Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 11-13-2014, 10:54 AM   #1
2014 30' Flying Cloud
Dandridge , Tennessee
Shower door fix
I too had a problem with the shower door being too low, thus tearing the seal off the door bottom.
I bought a 3/8" nylon bushing at the hardware department.
I inserted it under the hinge end of the door. I used a self tapping screw to hold it in place.
Attached is a sidewise pic
dmotwell is offline   Reply With Quote
Old 11-13-2014, 12:17 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I might have to do that also as I need to replace the seal. Did you need to remove the door to do that or does the bushing just rest under the door? I do not get how you installed the bushing. Thanks
Larry
lsbrodsky is offline   Reply With Quote
Old 11-13-2014, 01:22 PM   #3
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Lsbrodsky, the vinyl seal under the door is really easy to replace.
Pull the old away from the bottom of the door and squeeze insert the new, then trim to fit.
Toward the hinge side, note a small sliver of vinyl bead has been shaved away to ensure a better fit.
2013 25 FC FB (Twin)
2013 Suburban 2500
https://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 11-13-2014, 01:52 PM   #4
lsbrodsky's Avatar
I wanted to know how DMotwell installed the bushing in case that was the root cause of my seal failure, but thanks.
Larry
Old 11-13-2014, 10:29 PM   #5
I left the door on. I just raised the door up and inserted the vinyl bushing.
I installed the self tapping screw simply to hold the bushing in place.
After this was done I inserted the vinyl seal.
Old 11-14-2014, 04:10 AM   #6
lsbrodsky's Avatar
Thanks!
Larry
Old 02-25-2015, 11:11 PM   #7
1995 34' Excella
Cochrane , Alberta
Send a message via Skype™ to johnf
The pins at the top and bottom of the door screw out. Screw out top, lift door, insert nylon bushing, replace door and upper pin.
johnf is offline   Reply With Quote
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 27 10-02-2022 06:12 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
Fix for door, screen door combination, jammed slider DaveFL Land Yacht/Legacy Motorhomes 0 11-05-2009 08:26 AM
Fix pilot assbly, replace unit, or shower head instant HW? kdenault Water Heaters, Filters & Pumps 1 07-24-2006 08:28 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
