02-12-2012, 03:50 PM
2011 28' International
Bradford
, Massachusetts
Replacement mattress for my serenity
Any suggestions ?
Love my airstream
Not to happy with the mattress.
02-12-2012, 03:57 PM
1999 30' Excella 1000
Nellysford
, Virginia
We love our TempurPedic in the back of our Queen Excella.
Greg and Linda Heuer
'99 Excella 30 w/HAHA - The Silver Otter
'08 Chevy 2500HD 6.6 DuraMax w/MBRP dual pipes
TAC VA-18 | WBCCI 1927 - Unit 149 | AIR 53869
http://www.linkedin.com/in/gheuer
02-12-2012, 04:03 PM
Bradford
, Massachusetts
Did u you have to have it custom made with the rounded corners
02-12-2012, 04:06 PM
A.K.A "THE STREAM"
2010 25' FB International
Arlington
We put a down very thick mattress pad on our bed and love it. Firm and soo soft and comfortable. We love it!
shane
02-12-2012, 04:10 PM
2007 31' Classic
Athens
, Alabama
We replaced our mattress with an RV queen size but doesn't have the notched corners. Works just fine. In fact, sheets are much easier to find and don't cost as much.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
02-12-2012, 04:13 PM
Bradford
, Massachusetts
What was the size you ordered
In the specs it was 60x75
Nellysford
, Virginia
No, we make do with the fact it's a little long. The comfort, the ability to use our standard linens, and 26,000 miles, 29 states, and one province have proved the concept.
02-12-2012, 04:14 PM
Bradford
, Massachusetts
shane
We did the same
Still not that comfortable
02-12-2012, 04:19 PM
1995 30' Excella
Logan
, New Mexico
We bought 4" of memory foam from overstock.com and put it on top of our mattress. Made a hugh difference.
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
02-12-2012, 04:21 PM
A.K.A "THE STREAM"
Arlington
We did the same
Just want to be clear....we put on a "down feather" thick mattress pad.
I re read it and it looked confusing to me. Good luck in your search,..btw, out pad costs as much as a new mattress, I'm sure.
Shane
02-12-2012, 04:22 PM
2006 28' International CCD
Nashville
, Tennessee
You may want to check out this link. After hearing all kinds of good things about his product, we just made a purchase for our at-home bed. We've only had it a few days now but so far we love it. They have a 120 day return policy (they pay the shipping) so you've really nothing to lose by trying them out. They stock an rv queen and I believe they also do custom.
bedinabox.com
Debbie
Bradford
, Massachusetts
My mattress topper is only a 2 inch
I may try the 4 inch before I go and invest In new mattress
02-12-2012, 04:44 PM
2008 25' Safari FB SE
Crawford
The OEM mattress has long been the subject of complaints. We bought a 2" topper rated "medium". They had hard, soft and medium, and not knowing anything, we chose medium. It is comfortable. You might try to add another 2" soft one to get the feel you want.
The bed was too short for us, so I screwed a piece of plywood to the luan plywood under the bed and moved the mattress down 4". My wife made a bolster out of scraps to fit in the space at the head of the bed and I cut a piece of plywood to fit into the bottom of the bolster—this gives fitted sheets something to hold onto. We use standard queen sheets, a lot cheaper than special RV sheets.
Gene
02-12-2012, 05:03 PM
We had a local mattress factory duplicate the factory foam mattress' in our 25 Safari with rounded corners. New mattress' are inner spring and are much better than the skimpy foam pads which came stock. Cost for two twins was a little over $400.
They were still not soft and supportive enough so we purchased memory foam pads (about $70 a piece) at Costco and cut them to fit.
Now we wake up without pain and stiffness.
| Thread Tools |
| Display Modes |
