Old 06-15-2015, 09:29 AM   #1
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Texas trailer owners beware!
Starting this March 1, 2015, any trailer (travel, boat, etc) registered in Texas, will require a current State Inspection prior to each year's license plate renewal. The weight cutoff for this requirement is 4500 pounds for boat-and-trailer. I believe a travel trailer will fall in that same weight limit--but check. Main problem is that the majority of inspection stations will not inspect a travel trailer ( not enough room, etc.). I've called 10 places from auto dealers, quick lube, pep boys and finally found one that services large tractor trailer trucks that will inspect the 30 flying cloud. If you plan ahead and get your inspection prior to your license expiration date, that info will be transmitted to your county tax collector and you will receive your renewal paperwork in the mail as usual. With no inspection on file, you will get what I got--a letter stating you must have the trailer inspected and then bring proof of inspection with the letter to your Co. Tax Collector Office, in person, for plate renewal. Starting the end of Feb 2016 you will have a 90 day period before your registration expires to have an inspection done for seamless re-registration via mail. (Same rule for Autos as they are shifting to a "two steps, one window sticker" program.
This is Texas doing what they do best, make their money from property owners. A call to our state representatives, should be in order, explaining the difficulty of the lack with inspection sites and that we just don't drive a travel trailer through a Jiffy Lube safely every day.
Howard
Howard L. is offline   Reply With Quote
Old 06-16-2015, 01:20 PM   #2
Howard L.'s Avatar
San Antonio , Texas
A follow up after having the trailer inspected today and then sitting for an hour waiting in the Bexar County Tax Collector's office to be issued a license plate renewal sticker:
1. The TX vehicle inspection was a look at the tires and that all running, turn and brake lights were in good working condition--that was it.
2. 4500 pounds and above is the weight cut off for needing the inspection. (I suppose EOW)
3. Starting March 1, 2016 a trailer owner must have an inspection within 90 days of the registration expiration in order to have renewal registration forms sent in the mail. I ask and as of now, there is no option for re-registering your trailer if you are traveling out of state during that 90 days. I just really don't think much thought was put into the problems this new precess is going to cause. If out of state when all this now comes due, I guess, call your local Tax Collector and ask what to do.
4. One last thing. I would recommend keeping your plate registration paperwork in your TV or the trailer. A few decades ago I watched a law similar to this in Florida. In FL the law had to do with proof of insurance prior to the issuance of a license renewal and sticker that applied to your plate. There, the bad guys would use a razor blade, cut under and remove your up to date sticker and stick it on their uninsured auto's license plate. When you got stopped, your license had no current registration showing. I see that same possibility for us here now.
5. Take a good book if you have to visit the Tax Collector's in person.
Old 06-16-2015, 01:35 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Well, Texas trailers have been using the registration sticker on the license plate for years and required proof of liability insurance on SOME vehicle to issue it, so the last part isn't new. Your valid registration should be accessible in the state's computer system, so if someone steals the sticker and you get stopped, the officer should be able to check against your license plate and/or VIN to find that you're duly registered. It's not a bad idea to carry a copy of the registration papers in the glove box, but it's not required for non-commercial vehicles in Texas.
Travel trailers are (and have been for a long time) subject to a safety inspection if your titled GVWR for the trailer is 4501 lb or more. The difference is that this year they're changing the process for getting your license tags (for a motor vehicle OR a trailer, by the way) to require you to get the inspection (which no longer comes with a sticker) before you can renew your registration.
As far as not being in Texas within 90 days of your renewal, well, if you're not a full-time student or in the military you're required to get the inspection in Texas. This has always been true for your tow vehicle, so it's not really a new restriction. Once you get the inspection done, you can still renew the registration by mail or online unless you've waited until the last minute.
— David
DKB_SATX is online now   Reply With Quote
Old 06-16-2015, 01:41 PM   #4
2010 27' FB Classic
N/A , Texas
Howard thanks for the info and especially the update. That saves me a trip to gather information on this new set of rules. I get my inspection yearly in Oct, but now I see I won't have to think about getting the inspection in advance of registration till 2016.
Old 06-16-2015, 01:53 PM   #5
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Its another money grab. As I understand it, small utility trailers may require electric brakes of course this depends on the carrying weight of the trailer.
gaylejoe is offline   Reply With Quote
Old 06-16-2015, 02:14 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you are 'close' to renewal, it might be good to 'get er dun' before you 'trip out'...
I had mine inspected here in my home town... before the 'law' took effect. Next year will be my first 'help' from the new 'law'.
I said years ago.. "People, and politicians, are moving to Texas who are more comfortable with 'taxes', tolls and 'fees' than FREE men should accept." Now they are talking about paying for 'improvements' to I35 through Austin...with ''fees"...and 'Tolls'.... something like 14 BILLION dollars!!!!
Sick.
I hate it when I am right...
Well, for now, this is not too severe...yet.
If out of state when 'due', I will 'inspect' when I return to the Republic.. if it still exists.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-16-2015, 02:42 PM   #7
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Have had this sort of garbage in PA for years. Inspections can only be done by authorized trailer inspection locations - RV dealers almost all have the necessary license. Then things like motorcycles must be inspected someplace else. ETC. Money, it's all about the money.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-16-2015, 02:48 PM   #8
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Years ago, when I lived in Indiana, annual auto inspections were mandatory. Independent auto shops could perform the inspections and issue the sticker. We found certain shops that , if included with the state inspection fee, a large Pizza made to the inspectors liking would fast track the inspection and non-hazardous issue would be over looked. Thats more than likely why they don't do them anymore.
tsunami is offline   Reply With Quote
Old 06-16-2015, 03:27 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
This is not a forum for politics. It's fair to discuss the details around the implementation of this new process to push people to get the inspections that have already been required for years, and inconvenience that may result from the way it's been set up.
— David
Old 06-16-2015, 03:37 PM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
As David said, our CRs forbid political stakeholding, for obvious reasons. Please abide!
Lynn
WBCCI 21043
Old 06-16-2015, 04:25 PM   #11
tsunami's Avatar
Images: 20
Will Do!
Lynn
Intent was not to be political. Will abide.
Old 06-16-2015, 04:46 PM   #12
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
How does this effect the many Texas residents in name only full timers? Asking because I am getting ready to hit the road full time and need a legal residence of record. I have heard that Texas may be a good state for that.
MICHAEL
Old 06-16-2015, 04:50 PM   #13
DKB_SATX's Avatar
1976 Argosy 28
You, your vehicle(s) and your trailer would have to be physically present in Texas in your county of "residence" or another county with the same level of emissions inspection at least once per year, and it would be most convenient if that was within 90 days before your registration renewal date.
— David
Old 06-17-2015, 10:58 AM   #14
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Politics and religion two of the most important things to talk about.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Beware, Beware, Beware! carver 1 Airstream Lifestyle 27 04-17-2015 06:03 PM
390, 396XL owners beware! bfred Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 03-04-2010 05:14 PM
GMC 2500HD Owners Beware. boatdoc Hitches, Couplers & Balls 47 08-22-2008 04:23 PM
