Old 03-22-2012, 11:06 AM   #1
Charlotte , North Carolina
leveling...
New here and can't find this..Do Airstreams come with any leveling aids? I don't see any listed but know leveling is very important...
please excuse if this is a dumb question
mack-in-nc is offline   Reply With Quote
Old 03-22-2012, 11:07 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 58
Depends on how willing your partner is.
Dave
Old 03-22-2012, 11:13 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Hi Mack
Most if not all newer Airstreams come with four stabilizer jacks, one mounted near each corner. During the late 1990s and early 2000s the Classic Limited came with power operated stabilizers instead. The power stabilizers were available as an option some years, too, I believe.
Vintage trailers did not have built-in jacks, and it was customary for their owners to carry a-frame screw jacks and deploy them at each corner.
But the stabilizers aren't really meant for leveling, and the trailer frame can't carry the weight of the trailer on the four corners without bending.
Like most Airstreamers, I carry a set of Lynx levelling blocks and place them under the tires to level the trailer side-to-side. I level the trailer from front to back using the tongue jack.
Some Airstreamers use wood blocks instead of the plastic Lynx blocks, or use plastic blocks from another manufacturer. The main problem with wood blocks is that, when stacked, they tend to slide.
Old 03-22-2012, 11:29 AM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Since in another post you said you were looking at both trailers and motorhomes, I'd add that at least some of the motorhomes had hydraulic leveling systems.
— David
Old 03-22-2012, 11:31 AM   #5
Yep I knew MH's typically have leveling systems...but I was wondering about trailers...
Old 03-22-2012, 11:52 AM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
My 66 Tradewind does not have any stabilizer jacks and does not need them. My 84 31' Excella has manual stabilizer jacks and it does need them. Neither trailer has leveling jacks. I carry 4 2x6's of various lengths to level the trailer side to side. It works for me.
Dan
TouringDan is online now   Reply With Quote
Old 03-22-2012, 12:41 PM   #7
Splitrock's Avatar
Sioux Falls , South Dakota
Relating to my trailer, side to side leveling is done with wheel ramps and front to back leveling is done with the tongue jack.
Old 03-22-2012, 01:01 PM   #8
Please know, that the trailer "is never leveled".
A separate level is installed typically on the A-frame, AND calibrated to the reefer freezer compartment bottom plate or shelf in the freezer.
Then when you leveling, you will level the reefer, which is very important especially in hotter weather.
Usually, but not always, the trailer will also be level, when you level the freezer plate.
Old 03-22-2012, 02:11 PM   #9
AH-SO!!!! I did not know that...not at all...
Old 03-22-2012, 03:13 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
Dometic claims that this is not necessary for current production refrigerators. The design of the cooling unit has changed.
Old 03-22-2012, 04:43 PM   #11
aftermath's Avatar
Spokane , Washington
As far as the refrigerator goes, I believe mine said something like it should be as level as would make you comfortable in the trailer. I took this to mean that it should be close, but not perfectly level.
My problem is getting it level side to side. If my head is just a tad low when I lay down to sleep it really bugs me. The wife is usually asleep by the time I start to complain.
aftermath is offline   Reply With Quote
Old 03-22-2012, 08:56 PM   #12
mapleton , Utah
Theres a simple fix for that- flip over
course if she goes to kiss you in the morning---
rumrunner is offline   Reply With Quote
Old 03-22-2012, 09:12 PM   #13
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
The manual for my new Dometic RM2351 says that you want the trailer to be within 1-2 degrees of level! So, I've been using 2x6s and a small torpedo level camping, and will level my permanent parking spot. Depending on where you're camping, you can use a shovel to dig out an inch or two to lower that side of the trailer
Wherever you go, there you are
Globie64 is offline   Reply With Quote
