Old 04-13-2014, 06:38 PM   #1
Osogofind
1975 25' Tradewind
Replacing my belly pan and drilled through my black water tank
What's the best way to repair a small drill hole in the bottom of my black water holding tank??
Bwilson11 is offline   Reply With Quote
Old 04-13-2014, 07:17 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I would consider putting a glob of epoxy on a screw and simply screwing it in.
Old 04-13-2014, 08:42 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Your tank is likely made of roto-molded poly-ethylene. It is pretty hard to find glues/epoxies/caulks that will stick to it. If you can find something, then definitely try gooping it up. There was a recent thread where a guy had a leaking fresh water tank in a 2000's vintage trailer. It looked like a spun on fitting had separated from the tank. He said that he repaired it with with some kind of marine epoxy. Maybe worth a try if you can find the thread.
Otherwise, you might be able to repair it with plastic welding, or a spun-on blank fitting (plug).
Old 04-13-2014, 09:02 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Another take on this might be to use a tap, tap threads into the tank, coat a proper sized screw or bolt with epoxy and screw it in.
It it leaks you are out a few bucks and a few minutes, if it works, you are out of the woods for a few bucks and a few minutes.
Is the repair fails, the attempted fix won't screw up anything.
I have a feeling that this fix will work and work well.
Old 04-13-2014, 09:52 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You might try using JB Weld epoxy. It comes on two small tubes.
Another great epoxy is Marine Tex. Marine Tex tends to flow a little before it goes off. You might try mixing a small amount, forming it into a dowel shape, inserting half of it onto the hole, spreading the outside part, then use a hit dryer to slightly hear the area. It may spread the material inside before it starts to harden.
Or, you could use either of these products to heavily coat a screw to plug the hole. That might be the surest method. I would use some 80 grit sand paper to roughen up the area around tho hole to give the epoxy a "tooth" to secure to. Forgive me for using a preposition to end a sentence with.
Good luck.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 04-13-2014, 10:15 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Look for a product called LEXELL in your local lumber store.
Tapping the hole is a good idea. Use a Stainless Steel screw. Apply the LEXELL to the treads. Screw it in.
I swear this stuff will stick to water.
Old 04-13-2014, 10:31 PM   #7
Osogofind
1975 25' Tradewind
Thanks for the suggestions
I'll let ya know if the screw and epoxy / sealent works!
Old 04-14-2014, 07:50 AM   #8
1988 Argosy 32
Lomita , California
Done that way more than i care to rember, you need a O-ringed seal screw.
Call APM HEXSEAL at 201-569 5700 Tell them about it, ask for a free sample.
I think a (OVERSIZE PAN HEAD STAINLESS 10-32 UNF should do it )
WW GRANGER sells them 100 pc box just in case, best of luck-Jim
Wolfe is offline   Reply With Quote
Old 04-14-2014, 11:16 AM   #9
1981 31' Excella II
New Market , Alabama
I like the O-ring sealed screw approach. You can put some RTV over the screw head for added protection.
Perry
Old 04-14-2014, 01:03 PM   #10
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
An O ring or flat rubber washer on a sheet metal screw. I am assuming a small hole but you could probably do this up to a 1/4 inch or more
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-14-2014, 01:53 PM   #11
1981 31' Excella II
By the way, you can get short double ended sheet metal drill bits at mcmaster.com. You can chuck them up in the drill so that only about 1/2" protrudes. This makes it a lot less likely that you will drill through the tank. Usually there is about 1" of foam under the tank.
Perry
Old 04-14-2014, 02:02 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Drill the hole bigger, get a rubber well nut, tighten with a stainless bolt. I suspect epoxy will not stick! If you must try glue, I suggest gorilla glue. It will expand on both sides effectively making a seamless 2 sided cork. You don't want this to fail with the pan in place with your wife and kids away from home. Deal breaker!
AtomicNo13 is online now   Reply With Quote
Old 04-14-2014, 02:06 PM   #13
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
3M 5200, made for marine use. It is rated for use below the waterline on boats. Should stick to anything.
Cannonball is offline   Reply With Quote
Old 04-14-2014, 08:26 PM   #14
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
"Everything should be as simple as possible but not simpler."
-Albert Einstein
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
waste water tanks falling through belly pan Massey Waste Systems, Tanks & Totes 7 10-22-2013 11:59 AM
Drilled a hole in water tank, HELP bmklawt Fresh Water Systems 18 07-12-2009 10:00 PM
Dropping belly pan that covers black and grey tanks? casarodante Waste Systems, Tanks & Totes 20 06-10-2007 01:15 PM
Oh no! I drilled my holes to big. What now? HamiBambi Ribs, Skins & Rivets 8 05-30-2006 08:40 PM
