Old 03-06-2010, 05:57 PM   #155
Baltimore , Maryland
Originally Posted by 47WeeWind View Post
aircooled4:
The 14.5" tubeless wheels and tires were used by Airstream only on 1958 trailers. Ditch them and replace them with 15" wheels and tires, which are far more common and far more easily replaceable today. Search the Forums for others' comments and experiences on replacing their old 14.5" wheel and tires. I don't think you should have any problem fitting the 15" replacements in your wheel wells, but first see what other who have done this say about their experience. Make sure the new wheels you purchase have the same bolt circle diameter and same (or slightly larger) size center hole as the 14.5" wheels. Take in an old 14.5" wheel for matching when shopping for 15" wheels. Good luck on your continuing WT journey!
Fred, that is not so easy on the 59 models. The hub face is slightly different than most. Some of us like that low rider look and 14.5 " are very easy to find if you look under "mobil home tires"
Old 03-06-2010, 06:00 PM   #156
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
Some Pics for You!
Ok, here are a few pics from today's adventures:
Here's the route Jay and Kirt took to get it out of it's resting spot of 10+ years... that's some deep snow!
Jay tightening lugs once it was up on the road:
Hooked and ready to go:
Down the road:
Uh oh... stuck on the side of the road:
Where she sits tonight :
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 03-06-2010, 06:11 PM   #157
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Thanks for the tire advice! Jay also had been told that mobile homes come with the 14.5"; however, we were also told that they're not very good quality generally, simply because they're supposed to get the mobile home from point A to point B, not necessarily built for traveling.
Jay dropped off the innertube; our friend laughed and said he had put innertubes on much worse tires than what we gave him! So hopefully we'll be good to go tomorrow. Once we get it home, we're probably going to have quite some time to ponder the wheels and which direction we want to go with them. There's a long road ahead of us before we actually need to worry about regular travel!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 03-06-2010, 06:14 PM   #158
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Thank you. with the # of the telephone junction I can find the GPS coordinates, load up 4 15" tires and rims and be there in 6.5 hours ... (HEH, HEH, HEH!)
Xbob2 is offline   Reply With Quote
Old 03-06-2010, 06:32 PM   #159
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Actually, you could probably get a better idea from the road sign!!
Come on up... Jay would love the help tomorrow!!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 03-06-2010, 06:42 PM   #160
1962 28' Ambassador
1962 30' Sovereign
HAH! You got me babe!
Old 03-07-2010, 06:35 AM   #161
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Crazy Day!!
Ok, so it's going to be a CRAZY day for us! Pray that it all goes smoothly!
I've been keeping 2 of our horses at a friend's house since Nov. as one fo them had surgery. Jay's been working frantically to get our barn set up so we can bring them inside at night; otherwise they just had a shelter. I'm supposed to bring them home today.
SO, I'm going to feed the horses, but will not clean stalls since they're coming home; run to Tractor Supply for bedding and a new water tank for the horses; hook up the horse trailer and retrieve the beasts; hopefully the AS tire is delivered during that time, and we'll drive up to get the AS; tow her home and "tuck her in" to her new parking place; then take off with my daughter for a 2.5 hour drive to look at a show pony for her. I'm already tired and we haven't even started!
But as long as we get the AS home today safe and sound, we're calling it a good day!!!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 03-07-2010, 06:53 AM   #162
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Two weeks ago today I brought home a 1957 Overlander. The snow would have been to much for my truck. I was real lucky that there were some great people helping with getting it to the road for me. A snow blower sure helps!!
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 03-07-2010, 07:03 AM   #163
BradS's Avatar
1957 26' Overlander
Images: 14
Oops I had trouble linking the photo
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-07-2010, 07:33 AM   #164
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
I like that! a 3-pt mount snow blower! (I like the AS also!)
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 03-07-2010, 08:04 AM   #165
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
...any ideas WHAT you would put on the extended rear bumper of this 58? a vintage Vespa maybe? Coolers? other supplies?
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 03-07-2010, 09:42 AM   #166
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Wally had one on the front of his International Harvester! You could put one on your back bumper just to watch everybody have a heart attack over rear end separation.
Here's my '59 GS150 - only off by a year!
bredlo is offline   Reply With Quote
Old 03-07-2010, 02:30 PM   #167
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Its home! just got home and parked it behind the barn! no problems today...(all was good once the tires were properly aired up!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 03-07-2010, 02:33 PM   #168
1962 28' Ambassador
1962 30' Sovereign
Yea! Congratulations!
Newbie with an oldie jeeper50 Member Introductions 8 04-23-2010 02:22 PM
What's This Oldie? TinShack Classic Motorhomes 1 10-16-2009 08:49 PM
Yet another rescued oldie 69trotter Member Introductions 10 06-20-2009 12:52 AM
help for a newbie with an oldie new2air General Repair Forum 5 06-11-2009 12:57 PM
Newbie With An Oldie '73 72BamaStream Member Introductions 13 06-11-2008 07:48 PM
