Old 12-10-2018, 05:24 PM   #2921
2016 23' International
Long Beach , California
Just finished fabricating new brackets for Spot Diffusers.
ID:	329457   Click image for larger version
Seanlb is offline   Reply With Quote
Old 12-10-2018, 06:24 PM   #2922
CAB & DAB
dbdreams's Avatar
2019 19' Flying Cloud
Brenham , Texas
Joanna
The new bathroom door is std for 2019, I do not think it would be worth the time and money to retro fit one. We had thought of replacing the door with a curtain on a curved rod in or older 23D. It would be great to be able to mix and match some of the new 'upgrades' with some from the past, like the floors in the storage areas ~ used to be a nice diamond plate now a rubber mat!
David
dbdreams is offline   Reply With Quote
Old 12-10-2018, 06:39 PM   #2923
2008 23' International CCD
Pinson , Alabama
Hinge
Originally Posted by RFP View Post
Can you describe how (where) the hinges are breaking, or better yet, show us a photo of a broken hinge?
i like the piano hinge ideal
Can't seem to get pic loaded - it's breaking at the screw holes
RosiesGuy1 is offline   Reply With Quote
Old 12-10-2018, 06:47 PM   #2924
Pinson , Alabama
breaks at round screw holes - borrowed pic from another airstreamer
Old 12-10-2018, 07:29 PM   #2925
egraham's Avatar
2016 28' International
Birmingham , Alabama
Iím interested
egraham is offline   Reply With Quote
Old 12-10-2018, 07:41 PM   #2926
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Those look cool. Where did you get them?
GMFL is online now   Reply With Quote
Old 12-10-2018, 07:47 PM   #2927
I started a new post for the Air Conditioning Vents we made:
http://www.airforums.com/forums/f427/air-conditioning-vents-190181.html
If youíre interested in learning more about these and might like a set then please reply on the above link.
I will start to work out the cost of a short production run if I can get at least 10 members who are interested.
Old 12-10-2018, 08:00 PM   #2928
I started a new post for information about the Air Conditioning Vents we fabricated:
http://www.airforums.com/forums/f427...ts-190181.html
I will look into a short production run if 10 or more members are interested in them.
Old 12-10-2018, 08:12 PM   #2929
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
You 3D printed the mounting collar, but where did you buy the diffuser?
Old 12-10-2018, 08:18 PM   #2930
From a factory in Asia.
They are not available retail. The closest thing you’ll find spec wise is here: https://seiho.com/product/index2.html
These are usually special order parts so the price will vary wildly.
Old 12-10-2018, 08:30 PM   #2931
I was able to get them directly from a factory in Asia (Iím in engineering/design and had a contact who was able to find them for me).
The closest thing Iíve seen on the market is made by a Japanese Company (Seiho):
Poke around the web...
Old 12-10-2018, 09:02 PM   #2932
Pinson , Alabama
About 3 weeks ago I completed a Florida trip (down west coast to Key West, back up the east coast). Included in this trip was wife, Sister-in-law from AZ and Mother-in-Law from North Dakota. All in the 23'D Airstream. They did not shut up the whole trip !!! a little over 2300 miles. Never again without a Bose Headset!
Old 12-10-2018, 10:13 PM   #2933
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Rich,
I'm sure you still have an 'ample' supply of the laminate. If you will send an appropriate size piece, I'll make you a 'proper' wallplate.
Rob, thanks for the offer. The issue is clearance from opening the mirror. Itís very thin, Iím not sure one could be made from wood. Check out yours and let me know what you think.
Can you laminate aluminum?
Troutboy
Troutboy is offline   Reply With Quote
Old 12-11-2018, 05:58 AM   #2934
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We upgraded from the stock 14” tires and wheels on our 2015 23D at the selling dealership. We put on 15” SenDel wheels (5 lugnuts to attach to stock 10” brake drums) and 15” Michelin tires. Run 44 psi in the Michelin tires. They have a larger foot print on the road for better braking and a softer ride for the trailer. Had the same model Michelin tires and air pressure on our 2013 25 FB that was 900 pounds heavier loaded for camping.
Old 12-11-2018, 12:17 PM   #2935
RFP
RFP's Avatar
Hurst , Texas
Rich,
There is 5/8" clearance between my wall and the arc of the top cabinet door... plenty of room.
I 'can' laminate the aluminum, but would prefer to use 1/16" Baltic birch. It could be very easily made to look quite good.
Just let me know... I don't want to 'force feed' this idea, but I'd be happy to make a panel for you.
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 12-11-2018, 05:40 PM   #2936
Troutboy's Avatar
Parker , Colorado
Rob. Iíll measure mine. Then be in contact. Thanks for the options and willingness to help. You are the man!
Troutboy
Old 12-12-2018, 03:59 PM   #2937
RFP
RFP's Avatar
Hurst , Texas
This just seems weird to me. It seems to me that if the brass catches are fully closed, they would prevent most all up/down movement of the curved doors, and thus protect from hinge failure. Are you sure that your doors are 'latched' securely when closed?
Just wonderin'
And some stuff
Old 12-13-2018, 05:13 PM   #2938
Troutboy's Avatar
Parker , Colorado
Just paid off the airstream!!! Woohoo!
Troutboy
Old 12-13-2018, 05:14 PM   #2939
RFP
RFP's Avatar
Hurst , Texas
Congratulations.... It's a happy day!
And some stuff
Old 12-13-2018, 05:21 PM   #2940
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
It’s a great feeling. Congratulations!
Welcome to the club.
We are working super hard to pay off our house next.
23d
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
