Old 09-26-2012, 05:16 PM   #1
RogerLG's Avatar
Alexander , Arkansas
Pump won't prime!
Hey All I have a 1979 ambassador 28 ft. I'm redoing the leaks... And now my pump won 't prime ... It runs and I hear water gurgling but not much comes out... Any advice?
RogerLG is offline   Reply With Quote
Old 09-26-2012, 05:21 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
If there's water making it to the pump, and nothing coming out, bets are that the pump is, well, dead.
Lynn
WBCCI 21043
Old 09-26-2012, 05:24 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
Which Pump?
Is it the original PAR or an after-market replacement? If this question makes no sense, kindly take a picture.
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 09-26-2012, 05:26 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
This can also be a symptom of a bad check valve (or no check valve!) at the city water inlet. That's a pretty good description of what my pump was doing the first time I used it... turns out that when the PO replumbed he didn't include a check valve at the city inlet, so I just cap that when using the pump. Check to see if it spat any water out the city water inlet while the pump was running before you start with the pump.
Also make sure there's no place for it to suck air between the fresh tank and the pump inlet.
— David
Old 09-26-2012, 05:33 PM   #5
SteveH's Avatar
Common Sense , Texas
I've had various camper pumps do that over the years, and this sounds sort of remedial, but open only one faucet, and put your mouth under it and suck with the pump running.
If there are no leaks, you will draw water up into the pump to prime it.
Old 09-26-2012, 05:48 PM   #6
KYAirstream's Avatar
Northeastern , Kentucky
Once I couldn't get my pump to prime. Took it apart, messed with it, and still couldn't get it to work. For some reason I decided to open a drain valve on the outlet side of the pump (like you would do to drain fresh water tank) and it primed right up.
KYAirstream is offline   Reply With Quote
Old 09-26-2012, 08:10 PM   #7
RogerLG's Avatar
Thanks all... Found the leak under my closet! Repaired and voila! WATER and pump shuts off.....now on to the propane and propane accessories issues!
