Old 06-08-2018, 04:48 PM   #1
Dreamnsilver's Avatar
1988 32' Excella
maumelle , Arkansas
Lights blinking and clicking
Our 1988 Excella 1000 just started making the sound of a car turning signal coming from the 12v box behind front sofa and lights are blinking also any ideas..hheeelllp
I unplugged everything turned batteries off and when i plug in or turn batteries on it is still doing it even when only connected to truck.
Dreamnsilver is offline   Reply With Quote
Old 06-08-2018, 05:48 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The lights are blinking and you are hearing a clicking noise because you have a circuit overload or short. The clicking is the self-resetting circuit breaker cycling open and closed. You have a potentially dangerous situation, and you need to repair the problem ASAP. If you can't fix it immediately, you need to disconnect power from your trailer until you can get it repaired.
Old 06-08-2018, 07:27 PM   #3
1988 32' Excella
maumelle , Arkansas
Thank you
Old 06-24-2018, 07:09 PM   #4
1988 32' Excella
maumelle , Arkansas
It turned out to be a bad converter. We replaced it and all is well. Thank you for your help!
Blinking tail lights with Land Rover daver Lights - Interior & Exterior 11 12-20-2011 10:08 PM
Need help with new Airstream - tail lights keep blinking nette Lights - Interior & Exterior 13 07-07-2010 11:35 PM
Blinking lights!!!!! StingrayL82 Electrical - Systems, Generators, Batteries & Solar 6 06-15-2006 05:29 AM
Blinking lights 53flyingcloud On The Road... 0 10-26-2003 09:57 PM
Blinking Galley Lights ViewRVs Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
