Join Airstream Forums Today
Old 09-02-2009, 07:23 PM   #1
Airstream Newbie
Torrance , California
Parking question..
Hi all again.. In my quest to get answers before I decide on a AS size, I'm curious as to whether you think I could pull this off or not..
I've got a driveway that is on a slight incline (not sure what the angle is but not too bad) and I believe is ~25' wide (haven't yet measured -- will do that tonight).. I can't put a 25' trailer in the driveway w/o blocking the sidewalk, which won't fly w/ city officials.. So, I was thinking about putting it sideways at the top of the driveway near the garage door (parallel to the street & sidewalk)... Here's the hard part. I don't have sufficient space to completely move a trailer that size into position while hitched up (unless I can find a hitch that's about 4-5' long) without driving on my neighbors lawn. I was kinda thinking in my head (yeah, a bad idea) that perhaps I could attach one of those single (or double?) hitch wheels and do the final positioning after it's unhitched by hand assuming the majority of the weight would be resting on the dual axles. Does this sound like a really bad idea or a possible solution for not parking it on the street,etc.? I really don't want to park another trailer in the expensive RV storage joint if I can get away from doing that..
Hope this makes sense.. Comments?
Oh yeah.. This is more or less what I was thinking about using..
Rick F is offline   Reply With Quote
Old 09-02-2009, 07:41 PM   #2
Images: 14
The incline ...
is probably the killer. I have a power caster which is a fancy version of the device in your picture with an electric motor. It will push my 19 ft trailer up my slight incline but I always have to have another person standing by with a thick board to throw under the wheel to act as a brake. I can not stop the trailer by hand once it starts rolling down the incline. Likewise I cannot push the trailer up the incline by hand either.
Try pushing your car up the incline. It will give you an idea of how hard it will be to move a trailer uphill.
Power Caster,electric trailer mover dolly, boat dolly, toy hauler
bjond is offline   Reply With Quote
Old 09-02-2009, 07:46 PM   #3
azflycaster's Avatar
1975 25' Tradewind
Phoenix , Arizona
Images: 67
I had one of the dollies that you posted the picture of. It was great for my very small pop up. I doubt you could lift the tongue off the ground on an Airstream without breaking the dolly.
Richard
Charter Member Four Corners Unit
Old 09-02-2009, 07:53 PM   #4
moosetags's Avatar
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
What you are describing might work, but would really limit the size of Airstream that you may be able to accomplish this with.
If the grade of your driveway extends to the garage door, this would make it even more difficult. One of those trailer dollies that you pictured would be nearly impossible to use with any upgrade, and very dangerous going the other way.
Post a couple of pictures of your driveway area. Someone here might have an idea for you.
Brian
SuEllyn & Brian McCabe
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2011 Silverado 3500 (Fred) with Outfitter Truck Camper (Ethel)
Old 09-02-2009, 09:23 PM   #5
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
A power caster is the only way to go. Maybe your neighbor wouldnt mind letting you in and out with it. It's not and everyday thing I wouldn't think. Depends on the neighbor as well....lol
On the other hand, there are always option. Moosetags has a good idea, pictures are worth a thousand words. There are some pretty crafty people hereabouts!
Alwhisman is offline   Reply With Quote
Old 09-02-2009, 09:43 PM   #6
moderator
Airslide's Avatar
2001 30' Classic S/O
Novato , California
Images: 47
Send a message via Yahoo to Airslide
I use one of those trailer dollies as pictured for the featherlite car trailer. It weighs in at 1200 lbs with a tongue weight of a little over 100 lbs.. It takes everything i can do to turn those dual wheels in gravel and my feet are on cement with a slight incline.. If you can move an airstream with it your my new hero..
Vin
Air-safe / Reese dual cam
2011 Dodge 3500 Diesel
6 speed manual 4x4
Airslide is offline   Reply With Quote
Old 09-02-2009, 10:19 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 170
Parking question..
I don't know whether this might help, but it occurred to me that one of the selling benefits was always advertised as a greatly reduced turning radius for the car/trailer combination -- particularly with the 90 degree model. What I am thinking of is the Pull-Rite Trailer Hitch it is a proven design from a manufacturer who has been in business for a number of years. Friends who have towed with this hitch for several years have been very pleased with its performance.
