Old 12-22-2012, 08:58 PM   #1
2009 34' Panamerica
weyburn , Saskatchewan
Panamerica what size light plant will run it
I just bought a Panamerica which I believe has larger 15000 air conditioner and wonder if my Yamaha ef2400si inverter will run it. It has run a 13500 air conditioner on old trailer no problem before. Thanks for any help and comments on this trailer since I am a new to airstream and not sure how it will compare to my 2006 okanagon 28 foot double slide trailer which was a very good trailer and well built. I needed a toyhauler and wanted one that will last and not hard to pull so that is why I went with Panamerica
Pedecanada is offline   Reply With Quote
Old 12-22-2012, 11:15 PM   #2
2009 34' Panamerica
[It does not need to be Panamerica trailer just a bigger 15000 ac unit, what it takes for generator size to run it. [/I]
Old 12-23-2012, 12:15 AM   #3
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
We have the 15,000 AC upgrade on our 2009 27'FB. We have a Handi 3000i and it runs our AC without any problem. Sorry, but i don't know about the Yamaha 2,400 si.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 12-23-2012, 07:10 AM   #4
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Your going to need a bigger generator its max is 13500 BTU and I wouldn't try it on a 15,000 BTU. We have the Yamaha 2400 and love it but our AC is 11,000 BTU. Congrats on the Pan America!
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 12-23-2012, 10:05 AM   #5
2009 34' Panamerica
I was afraid it might not work with bigger air conditioner. I will probably try it and worse case it would just kick out which it probably will do. It is to bad since this is a nice generator.
Old 12-23-2012, 10:14 PM   #6
Scott J-24's Avatar
You should be okay with 2 Honda 2000i gennies linked together. I heard this combo works well, don't know if the Yamaha generators can be linked together like the Honda's. But, if they can that may be your best solution.
WBCCI #1215
Air #54601
Old 12-24-2012, 08:28 AM   #7
Images: 59
Worse case, unfortunately, is it won't kick out but continue to run at low voltage and damage your air conditioner.
Old 12-24-2012, 09:22 AM   #8
2009 34' Panamerica
You would think a Yamaha with inverter would have good quality electronics and kick when it should which I have seen it do. The cheap china build generators I would be afraid of doing that.
Old 12-24-2012, 04:01 PM   #9
Images: 59
Well, I guess you're good then.
Go ahead.
Old 02-03-2013, 03:44 PM   #10
2009 34' Panamerica
Got chance to try my Yamaha 2400 lightplant on Airstream with 15000btu ac in my heated shop for 1/2 hour with a/c on high all lights on and inverter on with tv on. That is really impressive for it size. It was working but not to bad.
