09-26-2018, 07:01 AM
#2401
2014 23' International
Hurst
Originally Posted by GMFL
Here’s a few pics of today’s progress. Slow and steady.
Managed to cut/file a square hole in the round face plate.
OK, now you're just showin' off
09-26-2018, 06:21 PM
#2402
2015 23' Flying Cloud
Copper Hill
, Virginia
Safety chains
I’m going to go with very tight tolerances on this and also add a way for the chains to be secured.
GMFL, I have an idea to run by you concerning those safety chains. Is there any reason the chains can't be detachable from the trailer the same way you would detach from the truck? If so you could just take them off the truck and trailer and store them away. Just a thought, Scott
09-26-2018, 06:35 PM
#2403
Overkill Specialist
2020 30’ Globetrotter
Dadeville
, Alabama
Scott,
That’s a great idea. Never thought about that. Simple and super effective. I’m in the trailer now and it’s raining, but that’s top of the list tomorrow.
Wow you guys are great.
09-26-2018, 06:39 PM
#2404
Overkill Specialist
Dadeville
, Alabama
Originally Posted by RFP
I cut the Hitch ball profile out of a piece of 1/2” AR500 today. Crazy hard to cut that stuff.
https://www.leecosteel.com/ar500-500f-steel-plate.html
09-26-2018, 07:11 PM
#2405
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Why not. Locking slip hook like on the 'truck' end. Or Heavy duty locking caribiners.
https://tulsachain.com/g70-clevis-sl...waAr_AEALw_wcB
http://www.industrialsafetyproducts....oaAuP5EALw_wcB
09-26-2018, 07:24 PM
#2406
2017 23' Flying Cloud
Parker
Love the chain idea! Thanks for posting. Eliminates need for another lock.
Troutboy
09-26-2018, 07:30 PM
#2407
Overkill Specialist
Dadeville
, Alabama
I’m going to pick up two hooks like are on the end tomorrow that way the chains are “reversible”. I also needed about 1” extension on my chains currently so this will take care of that also.
Man Scott that’s a smart idea. Simple yet, super effective.
09-26-2018, 08:41 PM
#2408
Copper Hill
, Virginia
Glad I could contribute! As you know we have been Hardening, improving and accessorizing our 23d. I have been reading a lot on these Airforums. I too want a way to secure our trailer while we are out exploring, a lock of some sort is on my short list. Most of the locking devices do not secure the chains. My list is quite long and I have to keep shuffling the order of my list as priorities change, leaking fan, money and most of all time. We have time as our first big trip is going to be next summer. Scott
09-27-2018, 12:25 AM
#2409
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
On both our 2014 31’ Classic and 2015 23D, the chains are welded to the “A” frame. One would have to either weld a bracket to the frame or drill holes in it to bolt a bracket onto the frame. Either process could weaken the frame.
So leaving one or two links of the original factory chain atteched will still allow for the heavy duty coupling to be used for the rest of the chain.
Note the strength factor of any replacement chain used.
09-27-2018, 07:30 AM
#2410
Overkill Specialist
Dadeville
, Alabama
Mine will be very easy to do. And I need about 1” more chain length anyway. I’ll paint one of the hooks so I can mark which side is for the truck.
09-27-2018, 07:40 AM
#2411
Copper Hill
, Virginia
Mine even easier, the tow chains are connected to trailer with quick links. Very easy to swap them out for the hooks.
09-27-2018, 07:42 AM
#2412
Copper Hill
, Virginia
New hooks would be more secure than quick links anyway.
09-27-2018, 07:48 AM
#2413
New Hyde Park
, New York
Larger gray tank
Hi Ronnie,
Quick trip down memory lane for you - when you replaced your black tank, did you happen to investigate the possibility of installing a larger gray tank on the 23CB? Was there enough room?
Thanks for sharing your knowledge.
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
Airstream Club International #2600
I’d rather be camping is an understatement!
09-27-2018, 04:04 PM
#2414
Overkill Specialist
Dadeville
, Alabama
Bruce,
I replaced the freshwater tank. But yes there are other
“Unoccupied” cells. First that comes to mind would be in front of the freshwater tank right in front of the front axle. You probably could fabricate a new grey tank pan and hold another factory tank just like you have now. This would double your gray water storage. It would require some plumbing and a second gray dump valve. But yes I think this could be done with a little effort.
09-27-2018, 04:06 PM
#2415
Overkill Specialist
Dadeville
, Alabama
Scott,
New Grade70 5/16” hooks purchased today from Tractor Supply.
09-27-2018, 04:34 PM
#2416
Overkill Specialist
Dadeville
, Alabama
Bruce
You could also just swap your current gray tank out for a square tank and increase you capacity by 18gallons.
http://www.ameri-kart.com/RV-Product...ter-Tanks.aspx
09-28-2018, 06:18 AM
#2417
New Hyde Park
, New York
Ronnie,
Thank you for your time with those two options.
Bruce
09-29-2018, 08:46 AM
#2418
Parker
On the chain deal. How do you cut that link? Bolt cutters?
Troutboy
09-29-2018, 10:49 AM
#2419
Overkill Specialist
Dadeville
, Alabama
Rich,
Still camping today but yep. Bolt cutters or angle grinder is the plan.
09-29-2018, 10:59 AM
#2420
Overkill Specialist
Dadeville
, Alabama
Two hooks will store well on the tonge well. This is what I got.
