Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 10-08-2018, 03:51 PM   #2461
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Originally Posted by Troutboy View Post
That thing looks sharp Ronnie!
Complete and utter overkill for sure. I will have approx 8 hrs of fabrication time and $126 for the Multlock MP5+ puck lock and $28 for the 3” ID AR500 pipe and $40 for powder coating and who knows how much Argon shield gas and MIG wire. The other steel I had on hand.
I could have bought one for less, but man it was a fun project.
My motto:
Why buy it if you can spend twice as much time and money and make it yourself?
Old 10-08-2018, 03:55 PM   #2462
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by RFP View Post
Ah ha... hitch jewelry!
Maybe I should have it CHROMED or GOLD plated
Old 10-08-2018, 03:56 PM   #2463
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Originally Posted by GMFL View Post
Here is a link to the hooks I used.
https://www.tractorsupply.com/tsc/pr...-5-16-in?rfk=1
They match the factory ones.
Thanks Ronnie, that hook is rated at 4700 lb according to the manufacturer. SO I think it will be fine and the coupler I selected above will as well, as it is even higher rated.....
I just like the screw bolt link better than the hook. Used them on my boats for years with no issues. Something they get stuck in the closed position and you need a wrench to unscrew.
Ive never had one come loose, but I do check them all the time on trips and at stops etc...
Troutboy
Troutboy is offline   Reply With Quote
Old 10-08-2018, 04:00 PM   #2464
RFP
RFP's Avatar
Hurst , Texas
I think a simple pave diamond setting might be appropriate !
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 10-08-2018, 04:00 PM   #2465
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yep Rich. I agree, both will work fine.
Old 10-08-2018, 06:38 PM   #2466
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Crap work be Airstream.
Ok guys here’s a couple of good one fo you.
Last week on our camping trip I had a small water leak show up in the plumbing. It was leaking at the back side of the city water hookup (where the female pex connector screwed to the pressure regulator). The fitting was loose so I tightened it and the leak stopped.
Me not being content with that I decided to remove the bathroom vanity so I could get a better look and make sure it did not happen again. Here’s a few thing I found.
Airstream had some kinda female to female pex adaptor in-line with the sink water hook up. I’m going to swap out for a crimped pex female connector straight to the pex supply line and do away with Airstreams gizmo. Also noticed Airstream did a not so wonderful job of crimping the male connectors. (If I remember correctly from when I took the factory tour these pex lines were pre made on a work bench so there is no excuse for this because it was not like it was crimped in a tight spot).
ID:	324757   Click image for larger version
Old 10-08-2018, 06:41 PM   #2467
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
More Crap....
I also decided to take a peek under the furnace vent into the gray tank and this is what I found.
ID:	324760   Click image for larger version
Old 10-08-2018, 06:42 PM   #2468
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Repair
This is what I did to fix it. The 2” hole in the plywood was already ready cut I just had to cut out the vinyl flooring to open up the hole and allow heated air to enter more freely.
ID:	324763   Click image for larger version
ID:	324765   Click image for larger version
Old 10-08-2018, 07:31 PM   #2469
Troutboy's Avatar
Parker , Colorado
Ronnie, any advice on how to take the vanity out. That is just unreal to me, and now I won’t be able to sleep when we go out in the mountains where it drops below freezing. Which by the way in Colorado is most of the time!
Troutboy
Old 10-08-2018, 07:33 PM   #2470
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Rich,
Call me it’s easy to access. You don’t have to take the vanity out. Just pull the bottom toe kick.
Old 10-08-2018, 09:00 PM   #2471
Registered User
2016 25' Flying Cloud
Fairfield , California
Now we are talking, put a trailer on one those to slow the crooks down from stealing your diamond encrusted hitch lock.
Do you think a 23ft would be sufficient?
Matti
Mattirs is offline   Reply With Quote
Old 10-08-2018, 09:04 PM   #2472
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Now that’s overkill!
Old 10-09-2018, 04:38 AM   #2473
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
If I had such a lock, I wouldn’t feel safe at anything less than 34 ft.
Clint
Is taking it all with you, really getting away from it all?
Fair_Enough is offline   Reply With Quote
Old 10-09-2018, 06:24 AM   #2474
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
This is interesting! I am going to check all my duct connections. When the furnace has been running, I’ve felt the airflow in the bathroom and bedroom and they are pretty weak. Makes me think every one of the pass throughs might be blocked. We haven’t been camped in a hard freeze yet, but some good frosts.
Thanks for sharing this. Hopefully folks from outside the 23CB community see it. (I check here almost daily to see great tips like this.) even though I’m a FBer instead of a CBer.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
GettinAway is offline   Reply With Quote
Old 10-09-2018, 06:47 AM   #2475
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
The 23D Thread is your one stop shop for everything!
We are the WalSamCoProShopWorldBela’s of Airforums.
Old 10-09-2018, 06:57 AM   #2476
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Clint
I could have done some nice file work around the edges, but I was not sure how well it would show up under the powder coat.
ID:	324814   Click image for larger version
Old 10-09-2018, 07:27 PM   #2477
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Cool pic made the local paper today. We are on the right.
Old 10-09-2018, 11:19 PM   #2478
Registered User
What found is there is about 12' of duct hose stuffed in where you need about 8'. I took off the panels pulled out as much ducting as I could, then cut off the excess. After doing that the air flow was better from the furnace.
Matti
Old 10-10-2018, 11:11 AM   #2479
Troutboy's Avatar
Parker , Colorado
Matti
I did the same Matti and agree.
Ronnie, I was thinking about that hole in the floor. Could it be that they did not want all the air going down there, so they STRATEGICALLY cut a small hole to moderate or reduce the airflow for optimal flow in the belly pan.
Now that it is unrestricted, maybe all of your air is going there and not to other spots.
But, then I remembered, it’s AS, so likely just some dude trying to meet a quota and thought that would do the trick.
Troutboy
Old 10-10-2018, 11:44 AM   #2480
Portland , Oregon
Rich,
When I first saw that picture, I wondered the same, thinking perhaps the restricted airflow was intentional.
But Ronnie said: "The 2” hole in the plywood was already ready cut I just had to cut out the vinyl flooring to open up the hole and allow heated air to enter more freely."
Then, I thought: If they intended to restrict the airflow by cutting the vinyl accordingly, then why bother to cut a full 2" hole in the plywood?
I soon came to the conclusion it was not intended, but rather a production mistake.
Cheers,
Bryan
blacklab is offline   Reply With Quote
23d
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
