Old 03-21-2018, 03:51 PM   #1
2007 31' Classic
Gulf Breeze , Florida
LED light strip
Any suggestions for adding an awning light strip? Brand, etc.
trumpetguy is offline   Reply With Quote
Old 03-21-2018, 04:04 PM   #2
czunc's Avatar
2017 25' Flying Cloud
Dallas , Texas
Try Boogey Lights, I have used these in the past.
https://www.boogeylights.com/rv-mult...low-light-kit/
2017 25FB Flying Cloud
2017 Ford F-250 Platinum FX4
"Life is a team sport"
czunc is offline   Reply With Quote
Old 03-21-2018, 04:20 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Talk to Dan at LED4RV. Tell him Marshall referred you.
Old 03-21-2018, 04:23 PM   #4
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
AS now includes a LED awning light option on Internationals, it requires a larger switch assembly, fishing some wires, and installing the strip. Your local AS dealer would be able to install no problem.
To DIY:
order from AS the following;
(1) interior light switch assembly including bezel-2016 and newer INT (interior light and awning light switch).
(1) LED strip for 28' INT
About 8' of wire
AS runs the wire harness up the curbside rear, but I suggest you run it straight up curbside front from the switch and seal the heck out of the grommet through the outside.
Good luck!
vintagemotor is offline   Reply With Quote
Old 03-21-2018, 04:28 PM   #5
Las Vegas , Nevada
From Airstream Dealer:
LED strip-$154.00
switch assy.-$92.13
This switch replaces the single interior light switch you have now, and maintains the Airstream factory original appearance.
Old 03-21-2018, 05:14 PM   #6
2007 31' Classic
Thanks for all the quick replies. So a strip of leds connected to the porch light won’t work? I see many for sale under $25.00
Old 03-21-2018, 05:19 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
Not an awning strip but if your porch light is the round 3" type with an incandescent bulb LED4RV sells a LED replacement that is much brighter.
Old 03-21-2018, 05:58 PM   #8
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
If by awning light you mean the strip you see at the top of some Airstreams under the awning, the advice to get the strip and switch is good.
If just a porch light, the suggestion to get the LED version was good too.
The $25 strips you've seen might be the kind I put on top of the beltline and connect to my battery. They last about a season - not really meant for all that outdoor stuff - but they're fun while they last.
Good luck!
SteveSueMac is online now   Reply With Quote
Awning LED Light Strip factory install silvereagle2 Lights - Interior & Exterior 36 04-19-2016 11:56 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
