Join Airstream Forums Today
Old 02-12-2012, 05:22 PM   #15
The Silver Bullitt
Xenomorph's Avatar
1976 27' Overlander
Ventura , California
You could look at the selection of knockoff tempurpedics at Walmart.com. I got a queen memory foam shipped for around $260. Not quite as good as the real deal but the value is there and a major upgrade. You want two layers of foam. Usually a base layer of high density(Hard) foam 5" or so and then topped with a 2" or 3" memory foam(Soft). You need that base layer otherwise you would sink into the mattress. I used to make futons and foam mattresses at my old job. Any resizing of the foam can easily be done with an electric carving knife. No joke. Lay the matrass on a large flat surface. Make sure it is pushed as small as possible from each side and square. Using a straight edge mark up with a sharpie. Then using the electric knife trim down the line. Best results will come from many shallow cuts down the line versus one long deep cut. One deep cut tends to give a sloped edge that isn't very square.
Xenomorph is offline   Reply With Quote
Old 02-12-2012, 05:57 PM   #16
Past Prez.NEU/Membership
AirHog's Avatar
2005 34' Classic
N Smithfield , Rhode Island
Images: 21
Hello Bjlecki,
We just sent you a PM, maybe we can help, as we live near you in RI.
T & Gail
2005 34'Classic- Mercury (Goddess of Travel)
2004 Yukon Denali
WBCCI #2905-NEU
AirHog is offline   Reply With Quote
Mattress Moisture Problem? palmer51 Winterizing, Storage, Carports & Covers 34 12-04-2011 07:01 PM
New member in central NY + mattress question rlewis Member Introductions 7 10-25-2011 06:40 PM
2011 28' Serenity Purchase nessie1020 Buyer Guidelines 9 08-16-2011 07:33 PM
Cutting down a sprung mattress mamos Upholstery, Blinds, Walls & Interior Finishes 7 07-17-2011 03:03 PM
Sources for Custom Mattress in Oregon - SW Washington TGK General Interior Topics 8 06-08-2011 08:53 AM
