Old 03-01-2006, 11:02 AM   #1
Woodbridge , Virginia
Is an Airstream a summer oven?
After 35 years of camping in tents and tent trailers we are seriously considering purchasing an Airstream (huzzah). We re interested in the 19' and the new 20' models. How well does the interior of an Airstream hold up under summer heat with open windows and a fantastic fan when boondocking? Do they get stiffling hot? We tend to camp at state and National parks where seldom do you have the opportunity for electrical hookups. We note that the windows on the 19' standard have small openings for ventilation. The Casita forum claims that the interior of a Bambi wil get hot enough to cook food without using the range (not that I put a lof of faith in the comment). Any experiences or knowledge will be appreciated.
Explorin is offline   Reply With Quote
Old 03-01-2006, 11:32 AM   #2
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
An Airstream in the direct sun gets hot. VERY hot. MUCH hotter than a Casita or a Scamp. I have had a parade of Airstreams as well as fiberglass trailers. I'm regularly amazed at how much difference there is between them. If you can park your Airstream in partial shade though, it's not so bad.
Roger
AIR 2053 Current: 2004 Airstream Interstate "B-Van" & 2006 Born Free 32 RQ Kodiak Chassis
Old 03-01-2006, 12:11 PM   #3
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Explorin, Like Roger says, shade works well and so do Hondas and Yamahas for generators. Considering you may not be inside your trailer much in the summertime with the exception of the nighttime hours, you'd be well advised to take a look at all the information on this forum concerning generators. Should you have the 'luxury' of planning your trips on a seasonal basis i.e. South in the Winter and mountains in the Summer, who knows, you may not even need the AC at night? Having said all that, if you camp in the open, summer sunlight, your Airstream will heat up quickly, the AC will run all the time, cool down slowly and not nearly as efficiently as your home or automobile. Good luck in your decision and welcome to this very useful Forum.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 03-01-2006, 12:40 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
It's hot, but with the windows open and fantastic vent(s) running, it's not bad. Of course when it's been 95+ outside with 40% humidity and in direct sunlight, it's nice having a good A/C unit.
In the 19' and 23' units, I think they come standard with 11k BTU units, I would opt to upgrade that to 13.5k units. If you go larger than 23', I'd bump up to a 15k unit.
Old 03-01-2006, 01:08 PM   #5
jcanavera's Avatar
Fenton , Missouri
Images: 143
Part of the key to comfort is also the windows themselves. The riveted windows as found on the Classic, CCD and Safari SE line swing out. The other models which use the windows surrounded by a black gasket have a limited portion of the window that opens.
If a lack of power is an issue, be sure to get a model with the riveted windows.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-01-2006, 01:34 PM   #6
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
While it's true that AS's can heat up during the day, we have found that they also cool off pretty quick. Aluminum does not hold heat well. Also being as reflective as they are, they don't get as hot as they might if say they were the SOB white/beige paint stuff.
Like Jack mentioned, I'd consider a model where you can open windows as much as posible. On our 19' CCD, the front window swings up quite a bit, the curb side bedroom window also opens generously.
And if you really need it, you can swing the door open, and just use the screen door.
One of the best suggestions I got from Silvertwinkie: If you go with a 19' model, be sure to spend the extra 240 dollars and get a second Fantastic Fan. Our stock 11,000btu AC seems to keep us cool enough during extreme temps, so I can't say that I miss the 13,500 btu unit, and I'm pretty freon-dependent during summer months.
When you say national Parks, do you mean parks out west? If that's the case, we found that no matter where we were, we seldom had any need for AC. For example, we camped at Zion NP during the summer when temps would get to about 100 degrees during the day, but by 9 or 10 o'clock in the evening, we might be looking for a blanket! It really cools off at night, at least that's what we found.
If you are camping in the midwest/east where it can get hot and humid and stay that way, you would either need a camp ground with electric or carry a couple of portable generators or a giant heavy one to run the AC.
Jonathan
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 03-01-2006, 03:03 PM   #7
Aluminut
2004 25' Safari
. , Illinois
Jack
I have the windows with the black gaskets. They don't fully open like the Classic, SE or CCDs, however this can be overcome with a fantastic vent....as Lev said, two can really be great. I can get a wind tunnel in our 25' with the windows alone open and both fans on high or one setting before high. Opening the door with the fans on is even better.
