Old 02-17-2019, 01:28 PM   #1
Sewer smell under bathroom sink 25ft airstream international 2015
We are at a campground where they come and pump your tanks
Today they pumped it and there is an open hole under the sink in the bathroom and it smells horrible. Sewer smell
What could have happened and what do we need to do help
The tank was 100 % full
Please help we have 10 more days and not sure we can stay unit with that smell
HeikeET is offline   Reply With Quote
Old 02-17-2019, 02:52 PM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Open hole under the sink? Picture would help, shot in the dark guess is the air admittance valve failed from the vacuum the truck put on your system.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is online now   Reply With Quote
Old 02-17-2019, 04:00 PM   #3
Tried to attach a photo
How do you fix the problem you mentioned
Old 02-17-2019, 04:00 PM   #4
Originally Posted by heikeet View Post
tried to attach a photo
how do you fix the problem you mentioned
Old 02-17-2019, 04:02 PM   #5
Looks like the lavatory sink may drain into the black tank as well ????
Old 02-17-2019, 04:13 PM   #6
AlinCal's Avatar
1991 25' Excella
So if it is the air admittance vavle its probably just indide the wall opening, you can try covering it up with a bag and tape to seal until you can replace it. They normally unthread.
The use of a pumper truck sucking your tanks empty was talked about some time ago, you can lessen the chance of vacuum damage by holding the toilet flush open during this process.
Also ask the driver not to use maximum suction.
Will Rogers
Alan
Old 02-17-2019, 04:25 PM   #7
2007 22' International CCD
If they used strong suction to clear your tanks, you may need to refill the sink trap with water. Run about 2-3 cups of water down the sink and see if the odor ends.
rmkrum is online now   Reply With Quote
Old 02-17-2019, 04:36 PM   #8
Thanks so much
Old 02-17-2019, 04:38 PM   #9
Originally Posted by HeikeET View Post
Thanks so much
Do you have to order that valve from airstream ?
Old 02-17-2019, 04:48 PM   #10
AlinCal's Avatar
1991 25' Excella
Any plumbing supply and possibly big box like home depot. They are usually 1-1/2" pipe thread.
https://www.amazon.com/s/?ie=UTF8&ke...sl_3b6tzwwde_b
Will Rogers
Alan
Old 02-17-2019, 04:51 PM   #11
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Make sure you’ve got some water in the P-trap for the bathroom sink per post #7 above....
wulfraat is online now   Reply With Quote
Old 02-17-2019, 05:17 PM   #12
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Along with the P-trap mentioned above, you also need to get your blank tank primed for the next use cycle, and make sure you have water in the toilet bowl to give you a water seal between the tank and bathroom.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 02-18-2019, 06:30 AM   #13
Great ...all this helped tremendously
When you say black tank primed
What do you mean. I do understand the part about the water in the toilet
Also other than flushing out the black tank ... mine has an exterior hose connection that rinses the black tank ... is there anything else anyone does to clean the black tank
Old 02-18-2019, 09:38 AM   #14
2015 25' FB Flying Cloud
The Woodlands , Texas
We get bad odors in our 2015 25FC from time to time, especially when running the bathroom or shower exhaust fan, the exhaust hood over the stovetop, or the Fantastic fan. Finally figured out that, yes, the bathroom sink is piped to the black tank. Also figured out that after long periods of storage with a dehumidifier running, water in the P-trap evaporates and the sink drain provides an unobstructed connection for vapors to be pulled out of the black tank into the trailer. Running a little water into the sink fixes this.
Bilbo is offline   Reply With Quote
mystery leak under bathroom sink --- how to access? monkeydance Fresh Water Systems 0 02-29-2016 10:48 AM
How do I remove leaky sink drain pipe, bathroom sink, 1970 Sovereign NevaH Plumbing - Systems & Fixtures 4 09-14-2015 04:01 PM
Water Damage in Floor Under Bathroom Sink? breezyway Repairing/Replacing Floor &/or Frame 3 11-09-2013 06:42 AM
Leak Under Bathroom Sink ... What to do? pdozanne Plumbing - Systems & Fixtures 4 06-03-2012 11:38 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
