Old 08-20-2018, 05:46 AM   #2059
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Uncle Bert is right. Probably Dew on the moisture sensor and if the thermostat is set to auto the fan will cycle.
Old 08-20-2018, 08:45 AM   #2060
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Originally Posted by KatherineHB View Post
Does anyone know where the GFCI switch is on the 2018 Signature 23cb? Our refrigerator is no longer working after only 3 trips and 6 nights on the road. Weíve checked fuses and tried to use propane, but no luck. So, weíre hoping we just need to reset the GFCI switch, which we canít find!
Thanks for any help.
Hi KatherineHB,
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 08-20-2018, 08:47 AM   #2061
Originally Posted by weirdstuff View Post
Having a couple issues.....
First issue is with our front fantastic fan. It has a mind of its own, and keeps closing at night.
Itís always just the front one, always happens at night after we go to sleep, and no, itís not raining out!
Second issue is with the a/c. Sometimes, like today, Iíll set the a/c at about 77 so that it will turn on in the afternoon if/when it gets hot out (and we plan to be away from trailer). This morning, inside temp was 71. I set a/c to 77. And the darn thing turns on and wonít turn off. Makes no sense!!
Otherwise, as always, life in our Airstream is great! Currently in Salida, CO.
Hi weirdstuff,
Thank you.
Old 08-20-2018, 12:25 PM   #2062
2018 23' International
Sahuarita , Arizona
Pantry Cabinet Shifting 23CB
We just purchased our first Airstream in June, a barely used 2018 International Signature 23CB (it was 3 months old). I already had to re-caulk the shower because there was a 1/2" gap between the shower pan and shower door that was only halfway caulked. I was hoping that would have been my only issue and wasn't a sign of the quality. Sadly, it is not my only issue, and I'm hoping that someone out there has had the same following cabinet issue, who maybe has an awesome suggestion how to "fix".
The pantry cabinet and wardrobe on the stove side is shifting. The top seems to be at least a 1/2" forward from the bottom, and it has shifted toward the bed as well. I've watched it get worse and worse. When I picked up my trailer, I noticed the roll out portion of the pantry had a reveal that wasn't the same at the top and bottom (and I just thought that the glides needed to get adjusted). Later, I realized that the roll out was level and the cabinet was shifting around it. It's now to the point where the roll out cabinet can't close because the cabinet around it has shifted so much, and we've had to remove the roll out entirely.
Poking around I noticed that there are 2 screws in each of the 2 cabinets that go into the floor at the front frame, as well as another 2 screws at the top that go into the ceiling. Is each of these cabinets solely secured by 4 screws? Or is there something I'm not seeing? I have to admit I'm a little dismayed that the 2 upper screws go through a piece of cabinet plywood, then there's a couple inches where the screw goes through nothing before it pierces the ceiling, and then the screw barely goes into the ceiling/metal shell maybe 1/4".
We are not in a position to take to Ohio for repair. It might be something that our local dealership could do (Lazy Days), though I'd rather this get repaired right, even if that means having to do it ourselves. Hoping someone has some insight. Thanks so much!
ID:	320405   Click image for larger version
ID:	320407   Click image for larger version
Stoeffler is offline   Reply With Quote
Old 08-20-2018, 07:54 PM   #2063
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Wow Stoeffler
Iíll do some poking around tomorrow and see what I can figure out. This should be something you can fix yourself.
Old 08-20-2018, 08:25 PM   #2064
2019 25' Flying Cloud
Hendersonville , North Carolina
On your pull out pantry, at the bottom, there is a slide on each side. There are probably 3 screws on each slider screwed into the wood at bottom of slide. They have come loose and let the pantry fall out of alignment. Open pantry, loosen screws slightly until you can freely move it back into alignment with cabinet. Make sure it is even down both sides and there is a nice gap at the bottom above the small door below pantry. If it is not high enough there will be to much gap at the top and it will not latch properly. Yes, it is a 2 person job and a pain. After realigning tighten screws. notice that these screws are in slots allowing for adjustment. Once you have it properly adjusted install at least 2 more screws on each side through the predrilled round holes. There are several to chose from. no more slipping of pantry. Why Airstream does not put a couple more screws in each side to pin pantry in place is beyond me. Also, we take the heaviest items out, namely the silverware tray, when traveling lessening the strain on the cabinet.
uraljohn is offline   Reply With Quote
Old 08-20-2018, 08:35 PM   #2065
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Adding the second set of slides like a few of us have done will help. But it looks like his whole cabinet has shifted aft and needs to be squared back up and reattached to the trailer.
Stoeffler, stick close we can figure this out and get you fixed up. On mine I added the second set of slides as Rob, instructs us to do in his previous post on external counter top space.
Your whole cabinet has shifted for sure.
A few more pics might help diagnose the cause
Here is a link to Robís MOD that shows the second slide
http://www.airforums.com/forums/f38/...ml#post1870564
Old 08-20-2018, 08:41 PM   #2066
I had completely forgotten about the 2nd slide upgrade. Without this great forum I just do not know how I would make it. Vast amount of great info shared by very generous 23D owners.
Old 08-20-2018, 09:01 PM   #2067
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
We are a strange little group
Old 08-20-2018, 11:07 PM   #2068
Huntington Beach , California
GFCI on 2018 23cb
So, we found the GFCI switch- at the very bottom of the fuse container. It wasnít tripped. Still no refrigerator power & its panel is dark, despite the refrigerator being plugged in and the outlet having power. Anyone have any ideas?!
KatherineHB is offline   Reply With Quote
Old 08-21-2018, 05:32 AM   #2069
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Katherine,
Check the 120 volt plug in the fridge compartment lower street side (where the fridge plugs in). That might be part of the problem. Also need to check for 12 volt power behind fridge. If you have power in those two places it sounds like one of the boards is bad (either the back board, the one in outside compartment or the panel board, th one behind the lights and switches inside.
Sorry for your trouble.
Old 08-21-2018, 09:10 AM   #2070
No refrigerator power
Katherine,
Could you please tell me how to check the 12 volt power behind the fridge? The 120 volt plug is good
Thanks so much for your help.
Old 08-21-2018, 11:55 AM   #2071
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Ok so I did some looking and hereís how mine looks.
ID:	320466   Click image for larger version
ID:	320468   Click image for larger version
ID:	320470   Click image for larger version
Old 08-21-2018, 11:59 AM   #2072
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Small gap between counter top and cabinet on mine but doors line up good.
Attached the same as yours with 2 screws through the top and bottom of both cabinets. My top screws go about 1/2’ into the inside skin.
On ours what is plumb? The cabinet frame or the slide I can’t tell from your picture.
23d
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
