Join Airstream Forums Today
Old 12-04-2005, 01:15 PM   #1
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 20
Send a message via Skype™ to Airstream25
Mounting ham antenna on Airstream trailer
Ham radios can be a good compliment to cell phones. Cell phones are great in the city and along Interstate Highways but in the rural part of sparsely populated western states, service can not be depended upon.
VHF and UHF ham radio repeaters are frequently located on mountain tops where they provide service to much of the rural areas.
Now the question, how to mount the antenna on the trailer?
The standard 5/8 wave mag mount 2 meter antenna used on the steel roof of a truck wont adhere on the aluminum trailer. A bolt or screw on mount could work but would be in the way when trying to park the trailer in the shed. The trailer being so tall, removing the antenna is not convenient.
Suggestions??
Airstream25 is offline   Reply With Quote
Old 12-04-2005, 03:34 PM   #2
azflycaster's Avatar
1975 25' Tradewind
Phoenix , Arizona
Images: 67
If you have a crank up television antenna, you could mount it on that.
BTW, I hope you did not offend Porkey Pig with the tittle of this thread!
Richard
Charter Member Four Corners Unit
Old 12-04-2005, 04:29 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Airstream25
... Now the question, how to mount the antenna on the trailer? ... Suggestions??
Here's how my CB antenna is mounted.
Tom
1967 Airstream Overlander International
AL-1
Old 12-04-2005, 06:32 PM   #4
1995 25' Excella
1982 34' Limited
Images: 20
Tom,
I checked the picture of the CB antenna on your web page. Thanks.
Old 12-05-2005, 08:27 AM   #5
1993 30' Excella
1993 19' "B" Van Airstream 190
Apache Junction, AZ
I installed an NMO mount in the refer vent cover and fished the coax down into the refer compartment, then into the trailer. It can be done (barely) without removing the cover. I use this for an external cell phone antenna. I will probably add anothe NMO for a ham or CB antenna. I use the NMO mount for almost all of my antennas, so they will interchange.
n7bdl is offline   Reply With Quote
Old 01-14-2006, 01:44 PM   #6
What Is A Nmo Mount? Thanks, Jim Kb6oin
J Goertzen is offline   Reply With Quote
Old 01-15-2006, 06:23 PM   #7
1993 30' Excella
Apache Junction, AZ
The NMO (New model Motorola) is a very common VHF/UHF antenna mount. I have CB, cell phone, and ham antennas that use it. You can find it with or without cable in many different configurations at Ham or CB stores. The roof mount, which I used on the Airstream refer vent, requires a 3/4 " hole.
Old 09-15-2011, 08:10 AM   #8
SARGE/AF's Avatar
1997 34' Limited
1977 31' Sovereign
Greeneville , Tennessee
Radio Antenna Install
Originally Posted by Airstream25 View Post
Ham radios can be a good compliment to cell phones. Cell phones are great in the city and along Interstate Highways but in the rural part of sparsely populated western states, service can not be depended upon. VHF and UHF ham radio repeaters are frequently located on mountain tops where they provide service to much of the rural areas. Now the question, how to mount the antenna on the trailer? The standard 5/8 wave mag mount 2 meter antenna used on the steel roof of a truck wont adhere on the aluminum trailer. A bolt or screw on mount could work but would be in the way when trying to park the trailer in the shed. The trailer being so tall, removing the antenna is not convenient. Suggestions??
I have a 3 stage extendable steel pole for antennas that is mounted on the hitch and is removable, It is on a bracket that allows me to lower it, extend pole then put it back up. I disconnect it during travel even thow in its retracted state it is no taller than the AC on the trailer, I just dont like having it there full time only when I plan on using it.
You can find this pole available from most ham radio stores, mine was given to me and came from HRO.
Sarge KG4KWP
SARGE/AF is offline   Reply With Quote
Old 09-15-2011, 08:26 AM   #9
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
For VHF/UHF I would suggest the NMO mounts permanently installed and 1/4 wave antennas which would only be 19 inches at 2 meters,and are flexible enough to get out of the way when going into the garage or whatever.
Based on many years on an antenna test range I can assure you that you will see no difference in performance with the 1/4 wave as compared to the larger 5/8.
On low frequencies we have pipes U bolted to the back bumper on each side.
One has a screwdriver antenna. We remove the whip when traveling. The other can be used for a Hustler 5 BTV when we are parked for longer periods.
The 5 BTV does provide a noticeable improvement on 75 meters where I do most my operating, less so on 40 and probably little or no improvement on 20 meters and up when compared to the screwdriver
Rick Davis 1602 TAC TN-2 K8DOC
PP VAC 2002-03
61 tradewind, 70 Globetrotter
69 Ambassador 64 Overlander
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum How-To's & Support 2 10-15-2002 06:38 PM
LT versus ST tires on a trailer 76Argosy Tires 16 08-21-2002 06:15 AM
Trailer weights, hitch heights & more... ameeker Airstream Trailer Forums 1 06-25-2002 04:42 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
