Old 04-14-2014, 11:46 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Replacing my belly pan and drilled through my black water tank
If a decent epoxy is applied to clean, dry, freshly cut threads it will stick and damn good,
A person could add some insurance by scuffing the area where the screw or bolt head will contact the bottom of the tank just to be sure if there are any doubts. (I would scuff it aggressively)
Epoxy WILL form a mechanical bond to abs to the effect of sealing the threads of a screw against a gravity leak no problem.
Old 04-15-2014, 06:10 AM   #16
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I used J B Weld epoxy. Excellent results. Make sure you drain the tank and let it dry. Apply and let sit for 15 hours as the instruction say. Worked like a charm. Nothing like a water leak to frustrate the you know what out of someone, good luck.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-19-2014, 01:47 PM   #17
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
I build green underwater fishing lights. Have for years. I use a two part M. grade epoxy and I've never had an issues. The stuff is bullet proof and once applied wont come off or leak. Just sand area to give epoxy something to grab onto clean and let it stand overnight. Im sure it will work. Let me know if you have any question as to where I got the stuff.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 08-23-2014, 09:14 AM   #18
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi All, I worked in a rotomold plastic shop for four years. Polyethylene is a thermoplastic. The cross linked versions and nylons are not. So we repaired many, many leaky tanks by "welding" polyethylene to polyethylene at about 300 degrees. We had "wire feed" heat guns that would feed the poly into the heated area, similar to a hot melt glue gun. Otherwise finding a stick of polyethylene and using a hot heat gun, or soldering iron, you can melt the hole and feed in new poly. Let it form a glob and then sand it smooth when it cools.
Polyethylene tanks are very repairable. Like others have said, we did not find any adhesives that would hold on it. But we puddled polyethylene into some pretty big holes and then sanded with Scotchbrite disc so you couldn't tell it was repaired.
Practice on some scrap pieces first. It isn't hard. Even I can do it!
David
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
waste water tanks falling through belly pan Massey Waste Systems, Tanks & Totes 7 10-22-2013 11:59 AM
Drilled a hole in water tank, HELP bmklawt Fresh Water Systems 18 07-12-2009 10:00 PM
Dropping belly pan that covers black and grey tanks? casarodante Waste Systems, Tanks & Totes 20 06-10-2007 01:15 PM
Oh no! I drilled my holes to big. What now? HamiBambi Ribs, Skins & Rivets 8 05-30-2006 08:40 PM
