Old 06-12-2017, 07:13 PM   #241
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Maxim skylight installed
Installed my new Maxim Skylight today. Bronze/ Clear/ Clear powder coat white frame. Size was 22.75" X 22.75"
Awesome upgrade and super easy to do. Plenty on here about how to install so I will not bore you with the details. Liz and David at Maxim are both Great to work with!!!
Old 06-12-2017, 09:07 PM   #242
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Ronnie, why did you replace the stock one?
Troutboy
Troutboy is offline   Reply With Quote
Old 06-13-2017, 08:40 AM   #243
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
One usually replaces the inexpensive factory skylight upon inspection of the external plastic frame on the roof and finding the screws were over torqued and cracked the frame which becomes sources for leaks.
The Maxim is triple glazed with an aluminum frame and certified for hail.
Old 06-13-2017, 09:44 AM   #244
RFP
RFP's Avatar
Hurst , Texas
There were no screws in ours (2014)... VHB tape instead. It was a booger to get off, too... that stuff holds with a vengeance.
Even so, the OEM skylight is pretty "basic" (as in flimsy, and letting in a LOT of radiant heat), and the Maxim is a superb upgrade... certainly worth the money and effort... well, it was to me.
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 06-13-2017, 10:11 AM   #245
Troutboy's Avatar
Parker , Colorado
What do these units cost? Sounds like a no-brained. Wife is going to kill me, I told her the lift was the last upgrade!
Troutboy
Old 06-13-2017, 10:32 AM   #246
RFP
RFP's Avatar
Hurst , Texas
Originally Posted by Troutboy View Post
< snip > I told her the lift was the last upgrade!
You told her WHAT ?
And some stuff
Old 06-13-2017, 10:34 AM   #247
Troutboy's Avatar
Parker , Colorado
Originally Posted by RFP View Post
You told her WHAT ?
I know, forgot the golden rule, under promise over deliver........
She says I spend more with the AS lately than with her.......
Troutboy
Old 06-13-2017, 11:59 AM   #248
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
😋there is never a last upgrade or acoutremont with this Airstream hobby.
And if she is claiming you spend more with it than with her then she is not spending enough time with the Airstream.
See how it's all intertwined. She can have her own list of gotta haves or isn't that pretty.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 06-13-2017, 01:09 PM   #249
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Where do you 23D guys have skylights? 23 FB has Fantastic Fans forward and rear, but no skylights?
pcskier is offline   Reply With Quote
Old 06-13-2017, 01:13 PM   #250
RFP
RFP's Avatar
Hurst , Texas
The skylight is between the front Fantastic Fan and the air conditioner...
And some stuff
Old 06-13-2017, 01:48 PM   #251
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yes
Old 06-13-2017, 01:51 PM   #252
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Mine was 282.00. Worth every penny!
Old 06-13-2017, 01:59 PM   #253
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Tell Her I said it is a must do! Haha
Don't look at my Alpha 1021 self leveling caulk job. Not my best work for sure
ID:	287498   Click image for larger version
Old 06-15-2017, 11:48 AM   #254
RFP
RFP's Avatar
Hurst , Texas
Getting there !
Just in case any may have wondered if I had completely given up on my 'folding dinette table' project (career?), may I say, nope, I'm still plugging away at this as time allows.
I am getting pretty close to finished, though, lacking only applying the final finish (wipe-on satin polyurethane) on the table edges. I elected not to use any of the various edge banding products on the table edges, opting instead to finish the edges with a three-step process: Solar-Lux black dye, black gel stain, and poly top coat. The genuine Baltic birch is 13-ply (as I recall) and lends itself to nice edge finishing. It should, it cost fifty-seven bucks for just enough to do the table tops! Yikes.
So, I am needing only to (1) finish the table edges, (2) attach the mounting hardware, and (3) do the final installation into the trailer. So, nearly all done.
Yay!
I will probably set aside my natural humility (of which I am so very proud ) and post a separate thread on this obsession when complete. It's been a complicated project and I have tried very, very hard to do it right... I really, really, really don't want this thing to look too "home made."
I do have a word of advice for any who may be feeling like they would like to do a project like this: Go lay down 'till that feeling goes away.
Rob
ID:	287619   Click image for larger version
And some stuff
Old 06-15-2017, 12:03 PM   #255
Long Island , New York
Nice work!
The Baltic Birch laminations also permit a similar clear finish to be stunning, although not the look you wanted probably.
Looking forward to photos of the table extended out, and after a torture test while towing on a bumpy twisty (side-to-side) road, to check the stability of the table underway.
I assume that this table does not offer the option of lowering it to make a bed?
( . . . forget if that was one of the design parameters . . . )
Have you kept track of your labor hours for this project ["career" . . . ], including design and online discussions?
Old 06-15-2017, 12:13 PM   #256
RFP
RFP's Avatar
Hurst , Texas
Originally Posted by OTRA15 View Post
Nice work!
Right, it's not the look I was after. The dye-stain resulted in deep brown, approaching black. Looks great and makes the black SOSS hinges virtually disappear.
I have absolutely no concerns about the table surviving an on-the-road 'torture test.' The combination of two pair of high quality drawer slides - each pair clocked 90-degrees to the other pair results in rock steady extension.
Correct. We would have never made the dinette into a bed. Of course, all the OEM stuff has been wrapped and stored for the next owner... whomever, whenever.
No, I haven't... it would be too depressing. I do expect the final tab for this thing to come in at around $300, the top-of-the-line Wilsonart laminate was $130. The laminate Airstream used in '14 is no longer available, but they offer a fairly good selection of laminates with the same "Mirage" finish (Wilsonart's #35 finish). It is VERY good stuff.
I will re-make the vanity to match the new dinette table. That's a one afternoon project.
Thanks for the compliment.
Rob
And some stuff
Old 06-15-2017, 12:31 PM   #257
RFP
RFP's Avatar
Hurst , Texas
< snip >
Looking forward to photos of the table extended out, and after a torture test while towing on a bumpy twisty (side-to-side) road, to check the stability of the table underway.< snip >:
Since the platform mechansim isn't yet fastened to the trailer wall, I can't show the table extended. I can show what it looks like when the 'extension' part is folded back over on top of the stationary table.
By the way, remember that the entire stationary table is firmly affixed to the trailer's wall, there will be no 'side-to-side' with that.
R
ID:	287622   Click image for larger version
And some stuff
Old 06-15-2017, 12:33 PM   #258
RFP
RFP's Avatar
Hurst , Texas
Oh, a couple more 'details' :
(1) The new folding table adds 16 pounds to the trailer. We travel so light, it matter not at all.
(2) The Wilsonart laminate used is 'River Gemstone.' It coordinates well with the deep brown Corian, the light UltraLeather, and the aluminum walls.
R
And some stuff
Old 06-15-2017, 04:27 PM   #259
RFP
RFP's Avatar
Hurst , Texas
You people are way too polite! Until I saw the photo I posted of the table, I hadn't realized that the table top edges were WAY TOO BLACK... failing to match the brownish-black of everything else. That's a beginner mistake that I shouldn't have made... but I did
So, back to the shop... more sanding and more staining. This time, I think I'll leave just a "hint" of grain showing through.
Sheesh...
R
And some stuff
Old 06-15-2017, 06:29 PM   #260
Troutboy's Avatar
Parker , Colorado
Rob, nice work as always. You are a true craftsman.
How do you install the laminate? Does it come with a glue backing?
Troutboy
23d
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
