Old 10-14-2019, 02:12 PM   #3581
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
Looks like the same. Mine kept pulling loose and retighting didnít help. They just kept working loose. Well I put some toothpick pieces and wood glue and they stayed tight during our last camping trip last weekend to Hocking Hills, Ohio. Today Iím winterizing today as well.
FloydCoVa is offline   Reply With Quote
Old 10-14-2019, 07:12 PM   #3582
richw46's Avatar
Lexington , Kentucky
Don't forget to close the outside shower taps before you waste 1/3 of your pink stuff. That's the 3rd time I've done that.
In my picture you can see there's a screw loose. I've owned this AS since early 2014 and we never had a screw come out. They seem to hold pretty well. On the other had, our slide out pantry slides out like it's warped, moving from the right side to the left. I've taken it out twice and replaced / tightened screws. That lasts about 6 months, then it moves again. It's the tracks, they keep slipping. I may use glue this next time.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old Yesterday, 06:43 AM   #3583
FloydCoVa's Avatar
Rich, last year while winterizing I left the front low point drain open and pumped most of a gallon on the driveway!
This is what I did to my pantry, not my idea, added a second slide to the second shelf. So far so good. Rob(RFP) came up with this and his write up is spot on. Iím not very handy with this kind of stuff but I got it done. Check it out.
http://www.airforums.com/forums/f38/...3d-158887.html
Old Yesterday, 08:13 AM   #3584
richw46's Avatar
Oh good, it's not just me then. After I discovered I had dumped that antifreeze I closed the spigot, shook my head and realized I hadn't winterized the shower spigot. We don't use the shower much but I always run tap water through it to get rid of the antifreeze. I barely had enough to finish the job. At least now I don't have to store any over the summer.
This is what I did to my pantry, not my idea, added a second slide to the second shelf. So far so good. Rob(RFP) came up with this and his write up is spot on. I’m not very handy with this kind of stuff but I got it done. Check it out.
Rob is definitely a talented individual and comes up with all kinds of improvements. He has some good ideas on stabilizing the pantry slide. I'll save the link and add it to my list of things to do. When I retired I wondered if I'd find enough projects to keep me busy. Then I bought an AS and I've not rested since then.
(Rob's pantry looks to be about twice the width of ours. I think ours is about 6-8" wide, difficult to get into to tighten screws.)
-Rich
Rich & Yvonne
2004 4Runner SE
Old Today, 06:16 AM   #3585
2018 23' Flying Cloud
St. Petersburg , Florida
Convection Microwave too much power
We have the 2018 with a Couture Convection Microwave that's rated at 1500 watts. For the first year plus, according to our EMS, it pulled about 12 amps when microwaving.
Recently it's pulling 18-19 amps on microwave. That seems impossible.
Any thoughts of how to check this out? I'm concerned it may be dangerous.
DavidaPeter is offline   Reply With Quote
Old Today, 07:15 AM   #3586
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
You would need to verify the AMP draw with another meter independent of the rest of the trailer. Your EMS monitors the total AMP draw traveling through the trailer like the charger/converter.
Also AMPS are dependent on VOLTS. (watt=amp X volt)
So with that.
1500watts=18AMPs X ?VOLTS
Using this formula 1500W/18A=83 VOLTS.
So whats your volts to the trailer UNDER LOAD?
If itís 120 volts. It Means W=18A x 120V. Your microwave is using 2160 watts
Based on the factory numbers your microwave should...1500=A x 120V. Draw. 12.5 AMPS
Best bet is to test the with a independent meter.
Old Today, 07:37 AM   #3587
richw46's Avatar
Originally Posted by richw46 View Post
In the RV section of Lowes I found a replacement. I can use the good parts off of the old drain to keep some of the "chrome" look. The old drain is mostly plastic anyhow, should look good. The bottom part was too long for my AS, the original is a good fit.
https://www.lowes.com/pd/Road-Home-C...Kit/1000458987
The Lowes drain is junk. We never even used the sink and the "chrome" at the bottom of the basin has separated from the drain. I used plumber's putty which may have been the reason, but there was no caution against it. I'm ordering a chrome plated steel one from eTrailer.com.
https://www.etrailer.com/p-PF282010.html
-Rich
Rich & Yvonne
2004 4Runner SE
Old Today, 08:29 AM   #3588
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yep. I swapped both of mine (bath sink and shower). Found nice heavy chrome plated brass ones.
ID:	354347   Click image for larger version
Old Today, 08:47 AM   #3589
FloydCoVa's Avatar
While winterizing the trailer and rereading the manual I ran across this. Could RV antifreeze be causing this?
Old Today, 12:02 PM   #3590
richw46's Avatar
For me, I left a hand soap dispenser in the sink and it leaked. It sat there all winter before I noticed the soap had corroded the stopper and drain. It was chrome plated steel and I got a replacement at Lowes that was plastic. We never used the sink and when I winterized I noticed the "chrome" drain was moving. It had separated from the rest of the drain. I'm getting a chrome plated steel one from eTrailer, looks like the original.
The original had never corroded from antifreeze, I always wipe up any spills. I'm guessing the plumber's putty I used for the seal dissolved the plastic.
-Rich
Rich & Yvonne
2004 4Runner SE
23d
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Chris Borth
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
