11-25-2018, 10:02 AM
#2861
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
No doubt
11-25-2018, 11:04 AM
#2862
CAB & DAB
2019 19' Flying Cloud
Brenham
Replacement 23CB
We are planning on heading out early in the morning heading to Tampa to pick up our replacement 23. It really was amazing to see what we salvaged out of the Armada and the Airstream! Funny, we had talked about taking EVERYTHING out of the trailer and repacking and reorganizing when we returned from our last trip, but did not think it would be because of an accident! Thanks to this fantastic group of folks here we know a lot of items to look over before driving her off the lot and have a lot of mods to do in order to get it close to what we had. Good news about some of them is they may work out better the second time around! Will post a few shots when we can
Have a great week all.
David and Carole
11-25-2018, 12:14 PM
#2863
Overkill Specialist
Dadeville
, Alabama
David and Carole,
I am so proud for you guys. Congratulations on the new unit.
11-25-2018, 08:48 PM
#2864
2013 23' International
Delaware
, Ohio
3" lift photos before and after
Hi all,
We put on Sendel T08 15" rims with 235/75R15" LT C truck tires. These added approximately 1.5" of radius over the factory 14" rims and tires.
Here are photos showing our 23D with the up-sized rims and tires before and after our 3" lift--before lift views are on the left, after on the right. The last photo is of the rig.
This lifted look may or may not appeal to some owners, but it serves our purposes.
Note that we have a WD hitch, but we were just moving the Airstream around the yard and into the building for work, so did not use it. The rig would be more level and look a bit better had we made the effort to use the WD.
Jim k
2013, 23D International Signature
2015, Toyota Land Cruiser
11-25-2018, 08:53 PM
#2865
Overkill Specialist
Dadeville
, Alabama
Looking good Jim!
11-25-2018, 08:55 PM
#2866
Delaware
, Ohio
David and Carole
Looks great! And, so happy that this experience is working out for you two.
11-27-2018, 01:49 PM
#2867
2016 23' Flying Cloud
Fanwood
, New Jersey
I apologize if this has already discussed here. It's a monster thread, and I can't go through it all....
Has anyone installed winterize kit, like this one?
As you know, WP in FC23D is in such a tight space and tubes are arranged in such a way that I'm not sure if this can be successfully installed....?
11-27-2018, 02:07 PM
#2868
Hurst
Yep, I installed this little gizmo a couple of weeks ago. Of, course, being who I am, I made a major production out of it: made a foam isolation mount for the pump and a bunch of other stuff which is of no interest at all to anybody.
The short answer is "sure," it will fit. It's pretty tight in there, but it certainly can be done. I would encourage you to do it... I've already winterized/un-winterized/and re-winterized this year. The Camco kit worked great.
PS: I would encourage you to read through the whole thread. There is a lot of good stuff here.
11-27-2018, 02:24 PM
#2869
Fanwood
, New Jersey
Wonderful. Thank you! I shall try then.
When we were contemplating on FC23D two years ago, I read most of it, but since then, it has grown significantly. I wish there is a way to search within this thread.
11-27-2018, 02:35 PM
#2870
Hurst
There is an easy way: toward the top of each page there is a "search this thread" tab
11-27-2018, 04:44 PM
#2871
Overkill Specialist
Dadeville
, Alabama
I have also installed one. We winter camp and it’s a great way to winterize on the road in just a few minutes.
We have also been know to run the furnace while traveling down the road to prevent the tanks for freezing.
But hey we are crazy
11-27-2018, 04:51 PM
#2872
Hurst
And I've run the furnace while traveling down the road because I forgot to turn it off!!!
*sigh*
11-27-2018, 04:58 PM
#2873
Overkill Specialist
Dadeville
, Alabama
*sigh*
That’s only because your mind is to full of great ideas!
11-27-2018, 09:47 PM
#2874
2017 23' Flying Cloud
Parker
I store in a heated garage, hence no more winterization!
Troutboy
11-28-2018, 02:08 AM
#2875
2017 23' International
Oregon City
, Oregon
Last Winter I purchased this kit for our 2017 Serenity.
Because of the way our water pump is positioned, there was not enough room to attach the T-Valve to the pump. It just wouldn't physically fit.
Consequently, I ended up attaching the clear tubing directly to the water pump and putting the other end into the jug of anti-freeze.
At that time we were into freezing temps so I had to get it done.
I suspect that each AS is slightly different in this area, so you probably won't know until you try.
Keith
2017 23D International Serenity
2014 1500 Silverado 5.3L
11-28-2018, 05:08 AM
#2876
New Hyde Park
, New York
Atsushi, yes it can be installed. I physically could not work in such a small space so I had Colonial AS suffer through it. We (I held the flashlight ) unscrewed the pump from the floor so that the new valve would fit and I can turn it later on. Once installed, rescrewed the pump back down and all is now good. Works like a charm!
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
Airstream Club International #2600
I’d rather be camping is an understatement!
11-28-2018, 08:02 PM
#2877
2013 23' Flying Cloud
1959 18' Traveler
1963 16' Bambi
Victoria
, British Columbia
seeking Trailer cover information
Oh Hi,
I'm trying to figure out a trailer port for my 23D. Its parking space is a pie slice, with the rear end too narrow to put a 12 ft. metal roofed carport or a tarp covered frame. It has to be "temporary" or moveable in nature.
I was cruising through the 23D thread recently and I remember seeing somebody's Airstream protected by some sort of fabric "tent" cover. It looked like the fabric was slung on cables and attached only at the four corners with no other posts between them. I can't seem to find that photo again to check out that possibility. I'd appreciate somebody letting me know if that's their cover or if they have any information about something like that.
Many thanks-
Cindy
11-28-2018, 08:16 PM
#2878
Overkill Specialist
Dadeville
, Alabama
Cindy,
Can you post a photo of the area you are trying to utilize. There are a lot of smart people on here that I’m sure can help.
11-29-2018, 12:37 AM
#2879
1959 18' Traveler
1963 16' Bambi
Victoria
, British Columbia
I'll post a photo of the space and dimensions tomorrow. Thanks for the suggestion.
11-29-2018, 08:57 PM
#2880
Overkill Specialist
Dadeville
, Alabama
Posted a few new things to my BLOG this week for those who are following along.
http://www.airforums.com/forums/blogs/105870-gmfl.html
