Old 06-16-2019, 02:02 PM   #1
Johnson City , Arkansas
Refrigerator condensation
We have a 2017 25’ Rear Queen Flying Cloud. Frig takes a while to cool down, but my real question is that we get a lot of water (assuming condensation) in the bottom of frig. Does anyone else have this problem? Does anyone have a solution or is this something we have to live with?
Willk is offline   Reply With Quote
Old 06-16-2019, 04:49 PM   #2
Flht2k's Avatar
sacramento , California
Yes. Look at tray, you will notice when you pull it out that it has a pipe that goes into the hole. I installed an oring on the tube, get a thick one. That is a little smaller than the hole. Push in. Presto.
Flht2k is offline   Reply With Quote
Old 06-16-2019, 04:53 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
use a small circulation fan
it is a must if you are in a high humidity area
these fans make our fridge a more consistent temp and reduces frost build up
cheap and easy to make
Name:	fan in fridge.jpg
ID:	343559   Click image for larger version
Name:	fans in fridge-1.jpg
waninae39 is offline   Reply With Quote
Old 06-16-2019, 05:04 PM   #4
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Yep fans are a must.
ID:	343561   Click image for larger version
Dept of “OverKill”
Old 06-16-2019, 06:27 PM   #5
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Originally Posted by Willk View Post
...that we get a lot of water (assuming condensation) in the bottom of frig. Does anyone else have this problem? Does anyone have a solution or is this something we have to live with?
If your AS isn’t level condensation may not drain properly. Also the tray ‘spout’ could be too short. We solved this issue by attaching a short piece of tubing and directing it down the outlet hole.
az-streamer is offline   Reply With Quote
Old 06-16-2019, 06:43 PM   #6
Thanks!
Old 06-16-2019, 06:44 PM   #7
Thanks!
Old 06-16-2019, 06:46 PM   #8
Attachment 343565
Attachment 343566
Attachment 343567
Attachment 343568
Thanks! Sounds like this might be a good solution.
Where does refrigerator condensation drain go? m.hony Refrigerators 23 01-17-2017 01:38 PM
Where does refrigerator condensation drain go? HowieE Plumbing - Systems & Fixtures 19 09-08-2016 09:34 AM
Window condensation Seon Windows & Screens 5 03-16-2003 10:19 PM
bed condensation kooblekidz Airstream Motorhome Forums 7 01-16-2003 08:52 AM
Window condensation????? Anna Windows & Screens 1 10-28-2002 10:51 PM
