V.E. Direct cable from the Color GX to the BMV. This was a difficult run down the wall under the floor (through the chase) and up to the microwave compartment. The V.E. Direct cable was required to allow the BMV to communicate with the Color GX. Whew that’s A lot I
Know but it turned out great and now I can run the microwave and anything else I want to run off battery power.
Here’s some pics.
ID:	359065   Click image for larger version
ID:	359067   Click image for larger version
ID:	359069   Click image for larger version
ID:	359071   Click image for larger version
ID:	359073   Click image for larger version
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 01-13-2020, 05:50 PM   #3745
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Looks awesome Ronnie! Are you getting any errors from the GCX? Seems like if you upgrade to latest firmware it may not work with the multiplus. I talked to victron and they told me to roll back my firmware, and turn off the auto update. They said that it it is nit necessary to keep all equipment up to latest firmware it’s more important to use a stable system. They told me not to go update my multi if it’s working and keep running off firmware I have.
Since yours is new, maybe it’s all up to date. They said keep it at version 2.33. Thx
Troutboy
Troutboy is offline   Reply With Quote
Old 01-13-2020, 06:04 PM   #3746
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I’m running 2.42 without issue.
Old 01-13-2020, 06:07 PM   #3747
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here’s a cool comparison photo. The factory battery connect cables vs my new 4/0 battery connect cables.
ID:	359091   Click image for larger version
Old 01-13-2020, 06:15 PM   #3748
2007 22' International CCD
The 23D thread
Man, I’ll bet those monster cables will have the ability to deliver lots of current. Make sure you have appropriate fuses to protect the rest of the wiring. I’m using a Blue Seas terminal mounted bolt-on fuse block right on the battery post to protect the rest of the wiring. Right now it’s an 80 amp fuse.
I just replaced the wimpy 10 gauge battery leads that came from the factory with 4 gauge marine rated wire, lugs, and sealant lined shrink tubing. My lights don’t flicker anymore when I dump a big load on the 12 volt buss.
I also added a Blue Seas disconnect switch on the front of the AS in the positive lead as a emergency/storage disconnect to kill all 12 volt power inside the trailer. Only thing that has power when it is off is breakaway, tongue jack and WD power jacks.
Old 01-13-2020, 06:20 PM   #3749
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
BlueSea 300A battery terminal fuses for both banks and a BlueSea 400A T-class fuse for the inverter along with various other appropriately sized fuses
Old 01-14-2020, 01:06 PM   #3750
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
All covered up now , Like it never even happened.......
ID:	359174   Click image for larger version
ID:	359176   Click image for larger version
Old 01-14-2020, 01:17 PM   #3751
eagletoo's Avatar
New Hyde Park , New York
Spic & Span condition
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
Airstream Club International #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 01-14-2020, 03:29 PM   #3752
StephSH's Avatar
2020 23' Flying Cloud
1977 Argosy 28
Southern Ohio , Ohio
You did an amazing job! You have more acronyms in that post than the VA uses in a day- and that’s saying something [emoji23][emoji23]
StephSH is offline   Reply With Quote
Old 01-14-2020, 10:19 PM   #3753
Troutboy's Avatar
Parker , Colorado
Looks great Ronnie, like those access holes, now I might have to add one more...
Troutboy
Old 01-19-2020, 01:27 PM   #3754
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I installed a HaloView rear camera yesterday. Tapped power at the rear clearance lights as many others have done. System has a camera that is wired to a forward booster. Works well as I have a strong signal with my truck in the garage and the Airstream parked over 100’ away.
ID:	359459   Click image for larger version
ID:	359461   Click image for larger version
Old 01-19-2020, 01:32 PM   #3755
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I also made a clamp from a piece of Kydex which will allow me to “click” my rear camera monitor over my trucks Rear View Mirror. I believe this is a logical place to mount it while towing.
ID:	359463   Click image for larger version
ID:	359465   Click image for larger version
ID:	359467   Click image for larger version
ID:	359469   Click image for larger version
Old 01-19-2020, 04:35 PM   #3756
Troutboy's Avatar
Parker , Colorado
Sweet Ronnie, looks great. I have the factory installed camera and love it. I think it helps greatly with lane changes and such. You aught to mass produce those mirror holders, really like that since the rear view mirror isn’t much use when the trailer is attached. It’s nice and out of the way for sure. I’ll take a look at my system and see if I can mod it to hang like that.
On the booster, did you look at installing it under the unit? Just curious if there was any reason you chose to install on top?
Troutboy
Old 01-19-2020, 05:03 PM   #3757
Registered User
2016 25' Flying Cloud
Fairfield , California
Put me on the list also for one of those, kept thinking to myself, it would be great and out of the way to have the rear view monitor on the rear view mirror.
Brilliant!
Matti
Mattirs is offline   Reply With Quote
Old 01-19-2020, 06:05 PM   #3758
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I did think about putting the booster under, but I only had 20’ of cable so I did not have enough to get there.
Old 01-19-2020, 06:05 PM   #3759
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Brilliant!
Matti
Only problem with making them is each brand is different.
Old 01-20-2020, 12:58 AM   #3760
Registered User
True did not think of that. Guess I will just need to learn how to do it myself. :-)
23d
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
