Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 08-27-2006, 12:06 PM   #1
Gambit242
Profile:  San Antonio , Texas
Need Identification help
I'm new to the airstream world and I'm buying some land that already has an Airstream on it. I need some help identifying the trailer. I've searched ebay and scanned through pics here and havent' had any luck.
Any help would be appreciated.
ID:	25268  Click image for larger version
Gambit242 is offline   Reply With Quote
Old 08-27-2006, 12:12 PM   #2
Janet
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
We can help. There should be a small square tag riveted on the body with ID numbers. The VIN will help us determine what model, year and wehere it was made.....
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
Wally for President
Janet is offline   Reply With Quote
Old 08-27-2006, 12:13 PM   #3
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Looks like mid-'70's International 31 or so...
Until others weigh in with exact model, if you can check the trailer, the VIN Number from that era will tell all... It will have length, location of manufacture (Ohio or CA) and model, as well as year..
Long double axle trailers were 30 or 31' models.. Pre-1980's had side trim like yours without blue coloring...
If you post VIN (called serial number..) from registration paperwork, some of experts here can ID it...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 08-27-2006, 12:15 PM   #4
Gambit242
You guys are awesome! The trailer/land is about 2 1/2 hrs away but I hope to go back to check it out soon. I wasn't sure if someone would just recognize from the pics.
I'll post the info as soon as I can get it.
Thanks again for your help and advice!
Old 08-27-2006, 12:39 PM   #5
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Congratualtions regardless of your paradigm!
Don't you mean, "I'm buying an Airstream and it already has land with it"???
With both pictures of the same side, there aren't quite enough clues to go on w/o the VIN #, but you may recognize it in the archives.
Check here: Photo Archives
I'd suggest the late 70's either an Ambassador or Sovereign.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 08-27-2006, 12:59 PM   #6
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Late 70's(77-80) and appears to be a center bath. Hard to tell if it is an Ambassasdor or Sovereign..
Aaron
WBCCI #2449 AIR #2495
Old 08-27-2006, 01:03 PM   #7
Gambit242
Wow!You are good! I think that it's the 78 soverign!
I'll post confirmation after I check it out again.
Old 08-27-2006, 01:21 PM   #8
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Gambit,
I am ahhh...intimately aquainted with the 70's vintage trailers I currently have a 75 Sovereign rearbath in a state of destruction, I also have an 80 Excella II in not much better shape I also had my hands on a 74 Tradewind at one point, but someone offered me 3 times what I paid for it, and I didn't (still don't) have time for another project. But just so you don't think I'm perfect
There were a couple of quick giveaways, as to the age, the rear side reflectors are 77 and up, and the battery door on the front wasn't added until after 1975 IIRC. The windows on a rear bath are further forward and typically don't have the access hatch underneath them on the road side.
Aaron
Old 08-27-2006, 04:49 PM   #9
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Originally Posted by wahoonc
Gambit,
Aaron
It also has an air conditioner not seen on Airstreams until after 1973.
Change is inevitable, except from a vending machine
AIR#2611
Old 08-27-2006, 04:55 PM   #10
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
And FWIW it may be rear twins
Aaron
Old 08-27-2006, 07:16 PM   #11
SafeHarbor
Round on both ends
SafeHarbor's Avatar
Profile:  1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Rear twins? Dunno. Would all late 70's rear twins have the access door on the back opening into the between beds cabinet and the off-center mounted license plate? My rear twin '79 doesn't have the street side access plate.
Gambit - do you have a picture where that tag number is clear? Just find a friendly local police officer, explain what you're doing, and see if he'll run the tag for you. If it comes back not in the name of your seller, things might get even more interesting. Anyway, that will tell you the year and VIN of the trailer.
I dragged your rear three-quarters photo to my desktop and opened it in the GIMP. I ran the sharpening filter, and the word in the blue strip starts with an "S."
And welcome to the forums. We need all the 70's long trailers we can get.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-27-2006, 07:53 PM   #12
66Overlander
66Overlander's Avatar
Profile:  1955 22' Safari
1994 28' Excella
Oakland County , Michigan
Images: 11
I'd say it is a 1979 Ambassador or Sovereign with a rear bedroom and a street side (as opposed to front) goucho in the front. My eye says Sovereign because of the length, but it could be an Ambassador. It could perhaps be a '80 or '81 if it is not a '79.
It has 1979 and newer tail lights. 1978 and earlier used a different style.
It has no little windows below the two big ones in the front streetside. This is a giveaway that it has the streetside goucho.
It has a window immediately before the rear endcap. This verifies the rear bedroom. I am not sure on the bed setup. but I will guess twins instead of a queen.
Joe
WBCCI/VAC #5533
'55 22' Safari / '94 28' Excella / '05 Hummer H2
66Overlander is offline   Reply With Quote
Old 08-27-2006, 08:03 PM   #13
SafeHarbor
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
This is fun! (And I'm learning.)
My '79 has a mystery compartment door under the front streetside window. A theory has been floated that the trailer was to be an L-couch but was changed to a front gaucho/side credenza during manufacture.
So... wouldn't that access hatch be UNDER the forward window if it had a side couch?
Just curious.
Lamar
Klaatu barada nikto
Old 08-27-2006, 08:33 PM   #14
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
I know this is the no skill way but....You could call Donald and Sandy Wood in Florida who have that number to see if it was theirs.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
67 Globetrotter septic identification nu2argosy Waste Systems, Tanks & Totes 2 04-01-2006 11:35 AM
VIN Identification trogers713 1970 Sovereign 6 06-15-2004 04:55 PM
Tire replacement Land Yacht Deb Tires 8 07-02-2003 08:36 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
How to find the VIN#? Action Title, VIN & Registration 7 04-19-2002 11:15 AM