This is just a thought -- that may not be practical for your circumstances.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 09-02-2009, 11:33 PM   #8
Airstream Newbie
Thanks all for the great feedback.. I was a bit curious what you all thought of the dolly things for this purpose... I think using a traditional hitch on my C2500 truck, I could get things about 75-85% in place but the last ~15% of the work might need to be done another way (unless the Pullrite can allow my truck to move to a 90 degree position w/o pinching either the truck or trailer).. I dropped a note to the company asking some questions.. Once I measure the width of the driveway, that ought to also factor into my length equation..
Old 09-03-2009, 01:43 AM   #9
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 170
Parking question..
Something else occurred to me as I was looking through the thread. Another option, again I don't know how practical would be a custom front hitch on the tow vehicle. What I am thinking of would require custom fabrication such that the receiver would be offset to one side or the other of the front bumper - - if sufficient offset were possible along with one of the longer draw bars (designed for use with tow vehicles that have spares mounted on the rear tailgate) it might be possible to gain a sharp enough angle to accomplish your parking goal. Finding a capable welder to do the fabrication might be a challenge with this method.
Kevin
Kevin D. Allen
AIR #827
Old 09-16-2009, 08:34 AM   #10
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Built this (@ $200 parts) to maneuver 31' Sovereign around some trees in the back yard to the monte site. The end of the driveway has @ 1' of rise at @ 15' of run, pushed and pulled with no problem. I should be done with the crushed concrete camper driveway soon. I will then know how the dolly handles in looser ground.
Birdwell57 is offline   Reply With Quote
Old 09-16-2009, 08:46 AM   #11
Mexray's Avatar
1978 29' Ambassador
Morada , California
Bird...like your 'three-wheeler'...did you use a small 12 volt winch for the drive motor - I've looked at the cheap ones at Harbor Freight with the same idea- did you use a couple of gears and a chain to drive the axle?
Ray & Pat near Lodi, CA
Old 09-16-2009, 09:10 AM   #12
bredlo's Avatar
1954 22' Safari
Evanston , Illinois
Send a message via AIM to bredlo
Originally Posted by Mexray View Post
...did you use a small 12 volt winch...
There's another idea. I was thinking about winches the other day as I was trying to hand-push our 19 footer up a shallow incline towards the garage, with little success. A small winch could help pull your trailer into that final position, if you had a sturdy mounting location, depending on your desired location for the trailer.
It'd sure be nice to mount it inside the ceiling of your garage... ready to go when you are.
bredlo is offline   Reply With Quote
Old 09-16-2009, 12:10 PM   #13
Birdwell57's Avatar
1978 31' Sovereign
2,000 lb winch from H.F., go-cart live axle, and hubs, golf cart tires, 12 teeth on winch sprocket, 66 teeth on axle sprocket
Old 09-16-2009, 12:57 PM   #14
Lumatic's Avatar
1967 24' Tradewind
Estancia , New Mexico
Images: 11
OSX the trailer dolly for yur trailer is not a good or safe idea. It is only designed for very small and light trailers. I use one for small sailboats, less than 500#.
Speaking of sailboats a friend of mine uses a lawn tractor for manuvering large sailboats weighing several tons in his tight back yard. He has a hitch on the front and back of his tractor. Because it did not cut grass he got it cheap for $100. That might work for you.
If you are dealing with an incline, it does not take much for a trailer to start rolling. Might be a good idea to be able to get to the break away switch if you need to stop her from rolling down your driveway.
Turn left right here
Parking Airstream? Aluminati General Repair Forum 19 12-14-2007 05:41 PM
New overnite rv parking! codybear Off Topic Forum 8 05-12-2007 08:52 PM
Courtesy Parking..... GT1963 WBCCI Forum 45 04-02-2006 09:26 AM
Who's driving and who is parking? bake315 Our Community 49 04-12-2005 03:58 PM
Parking in No VA robandzoe On The Road... 8 03-28-2005 03:16 AM
