Old 11-14-2019, 01:20 PM   #1
Bexar's Avatar
1960 24' Tradewind
San Clemente , California
Nokian Rotiva LT235/75R 15 LRE 116/113S Single Axel Air Pressure
These are installed on my 1960 Tradewind which weighs 4k to 4.5k lbs. Sidewall max pressure is 80psi. Discount tire says to run them at 80psi. Nokian customer service says they donít know proper pressure but 80psi is too high.
Running at 80psi is like running on steel and is beating this wonderful old machine up.
I typically pull between 60-65 mph.
Any single axel Rotiva owners have guidance on proper pressure?
Richard
Bexar is offline   Reply With Quote
Old 11-14-2019, 01:48 PM   #2
2017 19' Flying Cloud
Calgary , Alberta
Surprising that Nokian doesnít have Load/inflation tables similar to what Goodyear has for their Endurance tires.
Ronyx is offline   Reply With Quote
Old 11-14-2019, 02:30 PM   #3
Bexar's Avatar
1960 24' Tradewind
Found this link to a generic inflation chart:
http://www.yournexttire.com/trailer-...flation-chart/
TIRE INFLATION EQUATION:
Tire Weight / Tire Pressure = Load Capacity Pounds per PSI
ďIf the customer runs 65 psi in a 10 ply tire, his capacity is now able to carry 2,507 per tire.Ē
65psi looks like the correct pressure to me.
Nokian Rotiiva AT 235/75R15 116/113S RLS Tires 56 08-14-2019 09:01 PM
Nokian Rotiva LT tires Milo1952 Tires 1 02-12-2018 06:43 PM
info concerning Nokian Rotiva 235/75/15 light truck tire Milo1952 Tires 19 01-25-2018 11:24 AM
LT235 75 15 Goodyear Wrangler Ridgerunner3 Tires 1 04-01-2013 05:29 PM
Fitting LT235/75R15 LR C on our '71 Tradewind... barts Tires 7 04-18-2010 07:17 PM