Old 03-01-2006, 03:34 PM   #8
mandolindave's Avatar
Grillin' & Chillin'
I work at a Bluegrass Festival for ten days, in July every year.
1. I try for a spot with afternoon shade.
2. I use a 12 volt, clip on, oscilating fan pointed at my person.
3. I sit by the creek in the heat of the day.
mandolindave is offline   Reply With Quote
Old 03-01-2006, 03:41 PM   #9
cammur's Avatar
Roseville , California
We looked at two 25' Airstreams, one with beautiful wrap around front windows and high edge windows, the other with fewer and less fancy windows. On a hot Sacramento day, the one with less glass showing (the one we got) was definitely cooler. That was a major factor in our decision, helped by the cooler one being cheaper. Both units had all windows closed, the door open, and roof vents open but fan not running.
But boy do I like the looks of the one we didn't get! If I had it to do over, I'd get the one with more glass, and as Johnathan and others have said, add a 2nd Fantastic Fan.
I can't compare the windows, but I will say our windows are hard to open, and don't open far.
Cam
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 03-01-2006, 04:54 PM   #10
CanoeStream's Avatar
St. Cloud , Minnesota
Ditto on Jack Canavera's (and others') comments about the hinge-from-the-top windows. I would travel with my Argosy closed up and arrive all hot inside. Opening the top-hinged windows would cool it off inside purt' darned quick! Of course nothing helps on those muggy hot nights...
It is definitely hard to tote around enough 30A generator power and fuel to run the AC while boondocking (don't try the AC on anything less than a 30A circuit -- you could burn out the compressor!). You need at least two lightweight Honda EU2000i generators to run the AC -- cables are available to put it together right. I have the link for making your own here somewhere.... A single 30A generator gets pretty heavy to hoist up and down from a pickup bed. Yamaha generators have started to catch up to Honda (saw a big display at recent RV show; also featured in latest Airstream Life magazine). If you camp in the hottest season or areas, cooling off the hot inside with the AC toward the end of the afternoon has got to help some.
Due to the flammability issues with transporting gasoline I am really paying attention to this post! Propane powered EU2000i. I'd think the LP conversion could be worked with any generator -- talk to your dealer, talk to the local gas service company, etc.
5 meter Langford Nahanni
Old 03-01-2006, 05:06 PM   #11
lewster's Avatar
Naples, FL , Hood River, OR
Good advice! One thing that has not been mentioned is interior window tinting. I had this done to all of my vehicles here in SW Florida, and it makes a huge difference. So much so, that I just had my house done (faces mostly south) and even had the CCD done in a silver reflective tint. Besides looking awesome, it has reduced the interior heat during the day considerably. If I had the time, I would have done a temp. comparison, but it IS noticeable!
Also, be sure to order a full set of awnings. They help a lot too.
Old 03-01-2006, 05:22 PM   #12
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Airstreams are hot stuff
The newer units have white roof coating. It really helps. I had a 77 that baked when at International Rallies in Rapid city and Huntsville. I ran experiment to see if it was worth it to paint the roof. It really helps. temp inside dropped over 10 degrees F on a summer afternoon and seemed to have no effect on how fast it cooled down after the sun went down. Have had quite a few others also paint them. Helped them also. Parking so the awning shades the side also helps. Awnings all around (even covering a swing out window) also helps. Personal fans inside are also an option. It may not look classical, but form must follow function in my book.
Old 03-01-2006, 05:44 PM   #13
bill benton's Avatar
Mansfield , Texas
Some are hotter than others
In 1991 was when my Airstream was built. I think somebody at the factory was on something when they decided to offer a 34' trailer with a 13,000 BTU AC. I don't know if anyone thought that some people lived in the south. I know a second unit was a option. But it should have been mandatory for any units that were to be sold in the south. I've had it checked twice and was told it is functioning better than a new unit. If the temp goes above 85, staying inside is not a option.
bill benton is offline   Reply With Quote
Old 03-01-2006, 06:03 PM   #14
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I can attest to the effectiveness of window tinting. I tinted the windows in our Overlander just before the Florida State Rally, and there was at least a 5 degree drop in interior temperature versus the week two weeks previous. It will probably also cut down on the colors in your fabrics fading, as well.
Cost to restore a gutted Airstream Draco General Interior Topics 28 02-18-2013 11:17 PM
future airstream motorhome betteleal Airstream Motorhome Forums 11 02-12-2005 01:39 PM
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
