09-12-2018, 11:32 AM
#2201
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Originally Posted by Silvr_Bullet
Question, do you think it’s an issue by blocking off air circulation?
No, because all I have done is transitioned the airspace around the tops and sides of the fridge from outside airspace to inside air space. This new seal prevents the walls a and fridge from being bathed in hot air.... or the 3/4” walls from being exposed to cold air in the winter make the trailer easier to heat
09-12-2018, 11:36 AM
#2202
Overkill Specialist
Dadeville
, Alabama
Rob,
I used the nice stuff Home Depot sells for 3/4” pipe. It tucks in nicely.
I started at the bottom and wrapped it over the top and cut at opposite corner. Then did the same on the other side. So the top has two layers side by side.
09-12-2018, 11:40 AM
#2203
Overkill Specialist
Dadeville
, Alabama
By doing this you also reduce the cubic feet of air space the fans are trying to exchange which should make them more effective.
Also I think about the fact that Airstream uses the wiper seal with traps that hot air in and does not allow the fans to circulate that air.
09-12-2018, 12:27 PM
#2204
2017 16' Sport
N/A
, N/A
Great Results!!
09-12-2018, 12:32 PM
#2205
2017 16' Sport
N/A
, N/A
Originally Posted by KatherineHB
Did you put this fan in the refrigerator or behind the unit? Amazon reviews suggest in the fridge itself.
Inside the refrigerator my theory is that by promoting a more uniform temperature inside refrigerator results in fewer cycles. Also it helps with areas that freeze.
09-12-2018, 02:06 PM
#2206
2017 23' Flying Cloud
Parker
Originally Posted by RFP
Actually, I was asking about the black pipe insulation...
doh... need to read more thorough...
Troutboy
09-12-2018, 02:10 PM
#2207
Parker
Ronnie,
for those corner gaps you said to caulk, I wonder if using that foam spray would be better? Yes it would stick, but I think that would be fine. From your pics, the fridge would still be easily removed as the foam pipe insulation and backer rod you used would not be sticking to the fridge.
Troutboy
09-12-2018, 02:44 PM
#2208
Overkill Specialist
Dadeville
, Alabama
Foam would work. I used silicone cause I can control it better, but the foam would be fine just gotta be carful not to make a big ol mess.
09-12-2018, 03:13 PM
#2209
2007 23' Safari SE
Annandale
, New Jersey
Ronnie, may have missed it, but did you tape or secure the foam in place, or just compression fit?
Any chance that is going to move around and possibly come loose?
Thinking some double sided 3M tape ?
09-12-2018, 04:47 PM
#2210
Overkill Specialist
Dadeville
, Alabama
Compression should hold it in place it fit very tight. And is wrapped over the top.
09-12-2018, 07:16 PM
#2211
2018 23' International
Minneapolis
I take it that this is what the thermostat/thermostor looks like:
https://www.amazon.com/dp/B00RQNWP2K..._t2_B07117FBMH
I think I will do the pipe insulation method around the perimeter of the fridge and then try to move the thermostat so that the fan kicks in more frequently (both GMFL's suggestions) and see if that is sufficient.
09-12-2018, 07:57 PM
#2212
Overkill Specialist
Dadeville
, Alabama
This is the thermo switch looks like.
09-12-2018, 08:03 PM
#2213
Overkill Specialist
Dadeville
, Alabama
09-12-2018, 08:17 PM
#2214
Minneapolis
Do you have any idea what the stock one cycles on and off at? It seems like it must be at higher temperatures.
09-12-2018, 08:35 PM
#2215
Overkill Specialist
Dadeville
, Alabama
I believe 115 but don’t hold me to it.
09-12-2018, 10:59 PM
#2216
2023 27' Flying Cloud
San Jose
Thought I’d share my answer to the fridge compartment heat issue. I used some leftover DEI floor and tunnel heat shielding that I had from a hot rod build. I only stuck it to the trailer wall sides allowing the fridge to be removed without having to peel anything off. I also curved the top area to promote airflow out the top vent.
09-13-2018, 06:01 AM
#2217
Overkill Specialist
Dadeville
, Alabama
Niiiiice. Can that stuff be purchased at auto zone type stores. I’m thinking about the exposed wall segments in the fridge compartment.
I was looking at Refectic brand stuff but it’s not fire resistant. This stuff is fire resistant.
09-13-2018, 07:56 AM
#2218
San Jose
I usually buy it on Amazon. It’s called DEI Floor and Tunnel Shield II, part 050503. I believe it’s good for temps up to 1400F.
09-13-2018, 08:02 AM
#2219
2007 30' Classic S/O
Somewhere
, South Carolina
Just curious, what is the benefit to the fridge operation?
09-13-2018, 08:20 AM
#2220
Parker
The 23D thread
Mikentosh, that looks sweet. Perfect for this total overkill thread!
How did you secure it in place?
Troutboy
