10-17-2018, 05:46 PM
#2541
2015 23' Flying Cloud
Copper Hill
, Virginia
Pcskier , sorry for the confusion. There is only three low point drains and one fresh water tank drain. I'll be more careful posting.
10-17-2018, 05:53 PM
#2542
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
No worries! I winterized last week and have had 13 degree temps this weekend so you had me nervous that I missed one!
In your defense, in my 2014 manual it only refers to the tank drain, then the two under the bed...no mention of the third brass one under the fresh tank. So anyone using the manual could easily miss it. Way to go Airstream
10-17-2018, 06:45 PM
#2543
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
I am winterizing my 23d today. Thought I blew all water out of lines.while I was under the trailer I noticed another valve besides the one between the roadside tires and the two under the bed. I decided to open it up and water spilled out so I left it open.so next was to pump antifreeze in . I bypassed the hot water tank, got my antifreeze stuck the tube in it and turned the pump on. The pump sucked up 2 gallons of antifreeze! Seemed like a lot I went outside and found that I pumped 2gallons of antifreeze on the ground! I looked in my airstream manual and couldn't find any info on the forth valve. I used the white valve to drain fresh water tank. The valve on the bottom is the one that was open and pumped the antifreeze on the ground.
Attachment 325499
I’ve done the exact same thing and I knew it was there just was not smart enough to close the drain
Here’s a few pics for those whom my not follow us closely
10-17-2018, 07:31 PM
#2544
2018 23' International
SANTA BARBARA
, CA
Originally Posted by dbdreams
Just got back from a two month, 8500 mile adventure that took us from Fayetteville Tx to Caprock Canyons SP, Scottsbluff Nebraska, the Custer SD area, Glacier NP, Yellowstone NP, Grand Lake Colorado and Rocky Mountain NP and back to Fayetteville for 48 hours before heading to Missouri to take Mom up to visit a friend.
A hailstorm in North Dakota added some caricature marks to the Airstream and truck but nothing broken so were able to continue. All in all the 23 did a wonderful job of providing a great place to base out of and enjoy the wonders of some of our parks and scenery. Came home with a very short list of things needing attention but thanks to you guys have a few more mods to do!
Already planning on a few shorter fall and winter trips, will post a few more pictures and maybe where we plan to Glamp in the next few months if any of you guys are interested.
Thanks for all the support and great ideas on this thread!!!
David and Carole
Fabulous!!! And love the pics too!
10-18-2018, 08:23 AM
#2545
CAB & DAB
2019 19' Flying Cloud
Brenham
Dacron?
RFP,
In your post about the new foam upgrade in Fortune Cookie you mentioned wrapping the foam with Dacron. could I talk you into elaborating a bit as to the how's and whys? I know a lot of the covers tend to walk around and get out of place in the FCs at least, might the wrap help?
BTW, wet enough for you? The ducks around here are starting to carry umbrellas!
10-18-2018, 08:51 AM
#2546
Hurst
RFP,
Hi David! Sure, here's the deal (as I understand it): Most quality upholstered furniture 'wraps' the foam in a Dacron product that is made (more or less) for that specific purpose. This stuff, for example: https://www.joann.com/fairfield-30x1.../14311740.html
The "Dacron" is very resilient, regaining its loft after being squashed by sitting on it.
It's easy to install on the seat bottom cushions: just unzip the Ultraleather covers, slip out the foam, and wrap the suckers with the Dacron. A spray adhesive can help keep the Dacron in place as you replace the foam into the Ultraleather covers.
The Ultraleather will still "migrate" around on the cushions as they are used; probably not as badly as unwrapped ones. Firmer foam in the seat bottom cushions go a long way at controlling this "cover creep" ... but I think yours being a newer model 23D than ours, you probably already have the firm foam.
Does this help?
Don't forget to drop by again the next time you are up here... I've got your magazine rack thingie safely stored for you (and I actually know where it is!).
"Hi" to your sweetie.
10-18-2018, 09:39 AM
#2547
Hurst
While I had our accordion door off for another project (running the HDMI cable from the front television to the television back in The Queen's Chambers), I noticed that the little plastic "nail head" pin on the outside edge of the door was badly deformed and would certainly fail in the future... perhaps the near future.
