06-12-2019, 01:29 PM
#21
2005 22' International CCD
Pittsburgh
, Pennsylvania
Mattress Replacement
I am looking for a replacement mattress for our 2005 22 ft front bed trailer. I prefer latex and have found several that could be made with the curved corners or that I could modify to fit in place. The problem is that latex seems very heavy....approx 120# for the required size mattress. Not only is it a concern for hitch weight but also for this human to pick it up to apply the mattress pad and fitted sheet. Our current mattress has a noticeable dip where we sit so I do not think that a mattress topper is an option. Do you have any insight, comments or solutions to this problem?
06-12-2019, 02:03 PM
#22
1955 22' Safari
Laredo
Another vote for Rocky Mountain
Originally Posted by beachbouy
Look at rockymountainmattress.com/rv-mattresses. I have no regrets and they will do radial cuts to match your factory cut. Best decision I ever made.
Have had two of their mattresses and find them to be very high quality.
06-16-2019, 09:29 AM
#23
Another solution
I ordered a mattress from Rocky Mountain Mattress company. They specialize in Airstream sizes even the twin beds. They have standard configurations or will make custom to fit your needs.
06-16-2019, 09:49 AM
#24
Clearlake
I have 3" Beautyrest Gel Memory Foam toppers on my beds. You can trim to size or shape with an electric carving knife. Very comfortable and don't hold heat.
06-16-2019, 10:14 AM
#25
2018 22' Sport
Manchester
, Connecticut
22FB mattress
Originally Posted by firemermaid
HI, has anyone dealt with an uncomfortable airstream mattress? My husband & I are brand new to travel trailers. We recently purchased a brand new 2019 Sport 22FB and the mattress is nearly impossible for me to sleep on. Airstream says it is memory foam but it is hard like a rock. I am 67 and my hips, back & legs hurt all night long on that mattress. I cannot get a decent nights rest. Not so on our mattress at home, which is covered with a Tempurpedic mattress topper. We are trying to find a more reasonable mattress topper solution that won't break the bank. (Tempurpedic mattress toppers are not cheap and we would have to cut it up to boot!) Has anyone else dealt with this issue and willing to share solutions? We are looking into a custom 2" Brookside Memory Foam Topper with Quilted Organic Cotton Covertopper from a company called Mattress Insider. Any feedback from any of you out there? Would be so grateful for any thoughts... Thank you!
We experienced this same problem in our 22FF Bambi. Solution was to put a Tempurpedic double topper “UNDER” the mattress which stopped us from bottoming out. We have since moved that topper into our 27 Serenity under the queen mattress and it works well there as well. Tempurpedic topper was bought at Bed Bath and Beyond where you can get a 25% discount coupon on line and save some. It’s been worth it in my opinion.
06-16-2019, 12:07 PM
#26
2001 34' Limited S/O
milton
I'v been sleeping on a sleep # mattress for over 20 years, one at home & one in my
34' airstream. you can adjust matress for comfort. a short queen runs about 1600,
Well worth it. hoe this helps.
Wayne
06-16-2019, 12:10 PM
#27
milton
P/S forgot to mention they have rounded corners at foot of bed.
Wayne
06-16-2019, 05:15 PM
#28
2005 28' Safari S/O
Bountiful
, UT
S/N beds are great. Fully adjustable. Great quality.
06-16-2019, 05:29 PM
#29
Trailer Sold, Waving
2019 26' Flying Cloud
Stettler
, Alberta
I had a custom RV queen mattress made to my specs at Brothers Bedding near Knoxville, Tennessee. For about $900, they use your existing mattress as a template and work with you on the springs, pads and cover to whatever fits you best. About a week. Local Escapees camp 10 miles away.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
06-16-2019, 05:47 PM
#30
2019 33' Classic
Estes Park
Mattress
Google AB lifestyles. You name it, they have it. I purchased a set of custom sheets and blankets from them. They will custom cut a topper for your bed.
06-16-2019, 10:39 PM
#31
2020 16' Nest
2020 16' Basecamp
lee's summit
, MO
Tuft & Needle
I have a 2017 TB 27FB, and recently replaced the oem mattress with a Tuft & Needle Queen. I purchased it on Amazon, along with a $20 electric knife. You can watch YouTube videos on how to cut the foam, it’s very easy.
I just took the oem mattress, put it on top of the T&N mattress, drew the corners with a marker, then cut the T&N mattress with the knife.
Perfect fit, and a very good quality and comfortable mattress.
06-17-2019, 01:09 PM
#32
2016 30' Classic
Indianapolis
, Indiana
I did the same in buying the Tuft and Needle mattress, but did not cut it.
Did you remove or add to the thin wooden ribs under the mattress?
2016 GMC Sierra 2500 HD
2016 30' Classic
ProPride Hitch
Voyager back-up camera
06-20-2019, 07:06 AM
#33
2017 20' Flying Cloud
Williamson County
For the primary bed we use a foam topper, for the convertible bed we use an inflatable mattress with a foam topper and that is very comfortable. The inflatable is easy to adjust for firmness. Get a high quality one that does not leak down of course if you go that route.
06-20-2019, 05:34 PM
#34
2024 19' Caravel
Washougal
Something to consider; it takes in a number of the ideas above:
In our former trailer, the bed was truly uncomfortable. The spring mattress was wimpy and needed help. We solved it with a 3" gel foam topper and then a 4" hard foam sheet UNDER the mattress, cut to size and shape as above. Presto - no more shoulder or bum on hard surface, and the bed was more comfortable than the one at home!
Hope that helps.
06-26-2019, 06:18 AM
#35
2014 22' FB Sport
West Valley City
, Utah
Thermarest
I had the same problem with our 2014 22FB. I owned a couple of Thermarest self-inflating air mattresses. I used the duo kit that links them together. It works and is comfortable. I just put them on top of the mattress. They are not the same shape but cover most of the actual laying down area. I would think to purchase it all new it would be around $250. But they are very durable and can be used other places too.
