Old 05-21-2019, 11:20 AM   #1
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
LVD on AGM batteries?
Installing new Fullriver DC220-6 agm batteries and trying to figure out where to set the low voltage disconnect on the Xantrex freedom 1800 inverter. I appears about 40-50% discharge is maximum optimal according to their chart. Their charts are a bit confusing to me as to what voltage that would be.
Also, Fullrivers recommenced charging rates of 14.7 and 13.6 more closely match the flooded settings on the Xantrex. Thoughts?
Thanks!
ID:	341303Click image for larger version
sheriff1 is online now   Reply With Quote
Old 05-21-2019, 10:03 PM   #2
2007 27' International CCD FB
San Diego , California
Congratulations on some nice batteries. Good planning on installing an LVD to protect your investment.
My opinion, but I would set the LVD cut-off much lower than your anticipated capacity use. It should be there to protect the batts in a worst case, rather than artificially limit usable capacity. It's not everyday that one will tap full reserves, but it will be that day, in the cold, over a long night with furnace, that you don't exactly want the batts to cut out. Cold batteries show lower voltages, even if they aren't necessarily at deep DoDs. Something like 80% DoD which is ~11.7V.
What are the flooded voltage settings for the Xantrax? AGMs don't handle high voltages well. So even if the flooded settings are closer, if they are higher than the recommended voltages, I would avoid using that setting.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 05-23-2019, 11:29 AM   #3
Senior Member
sheriff1's Avatar
Sparks , Nevada
At this point Iím looking for a cutoff voltage for the inverter.
Old 05-23-2019, 12:27 PM   #4
Is this a setting on the inverter itself or the LVD?
At high c-rate draws, the battery voltage will sag. A high cutoff could prematurely shut things down.
Old 05-23-2019, 04:06 PM   #5
Senior Member
sheriff1's Avatar
Sparks , Nevada
This would be a setting on the inverter to drop the AC outlets it is providing power to. Low draw items such as TV.
Old 05-24-2019, 09:29 AM   #6
I would stagger the inverter to have a higher cutoff than the LVD.
I'm assuming your inverter loads are discretionary?
It's a balance. You don't want the inverter cutoff so high that it stops the party prematurely. Yet you want to leave some capacity that your critical loads still have reserve before the LVD cuts off.
You invested in great batteries for their capacity, reserve, and durability. IMO, there's no need to baby them. Yet agree that you want to protect them.
My opinion:
Inverter cutoff: 12.0
LVD cutoff: 11.7
I'd be comfortable setting them even .1V lower for each.
If you're conservative, you could go .1V higher for each.
Old 05-24-2019, 10:10 AM   #7
2019 27' Globetrotter
Salem , Oregon
Sheriff1 you mention you mention a DC-220. I can only find a DC-224-6? Also since the 27 has such a high hitch weight well these still be ok on the tongue?
Dave
NoResults is offline   Reply With Quote
Old 05-24-2019, 02:01 PM   #8
Senior Member
sheriff1's Avatar
Sparks , Nevada
ID:	341520Click image for larger version
ID:	341521Click image for larger version
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 36 03-08-2018 07:08 PM
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 05:35 PM
AGM Batteries? Boondocker Batteries, Univolts, Converters & Inverters 33 06-03-2007 06:23 AM
Cabelas AGM batteries wacnstac Batteries, Univolts, Converters & Inverters 26 10-13-2006 07:22 AM
Charging AGM trailer batteries from vehicle mswartz Batteries, Univolts, Converters & Inverters 5 05-15-2004 02:34 PM