My "fix" was to make a new part from HMW polyethylene (think white plastic cutting board). A couple of quick measurements and a few minutes on the table saw, and I had a fix-for-eternity. It took longer to drill-pry-coax-cuss the old part from the door than to replace with my new one.
You may also notice that I added the Asian Sand laminate into groove in the metal door track... the world's most insignificant mod). Anyway, cut a piece of laminate 1.15" and slide it in... that's all folks.
10-18-2018, 03:18 PM
#2548
CAB & DAB
Brenham
cover
Thanks Rob,
That clears it up, I was thinking the thin, slippery Dacron sheets I have seen, that upholstery material looks great, will try that and maybe re-foam the bottom cushions on the dinette.
Looks like we have decided to take the Airstream to the west coast next week. We were just going to drive out to take youngest son some of his stuff but after staying in a few hotels last week on the trip with Mom Carole said she would much rather take our cabin on wheels! Guess she has really taken to Glamping!!
10-18-2018, 04:29 PM
#2549
Overkill Specialist
Dadeville
, Alabama
Hitch *BLING*
Got my hitch BLING back from powder coater today.
I think it looks pretty good.
10-18-2018, 04:34 PM
#2550
Hurst
Ah... A worthy recipient of a
10-18-2018, 04:42 PM
#2551
Overkill Specialist
Dadeville
, Alabama
Now it’s on to firmer foam for the seat cushions.....
10-18-2018, 07:43 PM
#2552
Copper Hill
, Virginia
I like it a lot! Nice job.
10-18-2018, 07:44 PM
#2553
2022 Atlas
Homosassa
Looks Great especially now that it is power coated.
10-19-2018, 11:05 AM
#2554
The Aluminum Tent 3
Park City
, Utah
Pretty good? Wow! OK...so you are this group's master fabricator. Rob (RFP) is the master woodworker/interior finishes guy. Rob 2 (Trout) is the solar/electrical guru. And the talents and abilities of the three of you certainly overlap in many areas as well.
The rest of us...just desperately hoping to keep up
10-19-2018, 11:26 AM
#2555
Copper Hill
, Virginia
Pcskier,you are so right! I got my lift blocks drilled this am. Next to paint/rust proof them,but for now it's back to work.
Yesterday I got the 23d winterized after a trip to town for more antifreeze.
I don't try to keep up I just keep plugging away...
10-19-2018, 01:34 PM
#2556
The Aluminum Tent 3
Park City
, Utah
Good philosophy! Keeping up with these guys would be exhausting! So many great ideas to 'plug away' at though! But I'm not going to lie, even though I can and have built a house (being the GC and doing many jobs subs would normally do,) and am much more handy and mechanical than the average guy...no way do I have the tools and/or talent to do the finish work RFP does, nor the fabrication GMFL does. I just need to accept that and love myself anyway!!
10-19-2018, 01:58 PM
#2557
Wasilla
, Alaska
The lock looks great. And the play by play was excellent. I'm interested in doing a cushion foam upgrade myself so I'd like to see some pics as you progress. Where do you plan to get the foam from?
10-19-2018, 02:12 PM
#2558
Hurst
Look back a few pages in this thread, specifically my post number 2435 (I would link it here, but I'm engaged in hand-to-hand combat with my phone).
I did a lot of research before selecting the foam... there are about a g'zillion choices. The one I finally chose is perfect... to us... YMMY
Rob
10-19-2018, 02:24 PM
#2559
Overkill Specialist
Dadeville
, Alabama
Kind words
Thank you for the kind words. The Lord blesses us all with different talents for sure. I think one has to enjoy a craft to excell at it. My mind runs nonstop (it’s sometimes a curse). Working on projects like the hitch lock allow my mind to focus. I spent way to much time building that thing to make any sense to most people. It’s like a chew bone for a dog, it’s soothing for me. I could not afford the therapy sessions it would require to “fix” me so I self medicate with over the top projects that make little to no sense. You guys all do great work, and I love to see the projects and progress. Keep it up.
10-19-2018, 02:35 PM
#2560
Overkill Specialist
Dadeville
, Alabama
Example. This is what I’ve been doing the last two days.
Building a floating dock for my church.
