Old 05-27-2014, 09:52 AM   #1
2014 25' FB International
2014 Interstate Ext. Coach
Indianapolis , Indiana
New 2014 Sport 16' - why are the running lights blinking when parked?
Just returned from our first camping trip with our Sport 16'. This morning we noticed the running lights blinking. It is still attached to our 2014 MB ML63 AMG. Called the Airstream dealer...they have no idea. Is this a Mercedes question?
OurJuneBug is offline   Reply With Quote
Old 05-27-2014, 01:18 PM   #2
2004 16' International CCD
Chicagoland , Illinois
Have you checked your running lights before? Has this happened before or is it new?
Are the hazard lights or your turn signal activated in the tow vehicle when this happens? How about the headlights? If so you may have a wiring problem.
If the hazard lights are off in the tow vehicle, do the lights blink in a repeatable fashion (like your turn signals do) or are they just flickering randomly? If they are flickering randomly it might be a loose connection (maybe where the trailer connects to the tow vehicle).
You might try shutting off the car. Disconnecting the trailer plug from your car, and then liberally spraying some contact cleaner on both sets of connections. Then plug and unplug the connector several times, make sure the plug is firmly seated in the socket, and then turn on the car and see if the problem has gone away.
Good luck!
Airrogant is offline   Reply With Quote
Old 05-27-2014, 01:48 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Some European vehicles send a test pulse through the wiring to determine if there is a trailer connected. Your trailer has LED lights, which are very sensitive to those voltage pulses. If you had a trailer with incandescent bulbs, chances are, you would never even see them flash.
Blinking tail lights with Land Rover Der Sand Lights - Interior & Exterior 11 12-20-2011 10:08 PM
Need help with new Airstream - tail lights keep blinking nette Lights - Interior & Exterior 13 07-07-2010 11:35 PM
Blinking lights!!!!! StingrayL82 Electrical - Systems, Generators, Batteries & Solar 6 06-15-2006 05:29 AM
Blinking lights 53flyingcloud On The Road... 0 10-26-2003 09:57 PM
Blinking Galley Lights ViewRVs Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
